--- ray/src/cal/rcalc.c 2003/11/14 17:31:24 1.11 +++ ray/src/cal/rcalc.c 2014/05/10 01:48:14 1.25 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcalc.c,v 1.11 2003/11/14 17:31:24 schorsch Exp $"; +static const char RCSid[] = "$Id: rcalc.c,v 1.25 2014/05/10 01:48:14 greg Exp $"; #endif /* * rcalc.c - record calculator program. @@ -8,22 +8,21 @@ static const char RCSid[] = "$Id: rcalc.c,v 1.11 2003/ */ #include -#include -#include -#include #include #include #include "platform.h" -#include "calcomp.h" #include "rterror.h" +#include "rtmisc.h" +#include "rtio.h" +#include "calcomp.h" #define isnum(c) (isdigit(c) || (c)=='-' || (c)=='.' \ || (c)=='+' || (c)=='e' || (c)=='E') #define isblnk(c) (igneol ? isspace(c) : (c)==' '||(c)=='\t') -#define INBSIZ 4096 /* longest record */ +#define INBSIZ 16384 /* longest record */ #define MAXCOL 32 /* number of columns recorded */ /* field type specifications */ @@ -76,10 +75,12 @@ struct strvar *svhead = NULL; /* string variables */ int blnkeq = 1; /* blanks compare equal? */ int igneol = 0; /* ignore end of line? */ +int passive = 0; /* passive mode (transmit unmatched input) */ char sepchar = '\t'; /* input/output separator */ int noinput = 0; /* no input records? */ +int itype = 'a'; /* input type (a/f/F/d/D) */ int nbicols = 0; /* number of binary input columns */ -int bocols = 0; /* produce binary output columns */ +int otype = 'a'; /* output format (a/f/F/d/D) */ char inpbuf[INBSIZ]; /* input buffer */ double colval[MAXCOL]; /* input column values */ unsigned long colflg = 0; /* column retrieved flags */ @@ -103,6 +104,7 @@ int argc, char *argv[] ) { + char *fpath; int i; esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_OUTCHAN|E_RCONST; @@ -122,6 +124,9 @@ char *argv[] case 'l': igneol = !igneol; break; + case 'p': + passive = !passive; + break; case 't': sepchar = argv[i][2]; break; @@ -129,7 +134,15 @@ char *argv[] svpreset(argv[++i]); break; case 'f': - fcompile(argv[++i]); + fpath = getpath(argv[++i], getrlibpath(), 0); + if (fpath == NULL) { + eputs(argv[0]); + eputs(": cannot find file '"); + eputs(argv[i]); + eputs("'\n"); + quit(1); + } + fcompile(fpath); break; case 'e': scompile(argv[++i], NULL, 0); @@ -140,13 +153,17 @@ char *argv[] case 'i': switch (argv[i][2]) { case '\0': + itype = 'a'; nbicols = 0; readfmt(argv[++i], 0); break; case 'a': + itype = 'a'; nbicols = 0; break; case 'd': + case 'D': + itype = argv[i][2]; if (isdigit(argv[i][3])) nbicols = atoi(argv[i]+3); else @@ -158,11 +175,13 @@ char *argv[] } break; case 'f': + case 'F': + itype = argv[i][2]; if (isdigit(argv[i][3])) - nbicols = -atoi(argv[i]+3); + nbicols = atoi(argv[i]+3); else - nbicols = -1; - if (-nbicols*sizeof(float) > INBSIZ) { + nbicols = 1; + if (nbicols*sizeof(float) > INBSIZ) { eputs(argv[0]); eputs(": too many input columns\n"); quit(1); @@ -175,18 +194,20 @@ char *argv[] case 'o': switch (argv[i][2]) { case '\0': - bocols = 0; + otype = 'a'; readfmt(argv[++i], 1); break; case 'a': - bocols = 0; + otype = 'a'; break; case 'd': - bocols = 1; - break; + case 'D': case 'f': - bocols = -1; + case 'F': + otype = argv[i][2]; break; + default: + goto userr; } break; case 'w': @@ -199,16 +220,24 @@ char *argv[] userr: eputs("Usage: "); eputs(argv[0]); -eputs(" [-b][-l][-n][-w][-u][-tS][-s svar=sval][-e expr][-f source][-i infmt][-o outfmt] [file]\n"); +eputs(" [-b][-l][-n][-p][-w][-u][-tS][-s svar=sval][-e expr][-f source][-i infmt][-o outfmt] [file]\n"); quit(1); } - + if (otype != 'a') + SET_FILE_BINARY(stdout); +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + flockfile(stdout); +#endif if (noinput) { /* produce a single output record */ + if (i < argc) { + eputs(argv[0]); + eputs(": file argument(s) incompatible with -n\n"); + quit(1); + } eclock++; putout(); quit(0); } - if (blnkeq) /* for efficiency */ nbsynch(); @@ -242,12 +271,20 @@ FILE *fp { if (inpfmt != NULL) return(getrec()); - if (nbicols > 0) - return(fread(inpbuf, sizeof(double), - nbicols, fp) == nbicols); - if (nbicols < 0) - return(fread(inpbuf, sizeof(float), - -nbicols, fp) == -nbicols); + if (tolower(itype) == 'd') { + if (fread(inpbuf, sizeof(double), nbicols, fp) != nbicols) + return(0); + if (itype == 'D') + swap64(inpbuf, nbicols); + return(1); + } + if (tolower(itype) == 'f') { + if (fread(inpbuf, sizeof(float), nbicols, fp) != nbicols) + return(0); + if (itype == 'F') + swap32(inpbuf, nbicols); + return(1); + } return(fgets(inpbuf, INBSIZ, fp) != NULL); } @@ -269,16 +306,22 @@ char *file eputs(": cannot open\n"); quit(1); } + if (itype != 'a') + SET_FILE_BINARY(fp); +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + flockfile(fp); +#endif if (inpfmt != NULL) initinp(fp); while (getinputrec(fp)) { varset("recno", '=', (double)++nrecs); + varset("outno", '=', (double)(nout+1)); colflg = 0; eclock++; if (!conditional || varvalue("cond") > 0.0) { - varset("outno", '=', (double)++nout); putout(); + ++nout; } } fclose(fp); @@ -292,11 +335,11 @@ putout(void) /* produce an output recor colpos = 0; if (outfmt != NULL) putrec(); - else if (bocols) - chanout(bchanset); - else + else if (otype == 'a') chanout(chanset); - if (colpos && !bocols) + else + chanout(bchanset); + if (colpos && otype == 'a') putchar('\n'); if (unbuff) fflush(stdout); @@ -307,7 +350,7 @@ static double l_in(char *funame) /* function call for $channel */ { int n; - register char *cp; + char *cp; /* get argument as integer */ n = (int)(argument(1) + .5); if (n != 0) /* return channel value */ @@ -315,10 +358,8 @@ l_in(char *funame) /* function call for $channel */ /* determine number of channels */ if (noinput || inpfmt != NULL) return(0); - if (nbicols > 0) + if (nbicols) return(nbicols); - if (nbicols < 0) - return(-nbicols); cp = inpbuf; /* need to count */ for (n = 0; *cp; ) if (blnkeq && isspace(sepchar)) { @@ -341,7 +382,7 @@ int n ) { int i; - register char *cp; + char *cp; if (noinput || inpfmt != NULL) { eputs("no column input\n"); @@ -351,15 +392,13 @@ int n eputs("illegal channel number\n"); quit(1); } - if (nbicols > 0) { + if (nbicols) { if (n > nbicols) return(0.0); - cp = inpbuf + (n-1)*sizeof(double); - return(*(double *)cp); - } - if (nbicols < 0) { - if (n > -nbicols) - return(0.0); + if (tolower(itype) == 'd') { + cp = inpbuf + (n-1)*sizeof(double); + return(*(double *)cp); + } cp = inpbuf + (n-1)*sizeof(float); return(*(float *)cp); } @@ -411,16 +450,25 @@ double v ) { static char zerobuf[sizeof(double)]; + float fval = v; while (++colpos < n) fwrite(zerobuf, - bocols>0 ? sizeof(double) : sizeof(float), + tolower(otype)=='d' ? sizeof(double) : sizeof(float), 1, stdout); - if (bocols > 0) + switch (otype) { + case 'D': + swap64((char *)&v, 1); + /* fall through */ + case 'd': fwrite(&v, sizeof(double), 1, stdout); - else { - float fval = v; + break; + case 'F': + swap32((char *)&fval, 1); + /* fall through */ + case 'f': fwrite(&fval, sizeof(float), 1, stdout); + break; } } @@ -435,7 +483,7 @@ int output char *inptr; struct field fmt; int res; - register struct field *f; + struct field *f; /* check for inline format */ for (inptr = spec; *inptr; inptr++) if (*inptr == '$') @@ -448,7 +496,7 @@ int output eputs(": cannot open\n"); quit(1); } - res = read(fd, inpbuf+1, INBSIZ-1); + res = read(fd, inpbuf+2, INBSIZ-2); if (res <= 0 || res >= INBSIZ-1) { eputs(spec); if (res < 0) @@ -460,7 +508,7 @@ int output quit(1); } close(fd); - (inptr=inpbuf+1)[res] = '\0'; + (inptr=inpbuf+2)[res] = '\0'; } f = &fmt; /* get fields */ while ((res = readfield(&inptr)) != F_NUL) { @@ -495,12 +543,12 @@ int output static int readfield( /* get next field in format */ -register char **pp +char **pp ) { int type = F_NUL; int width = 0; - register char *cp; + char *cp; cp = inpbuf; while (cp < &inpbuf[INBSIZ-1] && **pp != '\0') { @@ -565,7 +613,7 @@ getsvar( /* get string variabl char *svname ) { - register struct strvar *sv; + struct strvar *sv; for (sv = svhead; sv != NULL; sv = sv->next) if (!strcmp(sv->name, svname)) @@ -584,8 +632,8 @@ svpreset( /* preset a string variab char *eqn ) { - register struct strvar *sv; - register char *val; + struct strvar *sv; + char *val; for (val = eqn; *val != '='; val++) if (!*val) @@ -604,7 +652,7 @@ char *eqn static void clearrec(void) /* clear input record variables */ { - register struct field *f; + struct field *f; for (f = inpfmt; f != NULL; f = f->next) switch (f->type & F_TYP) { @@ -622,33 +670,35 @@ clearrec(void) /* clear input record variables */ static int -getrec(void) /* get next record from file */ +getrec(void) /* get next record from file */ { int eatline; - register struct field *f; - + struct field *f; + while (ipb.chr != EOF) { - eatline = !igneol && ipb.chr != '\n'; - if (blnkeq) /* beware of nbsynch() */ + if (blnkeq) { /* beware of nbsynch() */ while (isblnk(ipb.chr)) - scaninp(); + resetinp(); + if (ipb.chr == EOF) + return(0); + } + eatline = (!igneol && ipb.chr != '\n'); clearrec(); /* start with fresh record */ for (f = inpfmt; f != NULL; f = f->next) if (getfield(f) == -1) break; if (f == NULL) { - advinp(); + advinp(); /* got one! */ return(1); } - resetinp(); + resetinp(); /* eat false start */ if (eatline) { /* eat rest of line */ while (ipb.chr != '\n') { if (ipb.chr == EOF) return(0); - scaninp(); + resetinp(); } - scaninp(); - advinp(); + resetinp(); } } return(0); @@ -657,14 +707,14 @@ getrec(void) /* get nex static int getfield( /* get next field */ -register struct field *f +struct field *f ) { static char buf[RMAXWORD+1]; /* no recursion! */ int delim, inword; double d; char *np; - register char *cp; + char *cp; switch (f->type & F_TYP) { case T_LIT: @@ -751,10 +801,11 @@ register struct field *f static void putrec(void) /* output a record */ { - char fmt[32]; - register int n; - register struct field *f; + char fmt[32], typ[16]; + int n; + struct field *f; int adlast, adnext; + double dv, av; adlast = 0; for (f = outfmt; f != NULL; f = f->next) { @@ -785,13 +836,24 @@ putrec(void) /* output break; case T_NUM: n = f->type & F_WID; + dv = evalue(f->f.ne); + av = fabs(dv); + if (n <= 9) + strcpy(typ, "g"); + else + sprintf(typ, ".%de", n-5); + if (av < 1L<<31) { + long iv = (int)(av + .5); + if (iv && fabs(av-iv) <= av*1e-14) + strcpy(typ, ".0f"); + } if (adlast && adnext) - strcpy(fmt, "%g"); + sprintf(fmt, "%%%s", typ); else if (adlast) - sprintf(fmt, "%%-%dg", n); + sprintf(fmt, "%%-%d%s", n, typ); else - sprintf(fmt, "%%%dg", n); - printf(fmt, evalue(f->f.ne)); + sprintf(fmt, "%%%d%s", n, typ); + printf(fmt, dv); adlast = 1; break; } @@ -845,6 +907,8 @@ resetinp(void) /* rewind position ipb.beg = ipb.end; ipb.pos = ipb.beg; ipb.chr = *ipb.pos; + if (passive) /* transmit unmatched character? */ + fputc(ipb.chr, stdout); if (++ipb.beg >= &inpbuf[INBSIZ]) ipb.beg = inpbuf; scaninp();
