--- ray/src/cal/rcalc.c 2003/11/06 05:39:33 1.10 +++ ray/src/cal/rcalc.c 2005/06/02 04:47:27 1.18 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcalc.c,v 1.10 2003/11/06 05:39:33 greg Exp $"; +static const char RCSid[] = "$Id: rcalc.c,v 1.18 2005/06/02 04:47:27 greg Exp $"; #endif /* * rcalc.c - record calculator program. @@ -8,21 +8,24 @@ static const char RCSid[] = "$Id: rcalc.c,v 1.10 2003/ */ #include +#include #include #include #include #include #include "platform.h" -#include "calcomp.h" #include "rterror.h" +#include "rtmisc.h" +#include "rtio.h" +#include "calcomp.h" #define isnum(c) (isdigit(c) || (c)=='-' || (c)=='.' \ || (c)=='+' || (c)=='e' || (c)=='E') #define isblnk(c) (igneol ? isspace(c) : (c)==' '||(c)=='\t') -#define INBSIZ 4096 /* longest record */ +#define INBSIZ 16384 /* longest record */ #define MAXCOL 32 /* number of columns recorded */ /* field type specifications */ @@ -75,6 +78,7 @@ struct strvar *svhead = NULL; /* string variables */ int blnkeq = 1; /* blanks compare equal? */ int igneol = 0; /* ignore end of line? */ +int passive = 0; /* passive mode (transmit unmatched input) */ char sepchar = '\t'; /* input/output separator */ int noinput = 0; /* no input records? */ int nbicols = 0; /* number of binary input columns */ @@ -121,6 +125,9 @@ char *argv[] case 'l': igneol = !igneol; break; + case 'p': + passive = !passive; + break; case 't': sepchar = argv[i][2]; break; @@ -182,10 +189,14 @@ char *argv[] break; case 'd': bocols = 1; + SET_FILE_BINARY(stdout); break; case 'f': bocols = -1; + SET_FILE_BINARY(stdout); break; + default: + goto userr; } break; case 'w': @@ -198,15 +209,23 @@ char *argv[] userr: eputs("Usage: "); eputs(argv[0]); -eputs(" [-b][-l][-n][-w][-u][-tS][-s svar=sval][-e expr][-f source][-i infmt][-o outfmt] [file]\n"); +eputs(" [-b][-l][-n][-p][-w][-u][-tS][-s svar=sval][-e expr][-f source][-i infmt][-o outfmt] [file]\n"); quit(1); } - + if (bocols) + SET_FILE_BINARY(stdout); if (noinput) { /* produce a single output record */ + if (i < argc) { + eputs(argv[0]); + eputs(": file argument(s) incompatible with -n\n"); + quit(1); + } eclock++; putout(); quit(0); } + if (nbicols) + SET_FILE_BINARY(stdin); if (blnkeq) /* for efficiency */ nbsynch(); @@ -218,6 +237,7 @@ eputs(" [-b][-l][-n][-w][-u][-tS][-s svar=sval][-e exp execute(argv[i]); quit(0); + return 0; /* pro forma return */ } @@ -446,7 +466,7 @@ int output eputs(": cannot open\n"); quit(1); } - res = read(fd, inpbuf+1, INBSIZ-1); + res = read(fd, inpbuf+2, INBSIZ-2); if (res <= 0 || res >= INBSIZ-1) { eputs(spec); if (res < 0) @@ -458,7 +478,7 @@ int output quit(1); } close(fd); - (inptr=inpbuf+1)[res] = '\0'; + (inptr=inpbuf+2)[res] = '\0'; } f = &fmt; /* get fields */ while ((res = readfield(&inptr)) != F_NUL) { @@ -620,33 +640,32 @@ clearrec(void) /* clear input record variables */ static int -getrec(void) /* get next record from file */ +getrec(void) /* get next record from file */ { int eatline; register struct field *f; - + while (ipb.chr != EOF) { - eatline = !igneol && ipb.chr != '\n'; if (blnkeq) /* beware of nbsynch() */ while (isblnk(ipb.chr)) - scaninp(); + resetinp(); + eatline = (!igneol && ipb.chr != '\n'); clearrec(); /* start with fresh record */ for (f = inpfmt; f != NULL; f = f->next) if (getfield(f) == -1) break; if (f == NULL) { - advinp(); + advinp(); /* got one! */ return(1); } - resetinp(); + resetinp(); /* eat false start */ if (eatline) { /* eat rest of line */ while (ipb.chr != '\n') { if (ipb.chr == EOF) return(0); - scaninp(); + resetinp(); } - scaninp(); - advinp(); + resetinp(); } } return(0); @@ -843,6 +862,8 @@ resetinp(void) /* rewind position ipb.beg = ipb.end; ipb.pos = ipb.beg; ipb.chr = *ipb.pos; + if (passive) /* transmit unmatched character? */ + fputc(ipb.chr, stdout); if (++ipb.beg >= &inpbuf[INBSIZ]) ipb.beg = inpbuf; scaninp();
