| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rcalc.c,v 1.24 2014/05/10 01:27:14 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rcalc.c - record calculator program.
| 6 |
| 7 |
* 9/11/87
| 8 |
| 9 |
| 10 |
#include <stdlib.h>
| 11 |
#include <math.h>
| 12 |
#include <ctype.h>
| 13 |
| 14 |
#include "platform.h"
| 15 |
#include "rterror.h"
| 16 |
#include "rtmisc.h"
| 17 |
#include "rtio.h"
| 18 |
#include "calcomp.h"
| 19 |
| 20 |
#define isnum(c) (isdigit(c) || (c)=='-' || (c)=='.' \
| 21 |
|| (c)=='+' || (c)=='e' || (c)=='E')
| 22 |
| 23 |
#define isblnk(c) (igneol ? isspace(c) : (c)==' '||(c)=='\t')
| 24 |
| 25 |
#define INBSIZ 16384 /* longest record */
| 26 |
#define MAXCOL 32 /* number of columns recorded */
| 27 |
| 28 |
/* field type specifications */
| 29 |
#define F_NUL 0 /* empty */
| 30 |
#define F_TYP 0x7000 /* mask for type */
| 31 |
#define F_WID 0x0fff /* mask for width */
| 32 |
#define T_LIT 0x1000 /* string literal */
| 33 |
#define T_STR 0x2000 /* string variable */
| 34 |
#define T_NUM 0x3000 /* numeric value */
| 35 |
| 36 |
struct strvar { /* string variable */
| 37 |
char *name;
| 38 |
char *val;
| 39 |
char *preset;
| 40 |
struct strvar *next;
| 41 |
| 42 |
| 43 |
struct field { /* record format structure */
| 44 |
int type; /* type of field (& width) */
| 45 |
union {
| 46 |
char *sl; /* string literal */
| 47 |
struct strvar *sv; /* string variable */
| 48 |
char *nv; /* numeric variable */
| 49 |
EPNODE *ne; /* numeric expression */
| 50 |
} f; /* field contents */
| 51 |
struct field *next; /* next field in record */
| 52 |
| 53 |
| 54 |
#define savqstr(s) strcpy(emalloc(strlen(s)+1),s)
| 55 |
#define freqstr(s) efree(s)
| 56 |
| 57 |
static int getinputrec(FILE *fp);
| 58 |
static void scaninp(void), advinp(void), resetinp(void);
| 59 |
static void putrec(void), putout(void), nbsynch(void);
| 60 |
static int getrec(void);
| 61 |
static void execute(char *file);
| 62 |
static void initinp(FILE *fp);
| 63 |
static void svpreset(char *eqn);
| 64 |
static void readfmt(char *spec, int output);
| 65 |
static int readfield(char **pp);
| 66 |
static int getfield(struct field *f);
| 67 |
static void chanset(int n, double v);
| 68 |
static void bchanset(int n, double v);
| 69 |
static struct strvar* getsvar(char *svname);
| 70 |
static double l_in(char *);
| 71 |
| 72 |
struct field *inpfmt = NULL; /* input record format */
| 73 |
struct field *outfmt = NULL; /* output record structure */
| 74 |
struct strvar *svhead = NULL; /* string variables */
| 75 |
| 76 |
int blnkeq = 1; /* blanks compare equal? */
| 77 |
int igneol = 0; /* ignore end of line? */
| 78 |
int passive = 0; /* passive mode (transmit unmatched input) */
| 79 |
char sepchar = '\t'; /* input/output separator */
| 80 |
int noinput = 0; /* no input records? */
| 81 |
int itype = 'a'; /* input type (a/f/F/d/D) */
| 82 |
int nbicols = 0; /* number of binary input columns */
| 83 |
int otype = 'a'; /* output format (a/f/F/d/D) */
| 84 |
char inpbuf[INBSIZ]; /* input buffer */
| 85 |
double colval[MAXCOL]; /* input column values */
| 86 |
unsigned long colflg = 0; /* column retrieved flags */
| 87 |
int colpos; /* output column position */
| 88 |
| 89 |
int nowarn = 0; /* non-fatal diagnostic output */
| 90 |
int unbuff = 0; /* unbuffered output (flush each record) */
| 91 |
| 92 |
struct {
| 93 |
FILE *fin; /* input file */
| 94 |
int chr; /* next character */
| 95 |
char *beg; /* home position */
| 96 |
char *pos; /* scan position */
| 97 |
char *end; /* read position */
| 98 |
} ipb; /* circular lookahead buffer */
| 99 |
| 100 |
| 101 |
int
| 102 |
main(
| 103 |
int argc,
| 104 |
char *argv[]
| 105 |
| 106 |
| 107 |
char *fpath;
| 108 |
int i;
| 109 |
| 110 |
esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_OUTCHAN|E_RCONST;
| 111 |
esupport &= ~(E_REDEFW);
| 112 |
| 113 |
#ifdef BIGGERLIB
| 114 |
biggerlib();
| 115 |
#endif
| 116 |
varset("PI", ':', 3.14159265358979323846);
| 117 |
funset("in", 1, '=', &l_in);
| 118 |
| 119 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 120 |
switch (argv[i][1]) {
| 121 |
case 'b':
| 122 |
blnkeq = !blnkeq;
| 123 |
break;
| 124 |
case 'l':
| 125 |
igneol = !igneol;
| 126 |
break;
| 127 |
case 'p':
| 128 |
passive = !passive;
| 129 |
break;
| 130 |
case 't':
| 131 |
sepchar = argv[i][2];
| 132 |
break;
| 133 |
case 's':
| 134 |
svpreset(argv[++i]);
| 135 |
break;
| 136 |
case 'f':
| 137 |
fpath = getpath(argv[++i], getrlibpath(), 0);
| 138 |
if (fpath == NULL) {
| 139 |
eputs(argv[0]);
| 140 |
eputs(": cannot find file '");
| 141 |
eputs(argv[i]);
| 142 |
eputs("'\n");
| 143 |
quit(1);
| 144 |
| 145 |
fcompile(fpath);
| 146 |
break;
| 147 |
case 'e':
| 148 |
scompile(argv[++i], NULL, 0);
| 149 |
break;
| 150 |
case 'n':
| 151 |
noinput = 1;
| 152 |
break;
| 153 |
case 'i':
| 154 |
switch (argv[i][2]) {
| 155 |
case '\0':
| 156 |
itype = 'a';
| 157 |
nbicols = 0;
| 158 |
readfmt(argv[++i], 0);
| 159 |
break;
| 160 |
case 'a':
| 161 |
itype = 'a';
| 162 |
nbicols = 0;
| 163 |
break;
| 164 |
case 'd':
| 165 |
case 'D':
| 166 |
itype = argv[i][2];
| 167 |
if (isdigit(argv[i][3]))
| 168 |
nbicols = atoi(argv[i]+3);
| 169 |
else
| 170 |
nbicols = 1;
| 171 |
if (nbicols*sizeof(double) > INBSIZ) {
| 172 |
eputs(argv[0]);
| 173 |
eputs(": too many input columns\n");
| 174 |
quit(1);
| 175 |
| 176 |
break;
| 177 |
case 'f':
| 178 |
case 'F':
| 179 |
itype = argv[i][2];
| 180 |
| 181 |
| 182 |
else
| 183 |
nbicols = 1;
| 184 |
if (nbicols*sizeof(float) > INBSIZ) {
| 185 |
eputs(argv[0]);
| 186 |
| 187 |
quit(1);
| 188 |
| 189 |
break;
| 190 |
default:
| 191 |
goto userr;
| 192 |
| 193 |
break;
| 194 |
case 'o':
| 195 |
| 196 |
case '\0':
| 197 |
otype = 'a';
| 198 |
readfmt(argv[++i], 1);
| 199 |
break;
| 200 |
case 'a':
| 201 |
otype = 'a';
| 202 |
break;
| 203 |
case 'd':
| 204 |
case 'D':
| 205 |
case 'f':
| 206 |
case 'F':
| 207 |
otype = argv[i][2];
| 208 |
break;
| 209 |
default:
| 210 |
goto userr;
| 211 |
| 212 |
break;
| 213 |
case 'w':
| 214 |
nowarn = !nowarn;
| 215 |
break;
| 216 |
case 'u':
| 217 |
unbuff = !unbuff;
| 218 |
break;
| 219 |
default:;
| 220 |
userr:
| 221 |
eputs("Usage: ");
| 222 |
eputs(argv[0]);
| 223 |
eputs(" [-b][-l][-n][-p][-w][-u][-tS][-s svar=sval][-e expr][-f source][-i infmt][-o outfmt] [file]\n");
| 224 |
quit(1);
| 225 |
| 226 |
if (otype != 'a')
| 227 |
SET_FILE_BINARY(stdout);
| 228 |
#ifdef getc_unlocked /* avoid lock/unlock overhead */
| 229 |
flockfile(stdout);
| 230 |
#endif
| 231 |
if (noinput) { /* produce a single output record */
| 232 |
if (i < argc) {
| 233 |
eputs(argv[0]);
| 234 |
eputs(": file argument(s) incompatible with -n\n");
| 235 |
quit(1);
| 236 |
| 237 |
eclock++;
| 238 |
putout();
| 239 |
quit(0);
| 240 |
| 241 |
if (blnkeq) /* for efficiency */
| 242 |
nbsynch();
| 243 |
| 244 |
if (i == argc) /* from stdin */
| 245 |
execute(NULL);
| 246 |
else /* from one or more files */
| 247 |
for ( ; i < argc; i++)
| 248 |
execute(argv[i]);
| 249 |
| 250 |
quit(0);
| 251 |
return 0; /* pro forma return */
| 252 |
| 253 |
| 254 |
| 255 |
static void
| 256 |
nbsynch(void) /* non-blank starting synch character */
| 257 |
| 258 |
if (inpfmt == NULL || (inpfmt->type & F_TYP) != T_LIT)
| 259 |
return;
| 260 |
while (isblnk(*inpfmt->f.sl))
| 261 |
inpfmt->f.sl++;
| 262 |
if (!*inpfmt->f.sl)
| 263 |
inpfmt = inpfmt->next;
| 264 |
| 265 |
| 266 |
| 267 |
static int
| 268 |
getinputrec( /* get next input record */
| 269 |
FILE *fp
| 270 |
| 271 |
| 272 |
if (inpfmt != NULL)
| 273 |
return(getrec());
| 274 |
if (tolower(itype) == 'd') {
| 275 |
if (fread(inpbuf, sizeof(double), nbicols, fp) != nbicols)
| 276 |
return(0);
| 277 |
if (itype == 'D')
| 278 |
swap64(inpbuf, nbicols);
| 279 |
return(1);
| 280 |
| 281 |
if (tolower(itype) == 'f') {
| 282 |
if (fread(inpbuf, sizeof(float), nbicols, fp) != nbicols)
| 283 |
return(0);
| 284 |
if (itype == 'F')
| 285 |
swap32(inpbuf, nbicols);
| 286 |
return(1);
| 287 |
| 288 |
return(fgets(inpbuf, INBSIZ, fp) != NULL);
| 289 |
| 290 |
| 291 |
| 292 |
static void
| 293 |
execute( /* process a file */
| 294 |
char *file
| 295 |
| 296 |
| 297 |
int conditional = vardefined("cond");
| 298 |
long nrecs = 0;
| 299 |
long nout = 0;
| 300 |
FILE *fp;
| 301 |
| 302 |
if (file == NULL)
| 303 |
fp = stdin;
| 304 |
else if ((fp = fopen(file, "r")) == NULL) {
| 305 |
eputs(file);
| 306 |
eputs(": cannot open\n");
| 307 |
quit(1);
| 308 |
| 309 |
if (itype != 'a')
| 310 |
SET_FILE_BINARY(fp);
| 311 |
| 312 |
flockfile(fp);
| 313 |
#endif
| 314 |
if (inpfmt != NULL)
| 315 |
initinp(fp);
| 316 |
| 317 |
while (getinputrec(fp)) {
| 318 |
varset("recno", '=', (double)++nrecs);
| 319 |
varset("outno", '=', (double)(nout+1));
| 320 |
colflg = 0;
| 321 |
eclock++;
| 322 |
if (!conditional || varvalue("cond") > 0.0) {
| 323 |
putout();
| 324 |
++nout;
| 325 |
| 326 |
| 327 |
fclose(fp);
| 328 |
| 329 |
| 330 |
| 331 |
static void
| 332 |
putout(void) /* produce an output record */
| 333 |
| 334 |
| 335 |
colpos = 0;
| 336 |
if (outfmt != NULL)
| 337 |
putrec();
| 338 |
else if (otype == 'a')
| 339 |
chanout(chanset);
| 340 |
else
| 341 |
chanout(bchanset);
| 342 |
if (colpos && otype == 'a')
| 343 |
putchar('\n');
| 344 |
if (unbuff)
| 345 |
fflush(stdout);
| 346 |
| 347 |
| 348 |
| 349 |
static double
| 350 |
l_in(char *funame) /* function call for $channel */
| 351 |
| 352 |
int n;
| 353 |
char *cp;
| 354 |
/* get argument as integer */
| 355 |
n = (int)(argument(1) + .5);
| 356 |
if (n != 0) /* return channel value */
| 357 |
return(chanvalue(n));
| 358 |
/* determine number of channels */
| 359 |
if (noinput || inpfmt != NULL)
| 360 |
return(0);
| 361 |
if (nbicols)
| 362 |
return(nbicols);
| 363 |
cp = inpbuf; /* need to count */
| 364 |
for (n = 0; *cp; )
| 365 |
if (blnkeq && isspace(sepchar)) {
| 366 |
while (isspace(*cp))
| 367 |
cp++;
| 368 |
n += *cp != '\0';
| 369 |
while (*cp && !isspace(*cp))
| 370 |
cp++;
| 371 |
} else {
| 372 |
n += *cp != '\n';
| 373 |
while (*cp && *cp++ != sepchar)
| 374 |
| 375 |
| 376 |
return(n);
| 377 |
| 378 |
| 379 |
double
| 380 |
chanvalue( /* return value for column n */
| 381 |
int n
| 382 |
| 383 |
| 384 |
int i;
| 385 |
char *cp;
| 386 |
| 387 |
if (noinput || inpfmt != NULL) {
| 388 |
eputs("no column input\n");
| 389 |
quit(1);
| 390 |
| 391 |
if (n < 1) {
| 392 |
eputs("illegal channel number\n");
| 393 |
quit(1);
| 394 |
| 395 |
if (nbicols) {
| 396 |
if (n > nbicols)
| 397 |
return(0.0);
| 398 |
| 399 |
cp = inpbuf + (n-1)*sizeof(double);
| 400 |
return(*(double *)cp);
| 401 |
| 402 |
cp = inpbuf + (n-1)*sizeof(float);
| 403 |
return(*(float *)cp);
| 404 |
| 405 |
if (n <= MAXCOL && colflg & 1L<<(n-1))
| 406 |
return(colval[n-1]);
| 407 |
| 408 |
cp = inpbuf;
| 409 |
for (i = 1; i < n; i++)
| 410 |
| 411 |
| 412 |
cp++;
| 413 |
| 414 |
cp++;
| 415 |
} else
| 416 |
| 417 |
| 418 |
| 419 |
while (isspace(*cp)) /* some atof()'s don't like tabs */
| 420 |
cp++;
| 421 |
| 422 |
if (n <= MAXCOL) {
| 423 |
colflg |= 1L<<(n-1);
| 424 |
return(colval[n-1] = atof(cp));
| 425 |
} else
| 426 |
return(atof(cp));
| 427 |
| 428 |
| 429 |
| 430 |
void
| 431 |
chanset( /* output column n */
| 432 |
int n,
| 433 |
double v
| 434 |
| 435 |
| 436 |
if (colpos == 0) /* no leading separator */
| 437 |
colpos = 1;
| 438 |
while (colpos < n) {
| 439 |
putchar(sepchar);
| 440 |
colpos++;
| 441 |
| 442 |
printf("%.9g", v);
| 443 |
| 444 |
| 445 |
| 446 |
void
| 447 |
bchanset( /* output binary channel n */
| 448 |
int n,
| 449 |
double v
| 450 |
| 451 |
| 452 |
static char zerobuf[sizeof(double)];
| 453 |
float fval = v;
| 454 |
| 455 |
while (++colpos < n)
| 456 |
fwrite(zerobuf,
| 457 |
tolower(otype)=='d' ? sizeof(double) : sizeof(float),
| 458 |
1, stdout);
| 459 |
switch (otype) {
| 460 |
case 'D':
| 461 |
swap64((char *)&v, 1);
| 462 |
/* fall through */
| 463 |
case 'd':
| 464 |
fwrite(&v, sizeof(double), 1, stdout);
| 465 |
break;
| 466 |
case 'F':
| 467 |
swap32((char *)&fval, 1);
| 468 |
/* fall through */
| 469 |
case 'f':
| 470 |
fwrite(&fval, sizeof(float), 1, stdout);
| 471 |
break;
| 472 |
| 473 |
| 474 |
| 475 |
| 476 |
static void
| 477 |
readfmt( /* read record format */
| 478 |
char *spec,
| 479 |
int output
| 480 |
| 481 |
| 482 |
int fd;
| 483 |
char *inptr;
| 484 |
struct field fmt;
| 485 |
int res;
| 486 |
struct field *f;
| 487 |
/* check for inline format */
| 488 |
for (inptr = spec; *inptr; inptr++)
| 489 |
if (*inptr == '$')
| 490 |
break;
| 491 |
if (*inptr) /* inline */
| 492 |
inptr = spec;
| 493 |
else { /* from file */
| 494 |
if ((fd = open(spec, 0)) == -1) {
| 495 |
eputs(spec);
| 496 |
| 497 |
quit(1);
| 498 |
| 499 |
res = read(fd, inpbuf+2, INBSIZ-2);
| 500 |
if (res <= 0 || res >= INBSIZ-1) {
| 501 |
eputs(spec);
| 502 |
if (res < 0)
| 503 |
eputs(": read error\n");
| 504 |
else if (res == 0)
| 505 |
eputs(": empty file\n");
| 506 |
else if (res >= INBSIZ-1)
| 507 |
eputs(": format too long\n");
| 508 |
quit(1);
| 509 |
| 510 |
close(fd);
| 511 |
(inptr=inpbuf+2)[res] = '\0';
| 512 |
| 513 |
f = &fmt; /* get fields */
| 514 |
while ((res = readfield(&inptr)) != F_NUL) {
| 515 |
f->next = (struct field *)emalloc(sizeof(struct field));
| 516 |
f = f->next;
| 517 |
f->type = res;
| 518 |
switch (res & F_TYP) {
| 519 |
case T_LIT:
| 520 |
f->f.sl = savqstr(inpbuf);
| 521 |
break;
| 522 |
case T_STR:
| 523 |
f->f.sv = getsvar(inpbuf);
| 524 |
break;
| 525 |
case T_NUM:
| 526 |
if (output)
| 527 |
f->f.ne = eparse(inpbuf);
| 528 |
else
| 529 |
f->f.nv = savestr(inpbuf);
| 530 |
break;
| 531 |
| 532 |
/* add final newline if necessary */
| 533 |
if (!igneol && *inptr == '\0' && inptr[-1] != '\n')
| 534 |
inptr = "\n";
| 535 |
| 536 |
f->next = NULL;
| 537 |
if (output)
| 538 |
outfmt = fmt.next;
| 539 |
else
| 540 |
inpfmt = fmt.next;
| 541 |
| 542 |
| 543 |
| 544 |
static int
| 545 |
readfield( /* get next field in format */
| 546 |
char **pp
| 547 |
| 548 |
| 549 |
int type = F_NUL;
| 550 |
int width = 0;
| 551 |
char *cp;
| 552 |
| 553 |
cp = inpbuf;
| 554 |
while (cp < &inpbuf[INBSIZ-1] && **pp != '\0') {
| 555 |
width++;
| 556 |
switch (type) {
| 557 |
case F_NUL:
| 558 |
if (**pp == '$') {
| 559 |
(*pp)++;
| 560 |
width++;
| 561 |
if (**pp == '{') {
| 562 |
type = T_NUM;
| 563 |
(*pp)++;
| 564 |
continue;
| 565 |
} else if (**pp == '(') {
| 566 |
type = T_STR;
| 567 |
(*pp)++;
| 568 |
continue;
| 569 |
} else if (**pp != '$') {
| 570 |
eputs("format error\n");
| 571 |
quit(1);
| 572 |
| 573 |
width--;
| 574 |
| 575 |
type = T_LIT;
| 576 |
*cp++ = *(*pp)++;
| 577 |
continue;
| 578 |
case T_LIT:
| 579 |
if (**pp == '$') {
| 580 |
width--;
| 581 |
break;
| 582 |
| 583 |
*cp++ = *(*pp)++;
| 584 |
continue;
| 585 |
case T_NUM:
| 586 |
if (**pp == '}') {
| 587 |
(*pp)++;
| 588 |
break;
| 589 |
| 590 |
if (!isspace(**pp))
| 591 |
*cp++ = **pp;
| 592 |
(*pp)++;
| 593 |
continue;
| 594 |
case T_STR:
| 595 |
if (**pp == ')') {
| 596 |
(*pp)++;
| 597 |
break;
| 598 |
| 599 |
if (!isspace(**pp))
| 600 |
*cp++ = **pp;
| 601 |
(*pp)++;
| 602 |
continue;
| 603 |
| 604 |
break;
| 605 |
| 606 |
*cp = '\0';
| 607 |
return(type | width);
| 608 |
| 609 |
| 610 |
| 611 |
struct strvar *
| 612 |
getsvar( /* get string variable */
| 613 |
char *svname
| 614 |
| 615 |
| 616 |
struct strvar *sv;
| 617 |
| 618 |
for (sv = svhead; sv != NULL; sv = sv->next)
| 619 |
if (!strcmp(sv->name, svname))
| 620 |
return(sv);
| 621 |
sv = (struct strvar *)emalloc(sizeof(struct strvar));
| 622 |
sv->name = savqstr(svname);
| 623 |
sv->val = sv->preset = NULL;
| 624 |
sv->next = svhead;
| 625 |
svhead = sv;
| 626 |
return(sv);
| 627 |
| 628 |
| 629 |
| 630 |
static void
| 631 |
svpreset( /* preset a string variable */
| 632 |
char *eqn
| 633 |
| 634 |
| 635 |
struct strvar *sv;
| 636 |
char *val;
| 637 |
| 638 |
for (val = eqn; *val != '='; val++)
| 639 |
if (!*val)
| 640 |
return;
| 641 |
*val++ = '\0';
| 642 |
sv = getsvar(eqn);
| 643 |
if (sv->preset != NULL)
| 644 |
freqstr(sv->preset);
| 645 |
if (sv->val != NULL)
| 646 |
freqstr(sv->val);
| 647 |
sv->val = sv->preset = savqstr(val);
| 648 |
*--val = '=';
| 649 |
| 650 |
| 651 |
| 652 |
static void
| 653 |
clearrec(void) /* clear input record variables */
| 654 |
| 655 |
struct field *f;
| 656 |
| 657 |
for (f = inpfmt; f != NULL; f = f->next)
| 658 |
switch (f->type & F_TYP) {
| 659 |
case T_NUM:
| 660 |
dremove(f->f.nv);
| 661 |
break;
| 662 |
case T_STR:
| 663 |
if (f->f.sv->val != f->f.sv->preset) {
| 664 |
freqstr(f->f.sv->val);
| 665 |
f->f.sv->val = f->f.sv->preset;
| 666 |
| 667 |
break;
| 668 |
| 669 |
| 670 |
| 671 |
| 672 |
static int
| 673 |
getrec(void) /* get next record from file */
| 674 |
| 675 |
int eatline;
| 676 |
struct field *f;
| 677 |
| 678 |
while (ipb.chr != EOF) {
| 679 |
if (blnkeq) { /* beware of nbsynch() */
| 680 |
while (isblnk(ipb.chr))
| 681 |
resetinp();
| 682 |
if (ipb.chr == EOF)
| 683 |
return(0);
| 684 |
| 685 |
eatline = (!igneol && ipb.chr != '\n');
| 686 |
clearrec(); /* start with fresh record */
| 687 |
| 688 |
if (getfield(f) == -1)
| 689 |
break;
| 690 |
if (f == NULL) {
| 691 |
advinp(); /* got one! */
| 692 |
return(1);
| 693 |
| 694 |
resetinp(); /* eat false start */
| 695 |
if (eatline) { /* eat rest of line */
| 696 |
while (ipb.chr != '\n') {
| 697 |
if (ipb.chr == EOF)
| 698 |
return(0);
| 699 |
resetinp();
| 700 |
| 701 |
resetinp();
| 702 |
| 703 |
| 704 |
return(0);
| 705 |
| 706 |
| 707 |
| 708 |
static int
| 709 |
getfield( /* get next field */
| 710 |
struct field *f
| 711 |
| 712 |
| 713 |
static char buf[RMAXWORD+1]; /* no recursion! */
| 714 |
int delim, inword;
| 715 |
double d;
| 716 |
char *np;
| 717 |
char *cp;
| 718 |
| 719 |
| 720 |
case T_LIT:
| 721 |
cp = f->f.sl;
| 722 |
do {
| 723 |
if (blnkeq && isblnk(*cp)) {
| 724 |
if (!isblnk(ipb.chr))
| 725 |
return(-1);
| 726 |
do
| 727 |
cp++;
| 728 |
while (isblnk(*cp));
| 729 |
do
| 730 |
scaninp();
| 731 |
while (isblnk(ipb.chr));
| 732 |
} else if (*cp == ipb.chr) {
| 733 |
cp++;
| 734 |
scaninp();
| 735 |
} else
| 736 |
return(-1);
| 737 |
} while (*cp);
| 738 |
return(0);
| 739 |
case T_STR:
| 740 |
if (f->next == NULL || (f->next->type & F_TYP) != T_LIT)
| 741 |
delim = EOF;
| 742 |
else
| 743 |
delim = f->next->f.sl[0];
| 744 |
cp = buf;
| 745 |
do {
| 746 |
if (ipb.chr == EOF || ipb.chr == '\n')
| 747 |
inword = 0;
| 748 |
else if (blnkeq && delim != EOF)
| 749 |
inword = isblnk(delim) ?
| 750 |
!isblnk(ipb.chr)
| 751 |
: ipb.chr != delim;
| 752 |
else
| 753 |
inword = cp-buf < (f->type & F_WID);
| 754 |
if (inword) {
| 755 |
*cp++ = ipb.chr;
| 756 |
scaninp();
| 757 |
| 758 |
} while (inword && cp < &buf[RMAXWORD]);
| 759 |
*cp = '\0';
| 760 |
if (f->f.sv->val == NULL)
| 761 |
f->f.sv->val = savqstr(buf); /* first setting */
| 762 |
else if (strcmp(f->f.sv->val, buf))
| 763 |
return(-1); /* doesn't match! */
| 764 |
return(0);
| 765 |
case T_NUM:
| 766 |
| 767 |
delim = EOF;
| 768 |
else
| 769 |
| 770 |
np = NULL;
| 771 |
cp = buf;
| 772 |
do {
| 773 |
if (!((np==NULL&&isblnk(ipb.chr)) || isnum(ipb.chr)))
| 774 |
inword = 0;
| 775 |
| 776 |
| 777 |
!isblnk(ipb.chr)
| 778 |
: ipb.chr != delim;
| 779 |
else
| 780 |
| 781 |
if (inword) {
| 782 |
if (np==NULL && !isblnk(ipb.chr))
| 783 |
np = cp;
| 784 |
*cp++ = ipb.chr;
| 785 |
scaninp();
| 786 |
| 787 |
| 788 |
*cp = '\0';
| 789 |
d = np==NULL ? 0. : atof(np);
| 790 |
if (!vardefined(f->f.nv))
| 791 |
varset(f->f.nv, '=', d); /* first setting */
| 792 |
else if ((d = (varvalue(f->f.nv)-d)/(d==0.?1.:d)) > .001
| 793 |
|| d < -.001)
| 794 |
| 795 |
return(0);
| 796 |
| 797 |
return -1; /* pro forma return */
| 798 |
| 799 |
| 800 |
| 801 |
static void
| 802 |
putrec(void) /* output a record */
| 803 |
| 804 |
char fmt[32], typ[16];
| 805 |
int n;
| 806 |
struct field *f;
| 807 |
int adlast, adnext;
| 808 |
double dv, av;
| 809 |
| 810 |
adlast = 0;
| 811 |
for (f = outfmt; f != NULL; f = f->next) {
| 812 |
adnext = blnkeq &&
| 813 |
f->next != NULL &&
| 814 |
!( (f->next->type&F_TYP) == T_LIT &&
| 815 |
f->next->f.sl[0] == ' ' );
| 816 |
| 817 |
case T_LIT:
| 818 |
fputs(f->f.sl, stdout);
| 819 |
adlast = f->f.sl[(f->type&F_WID)-1] != ' ';
| 820 |
break;
| 821 |
case T_STR:
| 822 |
if (f->f.sv->val == NULL) {
| 823 |
eputs(f->f.sv->name);
| 824 |
eputs(": undefined string\n");
| 825 |
quit(1);
| 826 |
| 827 |
n = (int)(f->type & F_WID) - strlen(f->f.sv->val);
| 828 |
if (adlast)
| 829 |
fputs(f->f.sv->val, stdout);
| 830 |
if (!(adlast && adnext))
| 831 |
while (n-- > 0)
| 832 |
putchar(' ');
| 833 |
if (!adlast)
| 834 |
| 835 |
adlast = 1;
| 836 |
break;
| 837 |
case T_NUM:
| 838 |
n = f->type & F_WID;
| 839 |
dv = evalue(f->f.ne);
| 840 |
av = fabs(dv);
| 841 |
if (n <= 9)
| 842 |
strcpy(typ, "g");
| 843 |
else
| 844 |
sprintf(typ, ".%de", n-5);
| 845 |
if (av < 1L<<31) {
| 846 |
long iv = (int)(av + .5);
| 847 |
if (iv && fabs(av-iv) <= av*1e-14)
| 848 |
strcpy(typ, ".0f");
| 849 |
| 850 |
if (adlast && adnext)
| 851 |
sprintf(fmt, "%%%s", typ);
| 852 |
else if (adlast)
| 853 |
sprintf(fmt, "%%-%d%s", n, typ);
| 854 |
else
| 855 |
sprintf(fmt, "%%%d%s", n, typ);
| 856 |
printf(fmt, dv);
| 857 |
adlast = 1;
| 858 |
break;
| 859 |
| 860 |
| 861 |
| 862 |
| 863 |
| 864 |
static void
| 865 |
initinp(FILE *fp) /* prepare lookahead buffer */
| 866 |
| 867 |
| 868 |
ipb.fin = fp;
| 869 |
ipb.beg = ipb.end = inpbuf;
| 870 |
ipb.pos = inpbuf-1; /* position before beginning */
| 871 |
ipb.chr = '\0';
| 872 |
scaninp();
| 873 |
| 874 |
| 875 |
| 876 |
static void
| 877 |
scaninp(void) /* scan next character */
| 878 |
| 879 |
if (ipb.chr == EOF)
| 880 |
return;
| 881 |
if (++ipb.pos >= &inpbuf[INBSIZ])
| 882 |
ipb.pos = inpbuf;
| 883 |
if (ipb.pos == ipb.end) { /* new character */
| 884 |
if ((ipb.chr = getc(ipb.fin)) != EOF) {
| 885 |
*ipb.end = ipb.chr;
| 886 |
if (++ipb.end >= &inpbuf[INBSIZ])
| 887 |
ipb.end = inpbuf;
| 888 |
if (ipb.end == ipb.beg)
| 889 |
ipb.beg = NULL;
| 890 |
| 891 |
} else
| 892 |
ipb.chr = *ipb.pos;
| 893 |
| 894 |
| 895 |
| 896 |
static void
| 897 |
advinp(void) /* move home to current position */
| 898 |
| 899 |
ipb.beg = ipb.pos;
| 900 |
| 901 |
| 902 |
| 903 |
static void
| 904 |
resetinp(void) /* rewind position and advance 1 */
| 905 |
| 906 |
if (ipb.beg == NULL) /* full */
| 907 |
ipb.beg = ipb.end;
| 908 |
ipb.pos = ipb.beg;
| 909 |
ipb.chr = *ipb.pos;
| 910 |
if (passive) /* transmit unmatched character? */
| 911 |
fputc(ipb.chr, stdout);
| 912 |
if (++ipb.beg >= &inpbuf[INBSIZ])
| 913 |
ipb.beg = inpbuf;
| 914 |
scaninp();
| 915 |
| 916 |
| 917 |
| 918 |
void
| 919 |
eputs(char *msg)
| 920 |
| 921 |
fputs(msg, stderr);
| 922 |
| 923 |
| 924 |
| 925 |
void
| 926 |
wputs(char *msg)
| 927 |
| 928 |
if (!nowarn)
| 929 |
eputs(msg);
| 930 |
| 931 |
| 932 |
| 933 |
void
| 934 |
quit(int code)
| 935 |
| 936 |
exit(code);
| 937 |
