root/radiance/ray/src/cal/rcalc.c
Sat May 10 01:48:14 2014 UTC (9 years, 11 months ago) by greg
Changes since 1.24: +8 -5 lines
Diff to previous 1.24 , to selected 1.7
Improvement on last change for many-digit numbers
Sat May 10 01:27:14 2014 UTC (9 years, 11 months ago) by greg
Changes since 1.23: +15 -6 lines
Diff to previous 1.23 , to selected 1.7
More adaptive handling of real output format (integers and high-precision)
Sun Mar 9 20:07:27 2014 UTC (10 years, 1 month ago) by greg
Changes since 1.22: +23 -18 lines
Diff to previous 1.22 , to selected 1.7
Added flockfile calls and fixed SET_FILE_BINARY usage for consistency
Thu Dec 19 16:38:12 2013 UTC (10 years, 4 months ago) by greg
Changes since 1.21: +11 -5 lines
Diff to previous 1.21 , to selected 1.7
Sun Jun 14 00:33:16 2009 UTC (14 years, 10 months ago) by greg
CVS Tags: rad4R0, rad4R1
Changes since 1.20: +3 -2 lines
Diff to previous 1.20 , to selected 1.7
Sat Dec 23 17:27:45 2006 UTC (17 years, 4 months ago) by greg
Changes since 1.19: +56 -38 lines
Diff to previous 1.19 , to selected 1.7
Tue Jun 14 01:25:02 2005 UTC (18 years, 10 months ago) by greg
Changes since 1.18: +5 -2 lines
Diff to previous 1.18 , to selected 1.7
Fixed bug in rcalc with -l option where it sometimes hung
Thu Jun 2 04:47:27 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.17: +9 -2 lines
Diff to previous 1.17 , to selected 1.7
Wed Feb 16 17:20:22 2005 UTC (19 years, 2 months ago) by greg
Changes since 1.16: +6 -1 lines
Diff to previous 1.16 , to selected 1.7
Added error check for files given with -n option
Fri Dec 10 05:52:14 2004 UTC (19 years, 4 months ago) by greg
Changes since 1.15: +2 -2 lines
Diff to previous 1.15 , to selected 1.7
Increased maximum input buffer size to 16 Kbytes
Thu Dec 9 22:09:40 2004 UTC (19 years, 4 months ago) by greg
Changes since 1.14: +2 -2 lines
Diff to previous 1.14 , to selected 1.7
Fixed bug for input lines containing only blanks
Mon Oct 11 10:02:15 2004 UTC (19 years, 6 months ago) by greg
Changes since 1.13: +4 -4 lines
Diff to previous 1.13 , to selected 1.7
Wed Jun 9 16:00:13 2004 UTC (19 years, 10 months ago) by greg
Changes since 1.12: +14 -9 lines
Diff to previous 1.12 , to selected 1.7
Changes since 1.11: +4 -2 lines
Diff to previous 1.11 , to selected 1.7
Fri Nov 14 17:31:24 2003 UTC (20 years, 5 months ago) by schorsch
Diff to previous 1.10 , to selected 1.7
Reduced compile warnings.
Thu Nov 6 05:39:33 2003 UTC (20 years, 5 months ago) by greg
Changes since 1.9: +37 -2 lines
Diff to previous 1.9 , to selected 1.7
Wed Nov 5 19:03:03 2003 UTC (20 years, 6 months ago) by greg
Changes since 1.8: +12 -2 lines
Diff to previous 1.8 , to selected 1.7
Added check for too many input columns for binary buffer
Fri Aug 1 14:14:23 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 1.7: +1 -5 lines
Diff to previous 1.7
Eliminated CPM, MAC, and UNIX conditional compiles.
Revision 1.7 - (view) (download) (annotate) - [selected]
Diff to previous 1.6
Thu Jul 3 22:41:44 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 1.5: +4 -4 lines
Sun Jun 8 12:03:09 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 1.4: +82 -51 lines
Sun May 25 05:27:16 2003 UTC (20 years, 11 months ago) by greg
Bug fix in latest change that caused newlines to disappear from output
Sun Apr 27 06:08:03 2003 UTC (21 years ago) by greg
Changes since 1.2: +97 -7 lines
Fri Feb 28 20:29:01 2003 UTC (21 years, 2 months ago) by greg
Removed redefinition warning to get back old rcalc behavior
Sat Feb 22 02:07:20 2003 UTC (21 years, 2 months ago) by greg
Diff to selected 1.7
