--- ray/src/cal/rcalc.c 2006/12/23 17:27:45 1.20 +++ ray/src/cal/rcalc.c 2014/03/09 20:07:27 1.23 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcalc.c,v 1.20 2006/12/23 17:27:45 greg Exp $"; +static const char RCSid[] = "$Id: rcalc.c,v 1.23 2014/03/09 20:07:27 greg Exp $"; #endif /* * rcalc.c - record calculator program. @@ -8,9 +8,6 @@ static const char RCSid[] = "$Id: rcalc.c,v 1.20 2006/ */ #include -#include -#include -#include #include #include @@ -107,6 +104,7 @@ int argc, char *argv[] ) { + char *fpath; int i; esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_OUTCHAN|E_RCONST; @@ -136,7 +134,15 @@ char *argv[] svpreset(argv[++i]); break; case 'f': - fcompile(argv[++i]); + fpath = getpath(argv[++i], getrlibpath(), 0); + if (fpath == NULL) { + eputs(argv[0]); + eputs(": cannot find file '"); + eputs(argv[i]); + eputs("'\n"); + quit(1); + } + fcompile(fpath); break; case 'e': scompile(argv[++i], NULL, 0); @@ -219,6 +225,9 @@ eputs(" [-b][-l][-n][-p][-w][-u][-tS][-s svar=sval][-e } if (otype != 'a') SET_FILE_BINARY(stdout); +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + flockfile(stdout); +#endif if (noinput) { /* produce a single output record */ if (i < argc) { eputs(argv[0]); @@ -229,9 +238,6 @@ eputs(" [-b][-l][-n][-p][-w][-u][-tS][-s svar=sval][-e putout(); quit(0); } - if (itype != 'a') - SET_FILE_BINARY(stdin); - if (blnkeq) /* for efficiency */ nbsynch(); @@ -300,16 +306,22 @@ char *file eputs(": cannot open\n"); quit(1); } + if (itype != 'a') + SET_FILE_BINARY(fp); +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + flockfile(fp); +#endif if (inpfmt != NULL) initinp(fp); while (getinputrec(fp)) { varset("recno", '=', (double)++nrecs); + varset("outno", '=', (double)(nout+1)); colflg = 0; eclock++; if (!conditional || varvalue("cond") > 0.0) { - varset("outno", '=', (double)++nout); putout(); + ++nout; } } fclose(fp); @@ -338,7 +350,7 @@ static double l_in(char *funame) /* function call for $channel */ { int n; - register char *cp; + char *cp; /* get argument as integer */ n = (int)(argument(1) + .5); if (n != 0) /* return channel value */ @@ -370,7 +382,7 @@ int n ) { int i; - register char *cp; + char *cp; if (noinput || inpfmt != NULL) { eputs("no column input\n"); @@ -471,7 +483,7 @@ int output char *inptr; struct field fmt; int res; - register struct field *f; + struct field *f; /* check for inline format */ for (inptr = spec; *inptr; inptr++) if (*inptr == '$') @@ -531,12 +543,12 @@ int output static int readfield( /* get next field in format */ -register char **pp +char **pp ) { int type = F_NUL; int width = 0; - register char *cp; + char *cp; cp = inpbuf; while (cp < &inpbuf[INBSIZ-1] && **pp != '\0') { @@ -601,7 +613,7 @@ getsvar( /* get string variabl char *svname ) { - register struct strvar *sv; + struct strvar *sv; for (sv = svhead; sv != NULL; sv = sv->next) if (!strcmp(sv->name, svname)) @@ -620,8 +632,8 @@ svpreset( /* preset a string variab char *eqn ) { - register struct strvar *sv; - register char *val; + struct strvar *sv; + char *val; for (val = eqn; *val != '='; val++) if (!*val) @@ -640,7 +652,7 @@ char *eqn static void clearrec(void) /* clear input record variables */ { - register struct field *f; + struct field *f; for (f = inpfmt; f != NULL; f = f->next) switch (f->type & F_TYP) { @@ -661,7 +673,7 @@ static int getrec(void) /* get next record from file */ { int eatline; - register struct field *f; + struct field *f; while (ipb.chr != EOF) { if (blnkeq) { /* beware of nbsynch() */ @@ -695,14 +707,14 @@ getrec(void) /* get next record from file */ static int getfield( /* get next field */ -register struct field *f +struct field *f ) { static char buf[RMAXWORD+1]; /* no recursion! */ int delim, inword; double d; char *np; - register char *cp; + char *cp; switch (f->type & F_TYP) { case T_LIT: @@ -790,8 +802,8 @@ static void putrec(void) /* output a record */ { char fmt[32]; - register int n; - register struct field *f; + int n; + struct field *f; int adlast, adnext; adlast = 0;
