| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rcalc.c,v 1.20 2006/12/23 17:27:45 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rcalc.c - record calculator program.
| 6 |
| 7 |
* 9/11/87
| 8 |
| 9 |
| 10 |
#include <stdlib.h>
| 11 |
#include <fcntl.h>
| 12 |
#include <stdio.h>
| 13 |
#include <string.h>
| 14 |
#include <math.h>
| 15 |
#include <ctype.h>
| 16 |
| 17 |
#include "platform.h"
| 18 |
#include "rterror.h"
| 19 |
#include "rtmisc.h"
| 20 |
#include "rtio.h"
| 21 |
#include "calcomp.h"
| 22 |
| 23 |
#define isnum(c) (isdigit(c) || (c)=='-' || (c)=='.' \
| 24 |
|| (c)=='+' || (c)=='e' || (c)=='E')
| 25 |
| 26 |
#define isblnk(c) (igneol ? isspace(c) : (c)==' '||(c)=='\t')
| 27 |
| 28 |
#define INBSIZ 16384 /* longest record */
| 29 |
#define MAXCOL 32 /* number of columns recorded */
| 30 |
| 31 |
/* field type specifications */
| 32 |
#define F_NUL 0 /* empty */
| 33 |
#define F_TYP 0x7000 /* mask for type */
| 34 |
#define F_WID 0x0fff /* mask for width */
| 35 |
#define T_LIT 0x1000 /* string literal */
| 36 |
#define T_STR 0x2000 /* string variable */
| 37 |
#define T_NUM 0x3000 /* numeric value */
| 38 |
| 39 |
struct strvar { /* string variable */
| 40 |
char *name;
| 41 |
char *val;
| 42 |
char *preset;
| 43 |
struct strvar *next;
| 44 |
| 45 |
| 46 |
struct field { /* record format structure */
| 47 |
int type; /* type of field (& width) */
| 48 |
union {
| 49 |
char *sl; /* string literal */
| 50 |
struct strvar *sv; /* string variable */
| 51 |
char *nv; /* numeric variable */
| 52 |
EPNODE *ne; /* numeric expression */
| 53 |
} f; /* field contents */
| 54 |
struct field *next; /* next field in record */
| 55 |
| 56 |
| 57 |
#define savqstr(s) strcpy(emalloc(strlen(s)+1),s)
| 58 |
#define freqstr(s) efree(s)
| 59 |
| 60 |
static int getinputrec(FILE *fp);
| 61 |
static void scaninp(void), advinp(void), resetinp(void);
| 62 |
static void putrec(void), putout(void), nbsynch(void);
| 63 |
static int getrec(void);
| 64 |
static void execute(char *file);
| 65 |
static void initinp(FILE *fp);
| 66 |
static void svpreset(char *eqn);
| 67 |
static void readfmt(char *spec, int output);
| 68 |
static int readfield(char **pp);
| 69 |
static int getfield(struct field *f);
| 70 |
static void chanset(int n, double v);
| 71 |
static void bchanset(int n, double v);
| 72 |
static struct strvar* getsvar(char *svname);
| 73 |
static double l_in(char *);
| 74 |
| 75 |
struct field *inpfmt = NULL; /* input record format */
| 76 |
struct field *outfmt = NULL; /* output record structure */
| 77 |
struct strvar *svhead = NULL; /* string variables */
| 78 |
| 79 |
int blnkeq = 1; /* blanks compare equal? */
| 80 |
int igneol = 0; /* ignore end of line? */
| 81 |
int passive = 0; /* passive mode (transmit unmatched input) */
| 82 |
char sepchar = '\t'; /* input/output separator */
| 83 |
int noinput = 0; /* no input records? */
| 84 |
int itype = 'a'; /* input type (a/f/F/d/D) */
| 85 |
int nbicols = 0; /* number of binary input columns */
| 86 |
int otype = 'a'; /* output format (a/f/F/d/D) */
| 87 |
char inpbuf[INBSIZ]; /* input buffer */
| 88 |
double colval[MAXCOL]; /* input column values */
| 89 |
unsigned long colflg = 0; /* column retrieved flags */
| 90 |
int colpos; /* output column position */
| 91 |
| 92 |
int nowarn = 0; /* non-fatal diagnostic output */
| 93 |
int unbuff = 0; /* unbuffered output (flush each record) */
| 94 |
| 95 |
struct {
| 96 |
FILE *fin; /* input file */
| 97 |
int chr; /* next character */
| 98 |
char *beg; /* home position */
| 99 |
char *pos; /* scan position */
| 100 |
char *end; /* read position */
| 101 |
} ipb; /* circular lookahead buffer */
| 102 |
| 103 |
| 104 |
int
| 105 |
main(
| 106 |
int argc,
| 107 |
char *argv[]
| 108 |
| 109 |
| 110 |
int i;
| 111 |
| 112 |
esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_OUTCHAN|E_RCONST;
| 113 |
esupport &= ~(E_REDEFW);
| 114 |
| 115 |
#ifdef BIGGERLIB
| 116 |
biggerlib();
| 117 |
#endif
| 118 |
varset("PI", ':', 3.14159265358979323846);
| 119 |
funset("in", 1, '=', &l_in);
| 120 |
| 121 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 122 |
switch (argv[i][1]) {
| 123 |
case 'b':
| 124 |
blnkeq = !blnkeq;
| 125 |
break;
| 126 |
case 'l':
| 127 |
igneol = !igneol;
| 128 |
break;
| 129 |
case 'p':
| 130 |
passive = !passive;
| 131 |
break;
| 132 |
case 't':
| 133 |
sepchar = argv[i][2];
| 134 |
break;
| 135 |
case 's':
| 136 |
svpreset(argv[++i]);
| 137 |
break;
| 138 |
case 'f':
| 139 |
fcompile(argv[++i]);
| 140 |
break;
| 141 |
case 'e':
| 142 |
scompile(argv[++i], NULL, 0);
| 143 |
break;
| 144 |
case 'n':
| 145 |
noinput = 1;
| 146 |
break;
| 147 |
case 'i':
| 148 |
switch (argv[i][2]) {
| 149 |
case '\0':
| 150 |
itype = 'a';
| 151 |
nbicols = 0;
| 152 |
readfmt(argv[++i], 0);
| 153 |
break;
| 154 |
case 'a':
| 155 |
itype = 'a';
| 156 |
nbicols = 0;
| 157 |
break;
| 158 |
case 'd':
| 159 |
case 'D':
| 160 |
itype = argv[i][2];
| 161 |
if (isdigit(argv[i][3]))
| 162 |
nbicols = atoi(argv[i]+3);
| 163 |
else
| 164 |
nbicols = 1;
| 165 |
if (nbicols*sizeof(double) > INBSIZ) {
| 166 |
eputs(argv[0]);
| 167 |
eputs(": too many input columns\n");
| 168 |
quit(1);
| 169 |
| 170 |
break;
| 171 |
case 'f':
| 172 |
case 'F':
| 173 |
itype = argv[i][2];
| 174 |
| 175 |
| 176 |
else
| 177 |
nbicols = 1;
| 178 |
if (nbicols*sizeof(float) > INBSIZ) {
| 179 |
eputs(argv[0]);
| 180 |
| 181 |
quit(1);
| 182 |
| 183 |
break;
| 184 |
default:
| 185 |
goto userr;
| 186 |
| 187 |
break;
| 188 |
case 'o':
| 189 |
| 190 |
case '\0':
| 191 |
otype = 'a';
| 192 |
readfmt(argv[++i], 1);
| 193 |
break;
| 194 |
case 'a':
| 195 |
otype = 'a';
| 196 |
break;
| 197 |
case 'd':
| 198 |
case 'D':
| 199 |
case 'f':
| 200 |
case 'F':
| 201 |
otype = argv[i][2];
| 202 |
break;
| 203 |
default:
| 204 |
goto userr;
| 205 |
| 206 |
break;
| 207 |
case 'w':
| 208 |
nowarn = !nowarn;
| 209 |
break;
| 210 |
case 'u':
| 211 |
unbuff = !unbuff;
| 212 |
break;
| 213 |
default:;
| 214 |
userr:
| 215 |
eputs("Usage: ");
| 216 |
eputs(argv[0]);
| 217 |
eputs(" [-b][-l][-n][-p][-w][-u][-tS][-s svar=sval][-e expr][-f source][-i infmt][-o outfmt] [file]\n");
| 218 |
quit(1);
| 219 |
| 220 |
if (otype != 'a')
| 221 |
SET_FILE_BINARY(stdout);
| 222 |
if (noinput) { /* produce a single output record */
| 223 |
if (i < argc) {
| 224 |
eputs(argv[0]);
| 225 |
eputs(": file argument(s) incompatible with -n\n");
| 226 |
quit(1);
| 227 |
| 228 |
eclock++;
| 229 |
putout();
| 230 |
quit(0);
| 231 |
| 232 |
if (itype != 'a')
| 233 |
SET_FILE_BINARY(stdin);
| 234 |
| 235 |
if (blnkeq) /* for efficiency */
| 236 |
nbsynch();
| 237 |
| 238 |
if (i == argc) /* from stdin */
| 239 |
execute(NULL);
| 240 |
else /* from one or more files */
| 241 |
for ( ; i < argc; i++)
| 242 |
execute(argv[i]);
| 243 |
| 244 |
quit(0);
| 245 |
return 0; /* pro forma return */
| 246 |
| 247 |
| 248 |
| 249 |
static void
| 250 |
nbsynch(void) /* non-blank starting synch character */
| 251 |
| 252 |
if (inpfmt == NULL || (inpfmt->type & F_TYP) != T_LIT)
| 253 |
return;
| 254 |
while (isblnk(*inpfmt->f.sl))
| 255 |
inpfmt->f.sl++;
| 256 |
if (!*inpfmt->f.sl)
| 257 |
inpfmt = inpfmt->next;
| 258 |
| 259 |
| 260 |
| 261 |
static int
| 262 |
getinputrec( /* get next input record */
| 263 |
FILE *fp
| 264 |
| 265 |
| 266 |
if (inpfmt != NULL)
| 267 |
return(getrec());
| 268 |
if (tolower(itype) == 'd') {
| 269 |
if (fread(inpbuf, sizeof(double), nbicols, fp) != nbicols)
| 270 |
return(0);
| 271 |
if (itype == 'D')
| 272 |
swap64(inpbuf, nbicols);
| 273 |
return(1);
| 274 |
| 275 |
if (tolower(itype) == 'f') {
| 276 |
if (fread(inpbuf, sizeof(float), nbicols, fp) != nbicols)
| 277 |
return(0);
| 278 |
if (itype == 'F')
| 279 |
swap32(inpbuf, nbicols);
| 280 |
return(1);
| 281 |
| 282 |
return(fgets(inpbuf, INBSIZ, fp) != NULL);
| 283 |
| 284 |
| 285 |
| 286 |
static void
| 287 |
execute( /* process a file */
| 288 |
char *file
| 289 |
| 290 |
| 291 |
int conditional = vardefined("cond");
| 292 |
long nrecs = 0;
| 293 |
long nout = 0;
| 294 |
FILE *fp;
| 295 |
| 296 |
if (file == NULL)
| 297 |
fp = stdin;
| 298 |
else if ((fp = fopen(file, "r")) == NULL) {
| 299 |
eputs(file);
| 300 |
eputs(": cannot open\n");
| 301 |
quit(1);
| 302 |
| 303 |
if (inpfmt != NULL)
| 304 |
initinp(fp);
| 305 |
| 306 |
while (getinputrec(fp)) {
| 307 |
varset("recno", '=', (double)++nrecs);
| 308 |
varset("outno", '=', (double)(nout+1));
| 309 |
colflg = 0;
| 310 |
eclock++;
| 311 |
if (!conditional || varvalue("cond") > 0.0) {
| 312 |
putout();
| 313 |
++nout;
| 314 |
| 315 |
| 316 |
fclose(fp);
| 317 |
| 318 |
| 319 |
| 320 |
static void
| 321 |
putout(void) /* produce an output record */
| 322 |
| 323 |
| 324 |
colpos = 0;
| 325 |
if (outfmt != NULL)
| 326 |
putrec();
| 327 |
else if (otype == 'a')
| 328 |
chanout(chanset);
| 329 |
else
| 330 |
chanout(bchanset);
| 331 |
if (colpos && otype == 'a')
| 332 |
putchar('\n');
| 333 |
if (unbuff)
| 334 |
fflush(stdout);
| 335 |
| 336 |
| 337 |
| 338 |
static double
| 339 |
l_in(char *funame) /* function call for $channel */
| 340 |
| 341 |
int n;
| 342 |
register char *cp;
| 343 |
/* get argument as integer */
| 344 |
n = (int)(argument(1) + .5);
| 345 |
if (n != 0) /* return channel value */
| 346 |
return(chanvalue(n));
| 347 |
/* determine number of channels */
| 348 |
if (noinput || inpfmt != NULL)
| 349 |
return(0);
| 350 |
if (nbicols)
| 351 |
return(nbicols);
| 352 |
cp = inpbuf; /* need to count */
| 353 |
for (n = 0; *cp; )
| 354 |
if (blnkeq && isspace(sepchar)) {
| 355 |
while (isspace(*cp))
| 356 |
cp++;
| 357 |
n += *cp != '\0';
| 358 |
while (*cp && !isspace(*cp))
| 359 |
cp++;
| 360 |
} else {
| 361 |
n += *cp != '\n';
| 362 |
while (*cp && *cp++ != sepchar)
| 363 |
| 364 |
| 365 |
return(n);
| 366 |
| 367 |
| 368 |
double
| 369 |
chanvalue( /* return value for column n */
| 370 |
int n
| 371 |
| 372 |
| 373 |
int i;
| 374 |
register char *cp;
| 375 |
| 376 |
if (noinput || inpfmt != NULL) {
| 377 |
eputs("no column input\n");
| 378 |
quit(1);
| 379 |
| 380 |
if (n < 1) {
| 381 |
eputs("illegal channel number\n");
| 382 |
quit(1);
| 383 |
| 384 |
if (nbicols) {
| 385 |
if (n > nbicols)
| 386 |
return(0.0);
| 387 |
| 388 |
cp = inpbuf + (n-1)*sizeof(double);
| 389 |
return(*(double *)cp);
| 390 |
| 391 |
cp = inpbuf + (n-1)*sizeof(float);
| 392 |
return(*(float *)cp);
| 393 |
| 394 |
if (n <= MAXCOL && colflg & 1L<<(n-1))
| 395 |
return(colval[n-1]);
| 396 |
| 397 |
cp = inpbuf;
| 398 |
for (i = 1; i < n; i++)
| 399 |
| 400 |
| 401 |
cp++;
| 402 |
| 403 |
cp++;
| 404 |
} else
| 405 |
| 406 |
| 407 |
| 408 |
while (isspace(*cp)) /* some atof()'s don't like tabs */
| 409 |
cp++;
| 410 |
| 411 |
if (n <= MAXCOL) {
| 412 |
colflg |= 1L<<(n-1);
| 413 |
return(colval[n-1] = atof(cp));
| 414 |
} else
| 415 |
return(atof(cp));
| 416 |
| 417 |
| 418 |
| 419 |
void
| 420 |
chanset( /* output column n */
| 421 |
int n,
| 422 |
double v
| 423 |
| 424 |
| 425 |
if (colpos == 0) /* no leading separator */
| 426 |
colpos = 1;
| 427 |
while (colpos < n) {
| 428 |
putchar(sepchar);
| 429 |
colpos++;
| 430 |
| 431 |
printf("%.9g", v);
| 432 |
| 433 |
| 434 |
| 435 |
void
| 436 |
bchanset( /* output binary channel n */
| 437 |
int n,
| 438 |
double v
| 439 |
| 440 |
| 441 |
static char zerobuf[sizeof(double)];
| 442 |
float fval = v;
| 443 |
| 444 |
while (++colpos < n)
| 445 |
fwrite(zerobuf,
| 446 |
tolower(otype)=='d' ? sizeof(double) : sizeof(float),
| 447 |
1, stdout);
| 448 |
switch (otype) {
| 449 |
case 'D':
| 450 |
swap64((char *)&v, 1);
| 451 |
/* fall through */
| 452 |
case 'd':
| 453 |
fwrite(&v, sizeof(double), 1, stdout);
| 454 |
break;
| 455 |
case 'F':
| 456 |
swap32((char *)&fval, 1);
| 457 |
/* fall through */
| 458 |
case 'f':
| 459 |
fwrite(&fval, sizeof(float), 1, stdout);
| 460 |
break;
| 461 |
| 462 |
| 463 |
| 464 |
| 465 |
static void
| 466 |
readfmt( /* read record format */
| 467 |
char *spec,
| 468 |
int output
| 469 |
| 470 |
| 471 |
int fd;
| 472 |
char *inptr;
| 473 |
struct field fmt;
| 474 |
int res;
| 475 |
register struct field *f;
| 476 |
/* check for inline format */
| 477 |
for (inptr = spec; *inptr; inptr++)
| 478 |
if (*inptr == '$')
| 479 |
break;
| 480 |
if (*inptr) /* inline */
| 481 |
inptr = spec;
| 482 |
else { /* from file */
| 483 |
if ((fd = open(spec, 0)) == -1) {
| 484 |
eputs(spec);
| 485 |
| 486 |
quit(1);
| 487 |
| 488 |
res = read(fd, inpbuf+2, INBSIZ-2);
| 489 |
if (res <= 0 || res >= INBSIZ-1) {
| 490 |
eputs(spec);
| 491 |
if (res < 0)
| 492 |
eputs(": read error\n");
| 493 |
else if (res == 0)
| 494 |
eputs(": empty file\n");
| 495 |
else if (res >= INBSIZ-1)
| 496 |
eputs(": format too long\n");
| 497 |
quit(1);
| 498 |
| 499 |
close(fd);
| 500 |
(inptr=inpbuf+2)[res] = '\0';
| 501 |
| 502 |
f = &fmt; /* get fields */
| 503 |
while ((res = readfield(&inptr)) != F_NUL) {
| 504 |
f->next = (struct field *)emalloc(sizeof(struct field));
| 505 |
f = f->next;
| 506 |
f->type = res;
| 507 |
switch (res & F_TYP) {
| 508 |
case T_LIT:
| 509 |
f->f.sl = savqstr(inpbuf);
| 510 |
break;
| 511 |
case T_STR:
| 512 |
f->f.sv = getsvar(inpbuf);
| 513 |
break;
| 514 |
case T_NUM:
| 515 |
if (output)
| 516 |
f->f.ne = eparse(inpbuf);
| 517 |
else
| 518 |
f->f.nv = savestr(inpbuf);
| 519 |
break;
| 520 |
| 521 |
/* add final newline if necessary */
| 522 |
if (!igneol && *inptr == '\0' && inptr[-1] != '\n')
| 523 |
inptr = "\n";
| 524 |
| 525 |
f->next = NULL;
| 526 |
if (output)
| 527 |
outfmt = fmt.next;
| 528 |
else
| 529 |
inpfmt = fmt.next;
| 530 |
| 531 |
| 532 |
| 533 |
static int
| 534 |
readfield( /* get next field in format */
| 535 |
register char **pp
| 536 |
| 537 |
| 538 |
int type = F_NUL;
| 539 |
int width = 0;
| 540 |
register char *cp;
| 541 |
| 542 |
cp = inpbuf;
| 543 |
while (cp < &inpbuf[INBSIZ-1] && **pp != '\0') {
| 544 |
width++;
| 545 |
switch (type) {
| 546 |
case F_NUL:
| 547 |
if (**pp == '$') {
| 548 |
(*pp)++;
| 549 |
width++;
| 550 |
if (**pp == '{') {
| 551 |
type = T_NUM;
| 552 |
(*pp)++;
| 553 |
continue;
| 554 |
} else if (**pp == '(') {
| 555 |
type = T_STR;
| 556 |
(*pp)++;
| 557 |
continue;
| 558 |
} else if (**pp != '$') {
| 559 |
eputs("format error\n");
| 560 |
quit(1);
| 561 |
| 562 |
width--;
| 563 |
| 564 |
type = T_LIT;
| 565 |
*cp++ = *(*pp)++;
| 566 |
continue;
| 567 |
case T_LIT:
| 568 |
if (**pp == '$') {
| 569 |
width--;
| 570 |
break;
| 571 |
| 572 |
*cp++ = *(*pp)++;
| 573 |
continue;
| 574 |
case T_NUM:
| 575 |
if (**pp == '}') {
| 576 |
(*pp)++;
| 577 |
break;
| 578 |
| 579 |
if (!isspace(**pp))
| 580 |
*cp++ = **pp;
| 581 |
(*pp)++;
| 582 |
continue;
| 583 |
case T_STR:
| 584 |
if (**pp == ')') {
| 585 |
(*pp)++;
| 586 |
break;
| 587 |
| 588 |
if (!isspace(**pp))
| 589 |
*cp++ = **pp;
| 590 |
(*pp)++;
| 591 |
continue;
| 592 |
| 593 |
break;
| 594 |
| 595 |
*cp = '\0';
| 596 |
return(type | width);
| 597 |
| 598 |
| 599 |
| 600 |
struct strvar *
| 601 |
getsvar( /* get string variable */
| 602 |
char *svname
| 603 |
| 604 |
| 605 |
register struct strvar *sv;
| 606 |
| 607 |
for (sv = svhead; sv != NULL; sv = sv->next)
| 608 |
if (!strcmp(sv->name, svname))
| 609 |
return(sv);
| 610 |
sv = (struct strvar *)emalloc(sizeof(struct strvar));
| 611 |
sv->name = savqstr(svname);
| 612 |
sv->val = sv->preset = NULL;
| 613 |
sv->next = svhead;
| 614 |
svhead = sv;
| 615 |
return(sv);
| 616 |
| 617 |
| 618 |
| 619 |
static void
| 620 |
svpreset( /* preset a string variable */
| 621 |
char *eqn
| 622 |
| 623 |
| 624 |
| 625 |
register char *val;
| 626 |
| 627 |
for (val = eqn; *val != '='; val++)
| 628 |
if (!*val)
| 629 |
return;
| 630 |
*val++ = '\0';
| 631 |
sv = getsvar(eqn);
| 632 |
if (sv->preset != NULL)
| 633 |
freqstr(sv->preset);
| 634 |
if (sv->val != NULL)
| 635 |
freqstr(sv->val);
| 636 |
sv->val = sv->preset = savqstr(val);
| 637 |
*--val = '=';
| 638 |
| 639 |
| 640 |
| 641 |
static void
| 642 |
clearrec(void) /* clear input record variables */
| 643 |
| 644 |
| 645 |
| 646 |
for (f = inpfmt; f != NULL; f = f->next)
| 647 |
switch (f->type & F_TYP) {
| 648 |
case T_NUM:
| 649 |
dremove(f->f.nv);
| 650 |
break;
| 651 |
case T_STR:
| 652 |
if (f->f.sv->val != f->f.sv->preset) {
| 653 |
freqstr(f->f.sv->val);
| 654 |
f->f.sv->val = f->f.sv->preset;
| 655 |
| 656 |
break;
| 657 |
| 658 |
| 659 |
| 660 |
| 661 |
static int
| 662 |
getrec(void) /* get next record from file */
| 663 |
| 664 |
int eatline;
| 665 |
| 666 |
| 667 |
while (ipb.chr != EOF) {
| 668 |
if (blnkeq) { /* beware of nbsynch() */
| 669 |
while (isblnk(ipb.chr))
| 670 |
resetinp();
| 671 |
if (ipb.chr == EOF)
| 672 |
return(0);
| 673 |
| 674 |
eatline = (!igneol && ipb.chr != '\n');
| 675 |
clearrec(); /* start with fresh record */
| 676 |
| 677 |
if (getfield(f) == -1)
| 678 |
break;
| 679 |
if (f == NULL) {
| 680 |
advinp(); /* got one! */
| 681 |
return(1);
| 682 |
| 683 |
resetinp(); /* eat false start */
| 684 |
if (eatline) { /* eat rest of line */
| 685 |
while (ipb.chr != '\n') {
| 686 |
if (ipb.chr == EOF)
| 687 |
return(0);
| 688 |
resetinp();
| 689 |
| 690 |
resetinp();
| 691 |
| 692 |
| 693 |
return(0);
| 694 |
| 695 |
| 696 |
| 697 |
static int
| 698 |
getfield( /* get next field */
| 699 |
| 700 |
| 701 |
| 702 |
static char buf[RMAXWORD+1]; /* no recursion! */
| 703 |
int delim, inword;
| 704 |
double d;
| 705 |
char *np;
| 706 |
register char *cp;
| 707 |
| 708 |
| 709 |
case T_LIT:
| 710 |
cp = f->f.sl;
| 711 |
do {
| 712 |
if (blnkeq && isblnk(*cp)) {
| 713 |
if (!isblnk(ipb.chr))
| 714 |
return(-1);
| 715 |
do
| 716 |
cp++;
| 717 |
while (isblnk(*cp));
| 718 |
do
| 719 |
scaninp();
| 720 |
while (isblnk(ipb.chr));
| 721 |
} else if (*cp == ipb.chr) {
| 722 |
cp++;
| 723 |
scaninp();
| 724 |
} else
| 725 |
return(-1);
| 726 |
} while (*cp);
| 727 |
return(0);
| 728 |
case T_STR:
| 729 |
if (f->next == NULL || (f->next->type & F_TYP) != T_LIT)
| 730 |
delim = EOF;
| 731 |
else
| 732 |
delim = f->next->f.sl[0];
| 733 |
cp = buf;
| 734 |
do {
| 735 |
if (ipb.chr == EOF || ipb.chr == '\n')
| 736 |
inword = 0;
| 737 |
else if (blnkeq && delim != EOF)
| 738 |
inword = isblnk(delim) ?
| 739 |
!isblnk(ipb.chr)
| 740 |
: ipb.chr != delim;
| 741 |
else
| 742 |
inword = cp-buf < (f->type & F_WID);
| 743 |
if (inword) {
| 744 |
*cp++ = ipb.chr;
| 745 |
scaninp();
| 746 |
| 747 |
} while (inword && cp < &buf[RMAXWORD]);
| 748 |
*cp = '\0';
| 749 |
if (f->f.sv->val == NULL)
| 750 |
f->f.sv->val = savqstr(buf); /* first setting */
| 751 |
else if (strcmp(f->f.sv->val, buf))
| 752 |
return(-1); /* doesn't match! */
| 753 |
return(0);
| 754 |
case T_NUM:
| 755 |
| 756 |
delim = EOF;
| 757 |
else
| 758 |
| 759 |
np = NULL;
| 760 |
cp = buf;
| 761 |
do {
| 762 |
if (!((np==NULL&&isblnk(ipb.chr)) || isnum(ipb.chr)))
| 763 |
inword = 0;
| 764 |
| 765 |
| 766 |
!isblnk(ipb.chr)
| 767 |
: ipb.chr != delim;
| 768 |
else
| 769 |
| 770 |
if (inword) {
| 771 |
if (np==NULL && !isblnk(ipb.chr))
| 772 |
np = cp;
| 773 |
*cp++ = ipb.chr;
| 774 |
scaninp();
| 775 |
| 776 |
| 777 |
*cp = '\0';
| 778 |
d = np==NULL ? 0. : atof(np);
| 779 |
if (!vardefined(f->f.nv))
| 780 |
varset(f->f.nv, '=', d); /* first setting */
| 781 |
else if ((d = (varvalue(f->f.nv)-d)/(d==0.?1.:d)) > .001
| 782 |
|| d < -.001)
| 783 |
| 784 |
return(0);
| 785 |
| 786 |
return -1; /* pro forma return */
| 787 |
| 788 |
| 789 |
| 790 |
static void
| 791 |
putrec(void) /* output a record */
| 792 |
| 793 |
char fmt[32];
| 794 |
register int n;
| 795 |
| 796 |
int adlast, adnext;
| 797 |
| 798 |
adlast = 0;
| 799 |
for (f = outfmt; f != NULL; f = f->next) {
| 800 |
adnext = blnkeq &&
| 801 |
f->next != NULL &&
| 802 |
!( (f->next->type&F_TYP) == T_LIT &&
| 803 |
f->next->f.sl[0] == ' ' );
| 804 |
| 805 |
case T_LIT:
| 806 |
fputs(f->f.sl, stdout);
| 807 |
adlast = f->f.sl[(f->type&F_WID)-1] != ' ';
| 808 |
break;
| 809 |
case T_STR:
| 810 |
if (f->f.sv->val == NULL) {
| 811 |
eputs(f->f.sv->name);
| 812 |
eputs(": undefined string\n");
| 813 |
quit(1);
| 814 |
| 815 |
n = (int)(f->type & F_WID) - strlen(f->f.sv->val);
| 816 |
if (adlast)
| 817 |
fputs(f->f.sv->val, stdout);
| 818 |
if (!(adlast && adnext))
| 819 |
while (n-- > 0)
| 820 |
putchar(' ');
| 821 |
if (!adlast)
| 822 |
| 823 |
adlast = 1;
| 824 |
break;
| 825 |
case T_NUM:
| 826 |
n = f->type & F_WID;
| 827 |
if (adlast && adnext)
| 828 |
strcpy(fmt, "%g");
| 829 |
else if (adlast)
| 830 |
sprintf(fmt, "%%-%dg", n);
| 831 |
else
| 832 |
sprintf(fmt, "%%%dg", n);
| 833 |
printf(fmt, evalue(f->f.ne));
| 834 |
adlast = 1;
| 835 |
break;
| 836 |
| 837 |
| 838 |
| 839 |
| 840 |
| 841 |
static void
| 842 |
initinp(FILE *fp) /* prepare lookahead buffer */
| 843 |
| 844 |
| 845 |
ipb.fin = fp;
| 846 |
ipb.beg = ipb.end = inpbuf;
| 847 |
ipb.pos = inpbuf-1; /* position before beginning */
| 848 |
ipb.chr = '\0';
| 849 |
scaninp();
| 850 |
| 851 |
| 852 |
| 853 |
static void
| 854 |
scaninp(void) /* scan next character */
| 855 |
| 856 |
if (ipb.chr == EOF)
| 857 |
return;
| 858 |
if (++ipb.pos >= &inpbuf[INBSIZ])
| 859 |
ipb.pos = inpbuf;
| 860 |
if (ipb.pos == ipb.end) { /* new character */
| 861 |
if ((ipb.chr = getc(ipb.fin)) != EOF) {
| 862 |
*ipb.end = ipb.chr;
| 863 |
if (++ipb.end >= &inpbuf[INBSIZ])
| 864 |
ipb.end = inpbuf;
| 865 |
if (ipb.end == ipb.beg)
| 866 |
ipb.beg = NULL;
| 867 |
| 868 |
} else
| 869 |
ipb.chr = *ipb.pos;
| 870 |
| 871 |
| 872 |
| 873 |
static void
| 874 |
advinp(void) /* move home to current position */
| 875 |
| 876 |
ipb.beg = ipb.pos;
| 877 |
| 878 |
| 879 |
| 880 |
static void
| 881 |
resetinp(void) /* rewind position and advance 1 */
| 882 |
| 883 |
if (ipb.beg == NULL) /* full */
| 884 |
ipb.beg = ipb.end;
| 885 |
ipb.pos = ipb.beg;
| 886 |
ipb.chr = *ipb.pos;
| 887 |
if (passive) /* transmit unmatched character? */
| 888 |
fputc(ipb.chr, stdout);
| 889 |
if (++ipb.beg >= &inpbuf[INBSIZ])
| 890 |
ipb.beg = inpbuf;
| 891 |
scaninp();
| 892 |
| 893 |
| 894 |
| 895 |
void
| 896 |
eputs(char *msg)
| 897 |
| 898 |
fputs(msg, stderr);
| 899 |
| 900 |
| 901 |
| 902 |
void
| 903 |
wputs(char *msg)
| 904 |
| 905 |
if (!nowarn)
| 906 |
eputs(msg);
| 907 |
| 908 |
| 909 |
| 910 |
void
| 911 |
quit(int code)
| 912 |
| 913 |
exit(code);
| 914 |
