--- ray/src/cal/rcalc.c 2022/02/21 23:00:55 1.31 +++ ray/src/cal/rcalc.c 2022/03/12 15:50:13 1.33 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcalc.c,v 1.31 2022/02/21 23:00:55 greg Exp $"; +static const char RCSid[] = "$Id: rcalc.c,v 1.33 2022/03/12 15:50:13 greg Exp $"; #endif /* * rcalc.c - record calculator program. @@ -55,7 +55,7 @@ struct field { /* record format structure */ #define freqstr(s) efree(s) static int getinputrec(FILE *fp); -static void scaninp(void), advinp(void), skipinp(void); +static void scaninp(void), advinp(void), passinp(void), skipinp(void); static void putrec(void), putout(void), nbsynch(void); static int getrec(void); static void execute(char *file); @@ -69,28 +69,28 @@ static void bchanset(int n, double v); static struct strvar* getsvar(char *svname); static double l_in(char *); -struct field *inpfmt = NULL; /* input record format */ -struct field *outfmt = NULL; /* output record structure */ -struct strvar *svhead = NULL; /* string variables */ +struct field *inpfmt = NULL; /* input record format */ +struct field *outfmt = NULL; /* output record structure */ +struct strvar *svhead = NULL; /* string variables */ -long incnt = 0; /* limit number of input records? */ +long incnt = 0; /* limit number of input records? */ long outcnt = 0; /* limit number of output records? */ -int blnkeq = 1; /* blanks compare equal? */ -int igneol = 0; /* ignore end of line? */ +int blnkeq = 1; /* blanks compare equal? */ +int igneol = 0; /* ignore end of line? */ int passive = 0; /* passive mode (transmit unmatched input) */ -char sepchar = '\t'; /* input/output separator */ -int noinput = 0; /* no input records? */ +char sepchar = '\t'; /* input/output separator */ +int noinput = 0; /* no input records? */ int itype = 'a'; /* input type (a/f/F/d/D) */ int nbicols = 0; /* number of binary input columns */ int otype = 'a'; /* output format (a/f/F/d/D) */ -char inpbuf[INBSIZ]; /* input buffer */ -double colval[MAXCOL]; /* input column values */ -unsigned long colflg = 0; /* column retrieved flags */ -int colpos; /* output column position */ +char inpbuf[INBSIZ]; /* input buffer */ +double colval[MAXCOL]; /* input column values */ +unsigned long colflg = 0; /* column retrieved flags */ +int colpos; /* output column position */ -int nowarn = 0; /* non-fatal diagnostic output */ -int unbuff = 0; /* unbuffered output (flush each record) */ +int nowarn = 0; /* non-fatal diagnostic output */ +int unbuff = 0; /* unbuffered output (flush each record) */ struct { FILE *fin; /* input file */ @@ -128,8 +128,11 @@ char *argv[] igneol = !igneol; break; case 'p': - passive = !passive; + passive = 1; break; + case 'P': + passive = -1; + break; case 't': sepchar = argv[i][2]; break; @@ -229,7 +232,7 @@ char *argv[] userr: eputs("Usage: "); eputs(argv[0]); -eputs(" [-b][-l][-n][-p][-w][-u][-tS][-s svar=sval][-e expr][-f source][-i infmt][-o outfmt] [file]\n"); +eputs(" [-b][-l][-n][-p|-P][-w][-u][-tS][-s svar=sval][-e expr][-f source][-i infmt][-o outfmt] [file]\n"); quit(1); } if (otype != 'a') @@ -247,6 +250,11 @@ eputs(" [-b][-l][-n][-p][-w][-u][-tS][-s svar=sval][-e putout(); quit(0); } + if (passive && (inpfmt == NULL) | (outfmt == NULL)) { + eputs(argv[0]); + eputs(": options -p and -P require -i and -o formats\n"); + quit(1); + } if (blnkeq) /* for efficiency */ nbsynch(); @@ -278,8 +286,6 @@ getinputrec( /* get next input record */ FILE *fp ) { - if (inpfmt != NULL) - return(getrec()); if ((itype == 'd') | (itype == 'D')) { if (getbinary(inpbuf, sizeof(double), nbicols, fp) != nbicols) return(0); @@ -303,12 +309,15 @@ execute( /* process a file */ char *file ) { - const int conditional = vardefined("cond"); - const int set_recno = (varlookup("recno") != NULL); - const int set_outno = (varlookup("outno") != NULL); - long nrecs = 0; - long nout = 0; - FILE *fp; + static char condVN[] = "cond"; + static char recnoVN[] = "recno"; + static char outnoVN[] = "outno"; + const int conditional = vardefined(condVN); + const int set_recno = (varlookup(recnoVN) != NULL); + const int set_outno = (varlookup(outnoVN) != NULL); + long nrecs = 0; + long nout = 0; + FILE *fp; if (file == NULL) fp = stdin; @@ -322,20 +331,31 @@ char *file #ifdef getc_unlocked /* avoid lock/unlock overhead */ flockfile(fp); #endif + if (conditional == ':') { + eputs(condVN); + eputs(": defined as constant\n"); + quit(1); + } if (inpfmt != NULL) initinp(fp); - while (getinputrec(fp)) { + while (inpfmt != NULL ? getrec() : getinputrec(fp)) { ++nrecs; if (set_recno) - varset("recno", '=', (double)nrecs); + varset(recnoVN, '=', (double)nrecs); if (set_outno) - varset("outno", '=', (double)(nout+1)); + varset(outnoVN, '=', (double)(nout+1)); colflg = 0; eclock++; - if (!conditional || varvalue("cond") > 0.0) { + if (!conditional || varvalue(condVN) > 0.0) { putout(); ++nout; + advinp(); + } else if (inpfmt != NULL) { + if (passive < 0) + passinp(); + else + advinp(); } if (incnt && nrecs >= incnt) break; @@ -688,7 +708,7 @@ clearrec(void) /* clear input record variables */ static int -getrec(void) /* get next record from file */ +getrec(void) /* get next record from file */ { int eatline; struct field *f; @@ -705,12 +725,10 @@ getrec(void) /* get next record from file */ for (f = inpfmt; f != NULL; f = f->next) if (!getfield(f)) break; - if (f == NULL) { - advinp(); /* got one! */ + if (f == NULL) /* got one? */ return(1); - } - skipinp(); /* eat false start */ - if (eatline) { /* eat rest of line */ + skipinp(); /* else eat false start */ + if (eatline) { /* eat rest of line */ while (ipb.chr != '\n') { if (ipb.chr == EOF) return(0); @@ -919,9 +937,24 @@ advinp(void) /* move home to current position */ static void -skipinp(void) /* rewind position and advance 1 */ +passinp(void) /* pass beginning to current position */ { - if (ipb.beg == NULL) /* full */ + if (!passive | (ipb.beg == NULL)) { + advinp(); + return; + } + while (ipb.beg != ipb.pos) { /* transfer buffer unaltered */ + putchar(*ipb.beg); + if (++ipb.beg >= &inpbuf[INBSIZ]) + ipb.beg = inpbuf; + } +} + + +static void +skipinp(void) /* rewind position and advance 1 */ +{ + if (ipb.beg == NULL) /* full */ ipb.beg = ipb.end; ipb.pos = ipb.beg; ipb.chr = *ipb.pos;
