1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rcalc.c,v 1.37 2023/02/06 22:40:21 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rcalc.c - record calculator program. |
6 |
7 |
* 9/11/87 |
8 |
9 |
10 |
#include <stdlib.h> |
11 |
#include <math.h> |
12 |
#include <ctype.h> |
13 |
14 |
#include "platform.h" |
15 |
#include "rterror.h" |
16 |
#include "rtmisc.h" |
17 |
#include "rtio.h" |
18 |
#include "calcomp.h" |
19 |
20 |
#define isnum(c) (isdigit(c) || ((c)=='-') | ((c)=='.') \ |
21 |
| ((c)=='+') | ((c)=='e') | ((c)=='E')) |
22 |
23 |
#define isblnk(c) (igneol ? isspace(c) : ((c)==' ')|((c)=='\t')) |
24 |
25 |
#define INBSIZ 16384 /* longest record */ |
26 |
#define MAXCOL 32 /* number of columns recorded */ |
27 |
28 |
/* field type specifications */ |
29 |
#define F_NUL 0 /* empty */ |
30 |
#define F_TYP 0x7000 /* mask for type */ |
31 |
#define F_WID 0x0fff /* mask for width */ |
32 |
#define T_LIT 0x1000 /* string literal */ |
33 |
#define T_STR 0x2000 /* string variable */ |
34 |
#define T_NUM 0x3000 /* numeric value */ |
35 |
36 |
struct strvar { /* string variable */ |
37 |
char *name; |
38 |
char *val; |
39 |
char *preset; |
40 |
struct strvar *next; |
41 |
42 |
43 |
struct field { /* record format structure */ |
44 |
int type; /* type of field (& width) */ |
45 |
union { |
46 |
char *sl; /* string literal */ |
47 |
struct strvar *sv; /* string variable */ |
48 |
char *nv; /* numeric variable */ |
49 |
EPNODE *ne; /* numeric expression */ |
50 |
} f; /* field contents */ |
51 |
struct field *next; /* next field in record */ |
52 |
53 |
54 |
#define savqstr(s) strcpy(emalloc(strlen(s)+1),s) |
55 |
#define freqstr(s) efree(s) |
56 |
57 |
static int getinputrec(FILE *fp); |
58 |
static void scaninp(void), skipinp(void), advinp(int skip); |
59 |
static void putrec(void), putout(void), nbsynch(void); |
60 |
static int getrec(void); |
61 |
static void execute(char *file); |
62 |
static void initinp(FILE *fp); |
63 |
static void svpreset(char *eqn); |
64 |
static void readfmt(char *spec, int output); |
65 |
static int readfield(char **pp); |
66 |
static int getfield(struct field *f); |
67 |
static void chanset(int n, double v); |
68 |
static void bchanset(int n, double v); |
69 |
static struct strvar* getsvar(char *svname); |
70 |
static double l_in(char *); |
71 |
72 |
struct field *inpfmt = NULL; /* input record format */ |
73 |
struct field *outfmt = NULL; /* output record structure */ |
74 |
struct strvar *svhead = NULL; /* string variables */ |
75 |
76 |
long incnt = 0; /* limit number of input records? */ |
77 |
long outcnt = 0; /* limit number of output records? */ |
78 |
79 |
int blnkeq = 1; /* blanks compare equal? */ |
80 |
int igneol = 0; /* ignore end of line? */ |
81 |
int passive = 0; /* passive mode (transmit unmatched input) */ |
82 |
char sepchar = '\t'; /* input/output separator */ |
83 |
int noinput = 0; /* no input records? */ |
84 |
int itype = 'a'; /* input type (a/f/F/d/D) */ |
85 |
int nbicols = 0; /* number of binary input columns */ |
86 |
int otype = 'a'; /* output format (a/f/F/d/D) */ |
87 |
char inpbuf[INBSIZ]; /* input buffer */ |
88 |
double colval[MAXCOL]; /* input column values */ |
89 |
unsigned long colflg = 0; /* column retrieved flags */ |
90 |
int colpos; /* output column position */ |
91 |
92 |
int nowarn = 0; /* non-fatal diagnostic output */ |
93 |
int unbuff = 0; /* unbuffered output (flush each record) */ |
94 |
95 |
struct { |
96 |
FILE *fin; /* input file */ |
97 |
int chr; /* next character */ |
98 |
char *beg; /* home position */ |
99 |
char *pos; /* scan position */ |
100 |
char *end; /* read position */ |
101 |
} ipb; /* circular lookahead buffer */ |
102 |
103 |
104 |
int |
105 |
main( |
106 |
int argc, |
107 |
char *argv[] |
108 |
109 |
110 |
char *fpath; |
111 |
int i; |
112 |
113 |
esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_OUTCHAN|E_RCONST; |
114 |
esupport &= ~(E_REDEFW); |
115 |
116 |
#ifdef BIGGERLIB |
117 |
biggerlib(); |
118 |
#endif |
119 |
varset("PI", ':', 3.14159265358979323846); |
120 |
funset("in", 1, '=', &l_in); |
121 |
122 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
123 |
switch (argv[i][1]) { |
124 |
case 'b': |
125 |
blnkeq = !blnkeq; |
126 |
break; |
127 |
case 'l': |
128 |
igneol = !igneol; |
129 |
break; |
130 |
case 'p': |
131 |
passive = 1; |
132 |
break; |
133 |
case 'P': |
134 |
passive = -1; |
135 |
break; |
136 |
case 't': |
137 |
sepchar = argv[i][2]; |
138 |
break; |
139 |
case 's': |
140 |
svpreset(argv[++i]); |
141 |
break; |
142 |
case 'f': |
143 |
fpath = getpath(argv[++i], getrlibpath(), 0); |
144 |
if (fpath == NULL) { |
145 |
eputs(argv[0]); |
146 |
eputs(": cannot find file '"); |
147 |
eputs(argv[i]); |
148 |
eputs("'\n"); |
149 |
quit(1); |
150 |
151 |
fcompile(fpath); |
152 |
break; |
153 |
case 'e': |
154 |
scompile(argv[++i], NULL, 0); |
155 |
break; |
156 |
case 'n': |
157 |
noinput = 1; |
158 |
esupport &= ~E_RCONST; |
159 |
break; |
160 |
case 'i': |
161 |
switch (argv[i][2]) { |
162 |
case '\0': |
163 |
itype = 'a'; |
164 |
nbicols = 0; |
165 |
readfmt(argv[++i], 0); |
166 |
break; |
167 |
case 'n': |
168 |
incnt = atol(argv[++i]); |
169 |
break; |
170 |
case 'a': |
171 |
itype = 'a'; |
172 |
nbicols = 0; |
173 |
break; |
174 |
case 'd': |
175 |
case 'D': |
176 |
itype = argv[i][2]; |
177 |
if (isdigit(argv[i][3])) |
178 |
nbicols = atoi(argv[i]+3); |
179 |
else |
180 |
nbicols = 1; |
181 |
if (nbicols*sizeof(double) > INBSIZ) { |
182 |
eputs(argv[0]); |
183 |
eputs(": too many input columns\n"); |
184 |
quit(1); |
185 |
186 |
break; |
187 |
case 'f': |
188 |
case 'F': |
189 |
190 |
191 |
192 |
else |
193 |
nbicols = 1; |
194 |
if (nbicols*sizeof(float) > INBSIZ) { |
195 |
eputs(argv[0]); |
196 |
197 |
quit(1); |
198 |
199 |
break; |
200 |
default: |
201 |
goto userr; |
202 |
203 |
break; |
204 |
case 'o': |
205 |
206 |
case '\0': |
207 |
otype = 'a'; |
208 |
readfmt(argv[++i], 1); |
209 |
break; |
210 |
case 'n': |
211 |
outcnt = atol(argv[++i]); |
212 |
break; |
213 |
case 'a': |
214 |
otype = 'a'; |
215 |
break; |
216 |
case 'd': |
217 |
case 'D': |
218 |
case 'f': |
219 |
case 'F': |
220 |
otype = argv[i][2]; |
221 |
break; |
222 |
default: |
223 |
goto userr; |
224 |
225 |
break; |
226 |
case 'w': |
227 |
nowarn = !nowarn; |
228 |
break; |
229 |
case 'u': |
230 |
unbuff = !unbuff; |
231 |
break; |
232 |
default:; |
233 |
userr: |
234 |
eputs("Usage: "); |
235 |
eputs(argv[0]); |
236 |
eputs(" [-b][-l][-n][-p|-P][-w][-u][-tS][-s svar=sval][-e expr][-f source][-i infmt][-o outfmt] [file]\n"); |
237 |
quit(1); |
238 |
239 |
if (otype != 'a') |
240 |
SET_FILE_BINARY(stdout); |
241 |
#ifdef getc_unlocked /* avoid lock/unlock overhead */ |
242 |
flockfile(stdout); |
243 |
#endif |
244 |
if (noinput) { /* produce a single output record */ |
245 |
if (i < argc) { |
246 |
eputs(argv[0]); |
247 |
eputs(": file argument(s) incompatible with -n\n"); |
248 |
quit(1); |
249 |
250 |
eclock++; |
251 |
putout(); |
252 |
quit(0); |
253 |
254 |
if (passive && (inpfmt == NULL) | (outfmt == NULL)) { |
255 |
eputs(argv[0]); |
256 |
eputs(": options -p and -P require -i and -o formats\n"); |
257 |
quit(1); |
258 |
259 |
if (blnkeq) /* for efficiency */ |
260 |
nbsynch(); |
261 |
262 |
if (i == argc) /* from stdin */ |
263 |
execute(NULL); |
264 |
else /* from one or more files */ |
265 |
for ( ; i < argc; i++) |
266 |
execute(argv[i]); |
267 |
268 |
quit(0); |
269 |
return 0; /* pro forma return */ |
270 |
271 |
272 |
273 |
static void |
274 |
nbsynch(void) /* non-blank starting synch character */ |
275 |
276 |
if (inpfmt == NULL || (inpfmt->type & F_TYP) != T_LIT) |
277 |
return; |
278 |
while (isblnk(*inpfmt->f.sl)) |
279 |
inpfmt->f.sl++; |
280 |
if (!*inpfmt->f.sl) |
281 |
inpfmt = inpfmt->next; |
282 |
283 |
284 |
285 |
static int |
286 |
getinputrec( /* get next input record */ |
287 |
FILE *fp |
288 |
289 |
290 |
if ((itype == 'd') | (itype == 'D')) { |
291 |
if (getbinary(inpbuf, sizeof(double), nbicols, fp) != nbicols) |
292 |
return(0); |
293 |
if (itype == 'D') |
294 |
swap64(inpbuf, nbicols); |
295 |
return(1); |
296 |
297 |
if ((itype == 'f') | (itype == 'F')) { |
298 |
if (getbinary(inpbuf, sizeof(float), nbicols, fp) != nbicols) |
299 |
return(0); |
300 |
if (itype == 'F') |
301 |
swap32(inpbuf, nbicols); |
302 |
return(1); |
303 |
304 |
return(fgets(inpbuf, INBSIZ, fp) != NULL); |
305 |
306 |
307 |
308 |
static void |
309 |
execute( /* process a file */ |
310 |
char *file |
311 |
312 |
313 |
static char condVN[] = "cond"; |
314 |
static char recnoVN[] = "recno"; |
315 |
static char outnoVN[] = "outno"; |
316 |
const int conditional = vardefined(condVN); |
317 |
const int set_recno = (varlookup(recnoVN) != NULL); |
318 |
const int set_outno = (varlookup(outnoVN) != NULL); |
319 |
long nrecs = 0; |
320 |
long nout = 0; |
321 |
FILE *fp; |
322 |
323 |
if (file == NULL) |
324 |
fp = stdin; |
325 |
else if ((fp = fopen(file, "r")) == NULL) { |
326 |
eputs(file); |
327 |
eputs(": cannot open\n"); |
328 |
quit(1); |
329 |
330 |
if (itype != 'a') |
331 |
SET_FILE_BINARY(fp); |
332 |
333 |
flockfile(fp); |
334 |
#endif |
335 |
if (conditional == ':') { |
336 |
eputs(condVN); |
337 |
eputs(": defined as constant\n"); |
338 |
quit(1); |
339 |
340 |
if (inpfmt != NULL) |
341 |
initinp(fp); |
342 |
343 |
while (inpfmt != NULL ? getrec() : getinputrec(fp)) { |
344 |
++nrecs; |
345 |
if (set_recno) |
346 |
varset(recnoVN, '=', (double)nrecs); |
347 |
if (set_outno) |
348 |
varset(outnoVN, '=', (double)(nout+1)); |
349 |
colflg = 0; |
350 |
eclock++; |
351 |
if (!conditional || varvalue(condVN) > 0.0) { |
352 |
353 |
advinp(0); |
354 |
putout(); |
355 |
++nout; |
356 |
} else if (inpfmt != NULL) { |
357 |
advinp(1); |
358 |
359 |
if (incnt && nrecs >= incnt) |
360 |
break; |
361 |
if (outcnt && nout >= outcnt) |
362 |
break; |
363 |
364 |
fclose(fp); |
365 |
366 |
367 |
368 |
static void |
369 |
putout(void) /* produce an output record */ |
370 |
371 |
372 |
colpos = 0; |
373 |
if (outfmt != NULL) |
374 |
putrec(); |
375 |
else if (otype == 'a') |
376 |
chanout(chanset); |
377 |
else |
378 |
chanout(bchanset); |
379 |
if (colpos && otype == 'a') |
380 |
putchar('\n'); |
381 |
if (unbuff) |
382 |
fflush(stdout); |
383 |
384 |
385 |
386 |
static double |
387 |
l_in(char *funame) /* function call for $channel */ |
388 |
389 |
int n; |
390 |
char *cp; |
391 |
/* get argument as integer */ |
392 |
n = (int)(argument(1) + .5); |
393 |
if (n != 0) /* return channel value */ |
394 |
return(chanvalue(n)); |
395 |
/* determine number of channels */ |
396 |
if (noinput || inpfmt != NULL) |
397 |
return(0); |
398 |
if (nbicols) |
399 |
return(nbicols); |
400 |
cp = inpbuf; /* need to count */ |
401 |
for (n = 0; *cp; ) |
402 |
if (blnkeq && isspace(sepchar)) { |
403 |
while (isspace(*cp)) |
404 |
cp++; |
405 |
n += *cp != '\0'; |
406 |
while (*cp && !isspace(*cp)) |
407 |
cp++; |
408 |
} else { |
409 |
n += *cp != '\n'; |
410 |
while (*cp && *cp++ != sepchar) |
411 |
412 |
413 |
return(n); |
414 |
415 |
416 |
double |
417 |
chanvalue( /* return value for column n */ |
418 |
int n |
419 |
420 |
421 |
int i; |
422 |
char *cp; |
423 |
424 |
if (noinput || inpfmt != NULL) { |
425 |
eputs("no column input\n"); |
426 |
quit(1); |
427 |
428 |
if (n < 1) { |
429 |
eputs("illegal channel number\n"); |
430 |
quit(1); |
431 |
432 |
if (nbicols) { |
433 |
if (n > nbicols) |
434 |
return(0.0); |
435 |
436 |
cp = inpbuf + (n-1)*sizeof(double); |
437 |
return(*(double *)cp); |
438 |
439 |
cp = inpbuf + (n-1)*sizeof(float); |
440 |
return(*(float *)cp); |
441 |
442 |
if (n <= MAXCOL && colflg & 1L<<(n-1)) |
443 |
return(colval[n-1]); |
444 |
445 |
cp = inpbuf; |
446 |
for (i = 1; i < n; i++) |
447 |
448 |
449 |
cp++; |
450 |
451 |
cp++; |
452 |
} else |
453 |
454 |
455 |
456 |
while (isspace(*cp)) /* some atof()'s don't like tabs */ |
457 |
cp++; |
458 |
459 |
if (n <= MAXCOL) { |
460 |
colflg |= 1L<<(n-1); |
461 |
return(colval[n-1] = atof(cp)); |
462 |
} else |
463 |
return(atof(cp)); |
464 |
465 |
466 |
467 |
void |
468 |
chanset( /* output column n */ |
469 |
int n, |
470 |
double v |
471 |
472 |
473 |
if (colpos == 0) /* no leading separator */ |
474 |
colpos = 1; |
475 |
while (colpos < n) { |
476 |
putchar(sepchar); |
477 |
colpos++; |
478 |
479 |
printf("%.9g", v); |
480 |
481 |
482 |
483 |
void |
484 |
bchanset( /* output binary channel n */ |
485 |
int n, |
486 |
double v |
487 |
488 |
489 |
static char zerobuf[sizeof(double)]; |
490 |
const int otlen = ((otype == 'd') | (otype == 'D')) ? |
491 |
sizeof(double) : sizeof(float); |
492 |
float fval = v; |
493 |
494 |
while (++colpos < n) |
495 |
putbinary(zerobuf, otlen, 1, stdout); |
496 |
switch (otype) { |
497 |
case 'D': |
498 |
swap64((char *)&v, 1); |
499 |
/* fall through */ |
500 |
case 'd': |
501 |
putbinary(&v, sizeof(double), 1, stdout); |
502 |
break; |
503 |
case 'F': |
504 |
swap32((char *)&fval, 1); |
505 |
506 |
case 'f': |
507 |
putbinary(&fval, sizeof(float), 1, stdout); |
508 |
break; |
509 |
510 |
511 |
512 |
513 |
static void |
514 |
readfmt( /* read record format */ |
515 |
char *spec, |
516 |
int output |
517 |
518 |
519 |
int fd; |
520 |
char *inptr; |
521 |
struct field fmt; |
522 |
int res; |
523 |
struct field *f; |
524 |
/* check for inline format */ |
525 |
for (inptr = spec; *inptr; inptr++) |
526 |
if (*inptr == '$') |
527 |
break; |
528 |
if (*inptr) /* inline */ |
529 |
inptr = spec; |
530 |
else { /* from file */ |
531 |
if ((fd = open(spec, 0)) == -1) { |
532 |
eputs(spec); |
533 |
534 |
quit(1); |
535 |
536 |
res = read(fd, inpbuf+2, INBSIZ-2); |
537 |
if (res <= 0 || res >= INBSIZ-1) { |
538 |
eputs(spec); |
539 |
if (res < 0) |
540 |
eputs(": read error\n"); |
541 |
else if (res == 0) |
542 |
eputs(": empty file\n"); |
543 |
else if (res >= INBSIZ-1) |
544 |
eputs(": format too long\n"); |
545 |
quit(1); |
546 |
547 |
close(fd); |
548 |
(inptr=inpbuf+2)[res] = '\0'; |
549 |
550 |
f = &fmt; /* get fields */ |
551 |
while ((res = readfield(&inptr)) != F_NUL) { |
552 |
f->next = (struct field *)emalloc(sizeof(struct field)); |
553 |
f = f->next; |
554 |
f->type = res; |
555 |
switch (res & F_TYP) { |
556 |
case T_LIT: |
557 |
f->f.sl = savqstr(inpbuf); |
558 |
break; |
559 |
case T_STR: |
560 |
f->f.sv = getsvar(inpbuf); |
561 |
break; |
562 |
case T_NUM: |
563 |
if (output) |
564 |
f->f.ne = eparse(inpbuf); |
565 |
else |
566 |
f->f.nv = savestr(inpbuf); |
567 |
break; |
568 |
569 |
/* add final newline if necessary */ |
570 |
if (!igneol && *inptr == '\0' && inptr[-1] != '\n') |
571 |
inptr = "\n"; |
572 |
573 |
f->next = NULL; |
574 |
if (output) |
575 |
outfmt = fmt.next; |
576 |
else |
577 |
inpfmt = fmt.next; |
578 |
579 |
580 |
581 |
static int |
582 |
readfield( /* get next field in format */ |
583 |
char **pp |
584 |
585 |
586 |
int type = F_NUL; |
587 |
int width = 0; |
588 |
char *cp; |
589 |
590 |
cp = inpbuf; |
591 |
while (cp < &inpbuf[INBSIZ-1] && **pp != '\0') { |
592 |
width++; |
593 |
switch (type) { |
594 |
case F_NUL: |
595 |
if (**pp == '$') { |
596 |
(*pp)++; |
597 |
width++; |
598 |
if (**pp == '{') { |
599 |
type = T_NUM; |
600 |
(*pp)++; |
601 |
continue; |
602 |
} else if (**pp == '(') { |
603 |
type = T_STR; |
604 |
(*pp)++; |
605 |
continue; |
606 |
} else if (**pp != '$') { |
607 |
eputs("format error\n"); |
608 |
quit(1); |
609 |
610 |
width--; |
611 |
612 |
type = T_LIT; |
613 |
*cp++ = *(*pp)++; |
614 |
continue; |
615 |
case T_LIT: |
616 |
617 |
width--; |
618 |
break; |
619 |
620 |
*cp++ = *(*pp)++; |
621 |
continue; |
622 |
case T_NUM: |
623 |
if (**pp == '}') { |
624 |
(*pp)++; |
625 |
break; |
626 |
627 |
if (!isspace(**pp)) |
628 |
*cp++ = **pp; |
629 |
(*pp)++; |
630 |
continue; |
631 |
case T_STR: |
632 |
if (**pp == ')') { |
633 |
(*pp)++; |
634 |
break; |
635 |
636 |
637 |
*cp++ = **pp; |
638 |
(*pp)++; |
639 |
continue; |
640 |
641 |
break; |
642 |
643 |
*cp = '\0'; |
644 |
return(type | width); |
645 |
646 |
647 |
648 |
struct strvar * |
649 |
getsvar( /* get string variable */ |
650 |
char *svname |
651 |
652 |
653 |
struct strvar *sv; |
654 |
655 |
for (sv = svhead; sv != NULL; sv = sv->next) |
656 |
if (!strcmp(sv->name, svname)) |
657 |
return(sv); |
658 |
sv = (struct strvar *)emalloc(sizeof(struct strvar)); |
659 |
sv->name = savqstr(svname); |
660 |
sv->val = sv->preset = NULL; |
661 |
sv->next = svhead; |
662 |
svhead = sv; |
663 |
return(sv); |
664 |
665 |
666 |
667 |
static void |
668 |
svpreset( /* preset a string variable */ |
669 |
char *eqn |
670 |
671 |
672 |
673 |
char *val; |
674 |
675 |
for (val = eqn; *val != '='; val++) |
676 |
if (!*val) |
677 |
return; |
678 |
*val++ = '\0'; |
679 |
sv = getsvar(eqn); |
680 |
if (sv->preset != NULL) |
681 |
freqstr(sv->preset); |
682 |
if (sv->val != NULL) |
683 |
freqstr(sv->val); |
684 |
sv->val = sv->preset = savqstr(val); |
685 |
*--val = '='; |
686 |
687 |
688 |
689 |
static void |
690 |
clearrec(void) /* clear input record variables */ |
691 |
692 |
struct field *f; |
693 |
694 |
for (f = inpfmt; f != NULL; f = f->next) |
695 |
switch (f->type & F_TYP) { |
696 |
case T_NUM: |
697 |
dremove(f->f.nv); |
698 |
break; |
699 |
case T_STR: |
700 |
if (f->f.sv->val != f->f.sv->preset) { |
701 |
freqstr(f->f.sv->val); |
702 |
f->f.sv->val = f->f.sv->preset; |
703 |
704 |
break; |
705 |
706 |
707 |
708 |
709 |
static int |
710 |
getrec(void) /* get next record from file */ |
711 |
712 |
int eatline; |
713 |
struct field *f; |
714 |
715 |
while (ipb.chr != EOF) { |
716 |
if (blnkeq) { /* beware of nbsynch() */ |
717 |
while (isblnk(ipb.chr)) |
718 |
skipinp(); |
719 |
if (ipb.chr == EOF) |
720 |
return(0); |
721 |
722 |
eatline = !igneol & (ipb.chr != '\n'); |
723 |
clearrec(); /* start with fresh record */ |
724 |
725 |
if (!getfield(f)) |
726 |
break; |
727 |
if (f == NULL) /* got one? */ |
728 |
return(1); |
729 |
skipinp(); /* else eat false start */ |
730 |
if (eatline) { /* eat rest of line */ |
731 |
while (ipb.chr != '\n') { |
732 |
733 |
return(0); |
734 |
skipinp(); |
735 |
736 |
skipinp(); |
737 |
738 |
739 |
return(0); |
740 |
741 |
742 |
743 |
static int |
744 |
getfield( /* get next field */ |
745 |
struct field *f |
746 |
747 |
748 |
static char buf[RMAXWORD+1]; /* no recursion! */ |
749 |
int delim, inword; |
750 |
double d; |
751 |
char *np; |
752 |
char *cp; |
753 |
754 |
755 |
case T_LIT: |
756 |
cp = f->f.sl; |
757 |
do { |
758 |
if (blnkeq && isblnk(*cp)) { |
759 |
if (!isblnk(ipb.chr)) |
760 |
return(0); |
761 |
do |
762 |
cp++; |
763 |
while (isblnk(*cp)); |
764 |
do |
765 |
scaninp(); |
766 |
while (isblnk(ipb.chr)); |
767 |
} else if (*cp == ipb.chr) { |
768 |
cp++; |
769 |
scaninp(); |
770 |
} else |
771 |
return(0); |
772 |
} while (*cp); |
773 |
break; |
774 |
case T_STR: |
775 |
if (f->next == NULL || (f->next->type & F_TYP) != T_LIT) |
776 |
delim = EOF; |
777 |
else |
778 |
delim = f->next->f.sl[0]; |
779 |
cp = buf; |
780 |
do { |
781 |
if ((ipb.chr == EOF) | (ipb.chr == '\n')) |
782 |
inword = 0; |
783 |
else if (blnkeq && delim != EOF) |
784 |
inword = isblnk(delim) ? |
785 |
!isblnk(ipb.chr) |
786 |
: ipb.chr != delim; |
787 |
else |
788 |
inword = cp-buf < (f->type & F_WID); |
789 |
if (inword) { |
790 |
*cp++ = ipb.chr; |
791 |
scaninp(); |
792 |
793 |
} while (inword && cp < &buf[RMAXWORD]); |
794 |
*cp = '\0'; |
795 |
if (f->f.sv->val == NULL) |
796 |
f->f.sv->val = savqstr(buf); /* first setting */ |
797 |
else if (strcmp(f->f.sv->val, buf)) |
798 |
return(0); /* doesn't match! */ |
799 |
break; |
800 |
case T_NUM: |
801 |
802 |
delim = EOF; |
803 |
else |
804 |
805 |
np = NULL; |
806 |
cp = buf; |
807 |
do { |
808 |
if (!((np==NULL&&isblnk(ipb.chr)) || isnum(ipb.chr))) |
809 |
inword = 0; |
810 |
811 |
812 |
!isblnk(ipb.chr) |
813 |
814 |
else |
815 |
816 |
if (inword) { |
817 |
if (np==NULL && !isblnk(ipb.chr)) |
818 |
np = cp; |
819 |
*cp++ = ipb.chr; |
820 |
scaninp(); |
821 |
822 |
823 |
*cp = '\0'; |
824 |
d = np==NULL ? 0. : atof(np); |
825 |
if (!vardefined(f->f.nv)) |
826 |
varset(f->f.nv, '=', d); /* first setting */ |
827 |
else if ((d = (varvalue(f->f.nv)-d)/(d==0.?1.:d)) > .001 |
828 |
|| d < -.001) |
829 |
830 |
break; |
831 |
832 |
return(1); /* success! */ |
833 |
834 |
835 |
836 |
static void |
837 |
putrec(void) /* output a record */ |
838 |
839 |
char fmt[32], typ[16]; |
840 |
int n; |
841 |
struct field *f; |
842 |
int adlast, adnext; |
843 |
double dv, av; |
844 |
845 |
adlast = 0; |
846 |
for (f = outfmt; f != NULL; f = f->next) { |
847 |
adnext = blnkeq && |
848 |
f->next != NULL && |
849 |
!( (f->next->type&F_TYP) == T_LIT && |
850 |
f->next->f.sl[0] == ' ' ); |
851 |
852 |
case T_LIT: |
853 |
fputs(f->f.sl, stdout); |
854 |
adlast = f->f.sl[(f->type&F_WID)-1] != ' '; |
855 |
break; |
856 |
case T_STR: |
857 |
if (f->f.sv->val == NULL) { |
858 |
eputs(f->f.sv->name); |
859 |
eputs(": undefined string\n"); |
860 |
quit(1); |
861 |
862 |
n = (int)(f->type & F_WID) - strlen(f->f.sv->val); |
863 |
if (adlast) |
864 |
fputs(f->f.sv->val, stdout); |
865 |
if (!(adlast && adnext)) |
866 |
while (n-- > 0) |
867 |
putchar(' '); |
868 |
if (!adlast) |
869 |
870 |
adlast = 1; |
871 |
break; |
872 |
case T_NUM: |
873 |
n = f->type & F_WID; |
874 |
dv = evalue(f->f.ne); |
875 |
av = fabs(dv); |
876 |
if (n <= 9) |
877 |
strcpy(typ, "g"); |
878 |
else |
879 |
sprintf(typ, ".%de", n-5); |
880 |
if (av < 1L<<31) { |
881 |
long iv = (int)(av + .5); |
882 |
if (iv && fabs(av-iv) <= av*1e-14) |
883 |
strcpy(typ, ".0f"); |
884 |
885 |
if (adlast && adnext) |
886 |
sprintf(fmt, "%%%s", typ); |
887 |
else if (adlast) |
888 |
sprintf(fmt, "%%-%d%s", n, typ); |
889 |
else |
890 |
sprintf(fmt, "%%%d%s", n, typ); |
891 |
printf(fmt, dv); |
892 |
adlast = 1; |
893 |
break; |
894 |
895 |
896 |
897 |
898 |
899 |
static void |
900 |
initinp(FILE *fp) /* prepare lookahead buffer */ |
901 |
902 |
903 |
ipb.fin = fp; |
904 |
ipb.beg = ipb.end = inpbuf; |
905 |
ipb.pos = inpbuf-1; /* position before beginning */ |
906 |
ipb.chr = '\0'; |
907 |
scaninp(); |
908 |
909 |
910 |
911 |
static void |
912 |
scaninp(void) /* scan next character */ |
913 |
914 |
915 |
return; |
916 |
if (++ipb.pos >= &inpbuf[INBSIZ]) |
917 |
ipb.pos = inpbuf; |
918 |
if (ipb.pos == ipb.end) { /* new character */ |
919 |
if ((ipb.chr = getc(ipb.fin)) != EOF) { |
920 |
*ipb.end = ipb.chr; |
921 |
if (++ipb.end >= &inpbuf[INBSIZ]) |
922 |
ipb.end = inpbuf; |
923 |
if (ipb.end == ipb.beg) |
924 |
ipb.beg = NULL; |
925 |
926 |
} else |
927 |
ipb.chr = *ipb.pos; |
928 |
929 |
930 |
931 |
static void |
932 |
skipinp(void) /* rewind position and advance 1 */ |
933 |
934 |
if (ipb.beg == NULL) /* can't fully rewind? */ |
935 |
ipb.beg = ipb.end; |
936 |
ipb.pos = ipb.beg; |
937 |
938 |
if (passive) /* transmit unmatched character? */ |
939 |
putchar(ipb.chr); |
940 |
if (++ipb.beg >= &inpbuf[INBSIZ]) |
941 |
ipb.beg = inpbuf; |
942 |
scaninp(); |
943 |
944 |
945 |
946 |
static void |
947 |
advinp(int skip) /* advance home to current position */ |
948 |
949 |
if (!skip | (passive >= 0)) { |
950 |
ipb.beg = ipb.pos; /* no need to copy input */ |
951 |
return; |
952 |
953 |
if (ipb.beg == NULL) { /* buffer overflowed a bit? */ |
954 |
wputs("buffer overflow\n"); |
955 |
puts("\n*** MISSING DATA ***"); |
956 |
957 |
958 |
while (ipb.beg != ipb.pos) { /* copy buffer to current */ |
959 |
putchar(*ipb.beg); |
960 |
961 |
ipb.beg = inpbuf; |
962 |
963 |
964 |
965 |
966 |
void |
967 |
eputs(const char *msg) |
968 |
969 |
fputs(msg, stderr); |
970 |
971 |
972 |
973 |
void |
974 |
wputs(const char *msg) |
975 |
976 |
if (!nowarn) |
977 |
eputs(msg); |
978 |
979 |
980 |
981 |
void |
982 |
quit(int code) |
983 |
984 |
exit(code); |
985 |
