1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: lam.c,v 1.27 2025/02/06 19:52:05 greg Exp $"; |
3 |
#endif |
4 |
5 |
* lam.c - simple program to laminate files. |
6 |
7 |
* 7/14/88 Greg Ward |
8 |
9 |
10 |
#include <ctype.h> |
11 |
12 |
#include "rtio.h" |
13 |
#include "platform.h" |
14 |
#include "paths.h" |
15 |
16 |
#ifndef MAXLINE |
17 |
#define MAXLINE (1L<<20) /* maximum input line per stream */ |
18 |
#endif |
19 |
20 |
struct instream { /* structure to hold input stream info */ |
21 |
FILE *input; /* input stream */ |
22 |
int bytsiz; /* bytes/component if binary */ |
23 |
char *tabc; /* data separation string */ |
24 |
} *rifile = NULL; |
25 |
26 |
int nfiles = 0; |
27 |
28 |
char buf[MAXLINE]; |
29 |
30 |
int |
31 |
main(int argc, char *argv[]) |
32 |
33 |
long incnt = 0; |
34 |
int unbuff = 0; |
35 |
int binout = 0; |
36 |
char *curtab = "\t"; |
37 |
int curbytes = 0; |
38 |
int puteol; |
39 |
int i; |
40 |
41 |
rifile = (struct instream *)calloc(argc-1, sizeof(struct instream)); |
42 |
if (!rifile) { |
43 |
fputs(argv[0], stderr); |
44 |
fputs(": not enough memory\n", stderr); |
45 |
return(1); |
46 |
47 |
for (i = 1; i < argc; i++) { |
48 |
if (argv[i][0] == '-') { |
49 |
switch (argv[i][1]) { |
50 |
case 't': |
51 |
curtab = argv[i]+2; |
52 |
if (!*curtab) curtab = "\n"; |
53 |
continue; |
54 |
case 'u': |
55 |
unbuff = !unbuff; |
56 |
continue; |
57 |
case 'i': |
58 |
switch (argv[i][2]) { |
59 |
case 'n': |
60 |
incnt = atol(argv[++i]); |
61 |
continue; |
62 |
case 'f': |
63 |
case 'F': |
64 |
curbytes = sizeof(float); |
65 |
break; |
66 |
case 'd': |
67 |
case 'D': |
68 |
curbytes = sizeof(double); |
69 |
break; |
70 |
case 'i': |
71 |
case 'I': |
72 |
curbytes = sizeof(int); |
73 |
break; |
74 |
case 'w': |
75 |
case 'W': |
76 |
curbytes = 2; |
77 |
break; |
78 |
case 'b': |
79 |
curbytes = 1; |
80 |
break; |
81 |
case 'a': |
82 |
curbytes = argv[i][3] ? -1 : 0; |
83 |
break; |
84 |
default: |
85 |
goto badopt; |
86 |
87 |
if (isdigit(argv[i][3])) |
88 |
curbytes *= atoi(argv[i]+3); |
89 |
curbytes += (curbytes == -1); |
90 |
if (curbytes > MAXLINE) { |
91 |
92 |
fputs(": input size too big\n", stderr); |
93 |
return(1); |
94 |
95 |
if (curbytes > 0) { |
96 |
curtab = ""; |
97 |
++binout; |
98 |
99 |
continue; |
100 |
case '\0': |
101 |
rifile[nfiles].tabc = curtab; |
102 |
rifile[nfiles].input = stdin; |
103 |
if (curbytes > 0) |
104 |
SET_FILE_BINARY(rifile[nfiles].input); |
105 |
rifile[nfiles++].bytsiz = curbytes; |
106 |
continue; |
107 |
badopt:; |
108 |
default: |
109 |
110 |
fputs(": unknown option '", stderr); |
111 |
fputs(argv[i], stderr); |
112 |
fputs("'\n", stderr); |
113 |
return(1); |
114 |
115 |
116 |
if (argv[i][0] == '!') { |
117 |
118 |
if ((rifile[nfiles].input = popen(argv[i]+1, "r")) == NULL) { |
119 |
120 |
fputs(": cannot start command\n", stderr); |
121 |
return(1); |
122 |
123 |
if (curbytes > 0) |
124 |
125 |
126 |
} else { |
127 |
128 |
if ((rifile[nfiles].input = fopen(argv[i], "r")) == NULL) { |
129 |
130 |
fputs(": cannot open file\n", stderr); |
131 |
return(1); |
132 |
133 |
if (curbytes > 0) |
134 |
135 |
136 |
137 |
138 |
if (!nfiles) { |
139 |
140 |
fputs(": no input streams\n", stderr); |
141 |
return(1); |
142 |
} /* reduce array to size we need */ |
143 |
rifile = (struct instream *)realloc(rifile, nfiles*sizeof(struct instream)); |
144 |
if (!rifile) { |
145 |
146 |
fputs(": realloc() failed!\n", stderr); |
147 |
return(1); |
148 |
149 |
if (binout) /* binary output? */ |
150 |
SET_FILE_BINARY(stdout); |
151 |
#ifdef getc_unlocked /* avoid lock/unlock overhead */ |
152 |
for (i = nfiles; i--; ) |
153 |
flockfile(rifile[i].input); |
154 |
flockfile(stdout); |
155 |
#endif |
156 |
puteol = 0; /* any ASCII output at all? */ |
157 |
158 |
puteol += (rifile[i].bytsiz <= 0); |
159 |
do { /* main loop */ |
160 |
for (i = 0; i < nfiles; i++) { |
161 |
if (rifile[i].bytsiz > 0) { /* binary input */ |
162 |
if (getbinary(buf, rifile[i].bytsiz, 1, rifile[i].input) < 1) |
163 |
break; |
164 |
if (putbinary(buf, rifile[i].bytsiz, 1, stdout) != 1) |
165 |
break; |
166 |
} else if (rifile[i].bytsiz < 0) { /* multi-line input */ |
167 |
int n = -rifile[i].bytsiz; |
168 |
while (n--) { |
169 |
if (fgets(buf, MAXLINE, rifile[i].input) == NULL) |
170 |
break; |
171 |
if ((i > 0) | (n < -rifile[i].bytsiz-1)) |
172 |
fputs(rifile[i].tabc, stdout); |
173 |
buf[strlen(buf)-1] = '\0'; |
174 |
if (fputs(buf, stdout) == EOF) |
175 |
break; |
176 |
177 |
if (n >= 0) /* fell short? */ |
178 |
break; |
179 |
} else { /* single-line input */ |
180 |
181 |
break; |
182 |
if (i) |
183 |
184 |
185 |
186 |
break; |
187 |
188 |
189 |
if (i < nfiles) |
190 |
break; |
191 |
if (puteol) |
192 |
putchar('\n'); |
193 |
if (unbuff) |
194 |
fflush(stdout); |
195 |
} while (--incnt); |
196 |
/* check ending */ |
197 |
if (fflush(stdout) == EOF) { |
198 |
199 |
fputs(": write error on standard output\n", stderr); |
200 |
return(1); |
201 |
202 |
if (incnt > 0) { |
203 |
204 |
fputs(": warning: premature EOD\n", stderr); |
205 |
206 |
return(0); |
207 |
