--- ray/src/cal/lam.c 2003/06/08 12:03:09 1.2 +++ ray/src/cal/lam.c 2014/03/09 20:07:27 1.14 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: lam.c,v 1.2 2003/06/08 12:03:09 schorsch Exp $"; +static const char RCSid[] = "$Id: lam.c,v 1.14 2014/03/09 20:07:27 greg Exp $"; #endif /* * lam.c - simple program to laminate files. @@ -10,39 +10,91 @@ static const char RCSid[] = "$Id: lam.c,v 1.2 2003/06/ #include #include #include +#include #include "platform.h" +#include "rtprocess.h" -#define MAXFILE 16 /* maximum number of files */ +#define MAXFILE 512 /* maximum number of files */ -#define MAXLINE 512 /* maximum input line */ +#define MAXLINE 65536 /* maximum input line */ FILE *input[MAXFILE]; -int tabc[MAXFILE]; +int bytsiz[MAXFILE]; +char *tabc[MAXFILE]; int nfiles; char buf[MAXLINE]; +int main(argc, argv) int argc; char *argv[]; { - register int i; - int curtab; - int running; + int unbuff = 0; + int binout = 0; + int i; + char *curtab; + int curbytes; + int puteol; - curtab = '\t'; + curtab = "\t"; + curbytes = 0; nfiles = 0; for (i = 1; i < argc; i++) { if (argv[i][0] == '-') { switch (argv[i][1]) { case 't': - curtab = argv[i][2]; + curtab = argv[i]+2; break; + case 'u': + unbuff = !unbuff; + break; + case 'i': + switch (argv[i][2]) { + case 'f': + curbytes = sizeof(float); + break; + case 'd': + curbytes = sizeof(double); + break; + case 'i': + curbytes = sizeof(int); + break; + case 'w': + curbytes = 2; + break; + case 'b': + curbytes = 1; + break; + case 'a': + curbytes = argv[i][3] ? -1 : 0; + break; + default: + goto badopt; + } + if (isdigit(argv[i][3])) + curbytes *= atoi(argv[i]+3); + if (abs(curbytes) > MAXLINE) { + fputs(argv[0], stderr); + fputs(": input size too big\n", stderr); + exit(1); + } + if (curbytes) { + curtab = ""; + ++binout; + } + break; case '\0': tabc[nfiles] = curtab; - input[nfiles++] = stdin; + input[nfiles] = stdin; + if (curbytes > 0) + SET_FILE_BINARY(input[nfiles]); + else + curbytes = -curbytes; + bytsiz[nfiles++] = curbytes; break; + badopt:; default: fputs(argv[0], stderr); fputs(": bad option\n", stderr); @@ -50,18 +102,28 @@ char *argv[]; } } else if (argv[i][0] == '!') { tabc[nfiles] = curtab; - if ((input[nfiles++] = popen(argv[i]+1, "r")) == NULL) { + if ((input[nfiles] = popen(argv[i]+1, "r")) == NULL) { fputs(argv[i], stderr); fputs(": cannot start command\n", stderr); exit(1); } + if (curbytes > 0) + SET_FILE_BINARY(input[nfiles]); + else + curbytes = -curbytes; + bytsiz[nfiles++] = curbytes; } else { tabc[nfiles] = curtab; - if ((input[nfiles++] = fopen(argv[i], "r")) == NULL) { + if ((input[nfiles] = fopen(argv[i], "r")) == NULL) { fputs(argv[i], stderr); fputs(": cannot open file\n", stderr); exit(1); } + if (curbytes > 0) + SET_FILE_BINARY(input[nfiles]); + else + curbytes = -curbytes; + bytsiz[nfiles++] = curbytes; } if (nfiles >= MAXFILE) { fputs(argv[0], stderr); @@ -69,21 +131,42 @@ char *argv[]; exit(1); } } - - do { - running = 0; + if (binout) /* binary output? */ + SET_FILE_BINARY(stdout); +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + for (i = nfiles; i--; ) + flockfile(input[i]); + flockfile(stdout); +#endif + puteol = 0; /* check for ASCII output */ + for (i = nfiles; i--; ) + if (!bytsiz[i] || isprint(tabc[i][0]) || tabc[i][0] == '\t') { + puteol++; + break; + } + for ( ; ; ) { /* main loop */ for (i = 0; i < nfiles; i++) { - if (fgets(buf, MAXLINE, input[i]) != NULL) { + if (bytsiz[i]) { /* binary file */ + if (fread(buf, bytsiz[i], 1, input[i]) < 1) + break; if (i) - putchar(tabc[i]); + fputs(tabc[i], stdout); + fwrite(buf, bytsiz[i], 1, stdout); + } else { + if (fgets(buf, MAXLINE, input[i]) == NULL) + break; + if (i) + fputs(tabc[i], stdout); buf[strlen(buf)-1] = '\0'; fputs(buf, stdout); - running++; } } - if (running) + if (i < nfiles) + break; + if (puteol) putchar('\n'); - } while (running); - - exit(0); + if (unbuff) + fflush(stdout); + } + return(0); }
