--- ray/src/cal/lam.c 2003/02/22 02:07:20 1.1 +++ ray/src/cal/lam.c 2019/08/13 16:31:35 1.25 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: lam.c,v 1.1 2003/02/22 02:07:20 greg Exp $"; +static const char RCSid[] = "$Id: lam.c,v 1.25 2019/08/13 16:31:35 greg Exp $"; #endif /* * lam.c - simple program to laminate files. @@ -7,79 +7,188 @@ static const char RCSid[] = "$Id: lam.c,v 1.1 2003/02/ * 7/14/88 Greg Ward */ -#include +#include -#define MAXFILE 16 /* maximum number of files */ +#include "rtio.h" +#include "platform.h" +#include "paths.h" -#define MAXLINE 512 /* maximum input line */ +#define MAXFILE 512 /* maximum number of files */ +#define MAXLINE 65536 /* maximum input line */ + FILE *input[MAXFILE]; -int tabc[MAXFILE]; -int nfiles; +int bytsiz[MAXFILE]; +char *tabc[MAXFILE]; +int nfiles = 0; char buf[MAXLINE]; -main(argc, argv) -int argc; -char *argv[]; +int +main(int argc, char *argv[]) { - register int i; - int curtab; - int running; + long incnt = 0; + int unbuff = 0; + int binout = 0; + char *curtab = "\t"; + int curbytes = 0; + int puteol; + int i; - curtab = '\t'; - nfiles = 0; for (i = 1; i < argc; i++) { if (argv[i][0] == '-') { switch (argv[i][1]) { case 't': - curtab = argv[i][2]; + curtab = argv[i]+2; + if (!*curtab) curtab = "\n"; break; + case 'u': + unbuff = !unbuff; + break; + case 'i': + switch (argv[i][2]) { + case 'n': + incnt = atol(argv[++i]); + break; + case 'f': + case 'F': + curbytes = sizeof(float); + break; + case 'd': + case 'D': + curbytes = sizeof(double); + break; + case 'i': + case 'I': + curbytes = sizeof(int); + break; + case 'w': + case 'W': + curbytes = 2; + break; + case 'b': + curbytes = 1; + break; + case 'a': + curbytes = argv[i][3] ? -1 : 0; + break; + default: + goto badopt; + } + if (isdigit(argv[i][3])) + curbytes *= atoi(argv[i]+3); + curbytes += (curbytes == -1); + if (curbytes > MAXLINE) { + fputs(argv[0], stderr); + fputs(": input size too big\n", stderr); + return(1); + } + if (curbytes > 0) { + curtab = ""; + ++binout; + } + break; case '\0': tabc[nfiles] = curtab; - input[nfiles++] = stdin; + input[nfiles] = stdin; + if (curbytes > 0) + SET_FILE_BINARY(input[nfiles]); + bytsiz[nfiles++] = curbytes; break; + badopt:; default: fputs(argv[0], stderr); fputs(": bad option\n", stderr); - exit(1); + return(1); } } else if (argv[i][0] == '!') { tabc[nfiles] = curtab; - if ((input[nfiles++] = popen(argv[i]+1, "r")) == NULL) { + if ((input[nfiles] = popen(argv[i]+1, "r")) == NULL) { fputs(argv[i], stderr); fputs(": cannot start command\n", stderr); - exit(1); + return(1); } + if (curbytes > 0) + SET_FILE_BINARY(input[nfiles]); + bytsiz[nfiles++] = curbytes; } else { tabc[nfiles] = curtab; - if ((input[nfiles++] = fopen(argv[i], "r")) == NULL) { + if ((input[nfiles] = fopen(argv[i], "r")) == NULL) { fputs(argv[i], stderr); fputs(": cannot open file\n", stderr); - exit(1); + return(1); } + if (curbytes > 0) + SET_FILE_BINARY(input[nfiles]); + bytsiz[nfiles++] = curbytes; } if (nfiles >= MAXFILE) { fputs(argv[0], stderr); fputs(": too many input streams\n", stderr); - exit(1); + return(1); } } - - do { - running = 0; + if (!nfiles) { + fputs(argv[0], stderr); + fputs(": no input streams\n", stderr); + return(1); + } + if (binout) /* binary output? */ + SET_FILE_BINARY(stdout); +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + for (i = nfiles; i--; ) + flockfile(input[i]); + flockfile(stdout); +#endif + puteol = 0; /* any ASCII output at all? */ + for (i = nfiles; i--; ) + puteol += (bytsiz[i] <= 0); + do { /* main loop */ for (i = 0; i < nfiles; i++) { - if (fgets(buf, MAXLINE, input[i]) != NULL) { + if (bytsiz[i] > 0) { /* binary input */ + if (getbinary(buf, bytsiz[i], 1, input[i]) < 1) + break; + if (putbinary(buf, bytsiz[i], 1, stdout) != 1) + break; + } else if (bytsiz[i] < 0) { /* multi-line input */ + int n = -bytsiz[i]; + while (n--) { + if (fgets(buf, MAXLINE, input[i]) == NULL) + break; + if ((i > 0) | (n < -bytsiz[i]-1)) + fputs(tabc[i], stdout); + buf[strlen(buf)-1] = '\0'; + if (fputs(buf, stdout) == EOF) + break; + } + if (n >= 0) /* fell short? */ + break; + } else { /* single-line input */ + if (fgets(buf, MAXLINE, input[i]) == NULL) + break; if (i) - putchar(tabc[i]); + fputs(tabc[i], stdout); buf[strlen(buf)-1] = '\0'; - fputs(buf, stdout); - running++; + if (fputs(buf, stdout) == EOF) + break; } } - if (running) + if (i < nfiles) + break; + if (puteol) putchar('\n'); - } while (running); - - exit(0); + if (unbuff) + fflush(stdout); + } while (--incnt); + /* check ending */ + if (fflush(stdout) == EOF) { + fputs(argv[0], stderr); + fputs(": write error on standard output\n", stderr); + return(1); + } + if (incnt > 0) { + fputs(argv[0], stderr); + fputs(": warning: premature EOD\n", stderr); + } + return(0); }
