root/radiance/ray/src/cal/lam.c
Tue Aug 13 16:31:35 2019 UTC (4 years, 9 months ago) by greg
Changes since 1.24: +3 -5 lines
Diff to previous 1.24
Windows cleaning (thanks to Nathaniel Jones for pointing out errors)
Revision 1.24 - (view) (download) (annotate) - [selected]
Thu Jul 18 17:45:51 2019 UTC (4 years, 10 months ago) by greg
Changes since 1.23: +5 -1 lines
Diff to previous 1.23
Made -f more flexible accepting upper-case letters (byte-swapping doesn't matter)
Tue Jul 16 15:59:49 2019 UTC (4 years, 10 months ago) by greg
Changes since 1.22: +2 -1 lines
Diff to previous 1.22 , to selected 1.24
Made it so -t option sets newline if no character follows
Fri Jul 5 15:04:20 2019 UTC (4 years, 11 months ago) by greg
Changes since 1.21: +12 -4 lines
Diff to previous 1.21 , to selected 1.24
Improved error reporting and added newline after ASCII records
Fri Jul 5 00:46:23 2019 UTC (4 years, 11 months ago) by greg
Changes since 1.20: +6 -1 lines
Diff to previous 1.20 , to selected 1.24
Added check for premature end-of-data
Fri Jul 5 00:20:57 2019 UTC (4 years, 11 months ago) by greg
Changes since 1.19: +3 -9 lines
Diff to previous 1.19 , to selected 1.24
Thu Jul 4 17:36:04 2019 UTC (4 years, 11 months ago) by greg
Changes since 1.18: +30 -21 lines
Diff to previous 1.18 , to selected 1.24
Changed rlam -iaN behavior to read N lines rather than N characters
Thu Jul 4 16:51:03 2019 UTC (4 years, 11 months ago) by greg
Changes since 1.17: +7 -10 lines
Diff to previous 1.17 , to selected 1.24
Minor bug fix for Windoz -- was setting fixed-width ASCII input to binary output
Thu Aug 18 00:52:47 2016 UTC (7 years, 9 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 1.16: +4 -3 lines
Diff to previous 1.16 , to selected 1.24
Thu Mar 24 19:00:54 2016 UTC (8 years, 2 months ago) by greg
Diff to previous 1.15 , to selected 1.24
I guess I can't count...
Thu Mar 24 18:48:28 2016 UTC (8 years, 2 months ago) by greg
Changes since 1.14: +8 -3 lines
Diff to previous 1.14 , to selected 1.24
Added -in options to commands for manual EOF specification
Sun Mar 9 20:07:27 2014 UTC (10 years, 2 months ago) by greg
Changes since 1.13: +12 -2 lines
Diff to previous 1.13 , to selected 1.24
Added flockfile calls and fixed SET_FILE_BINARY usage for consistency
Tue Feb 11 17:05:00 2014 UTC (10 years, 3 months ago) by greg
Diff to previous 1.12 , to selected 1.24
Increased maximum line length to 64KB
Fri Jul 26 16:45:04 2013 UTC (10 years, 10 months ago) by greg
Changes since 1.11: +18 -12 lines
Diff to previous 1.11 , to selected 1.24
Improved handling of -iaN option and binary input from stdin
Fri Jun 18 21:22:49 2010 UTC (13 years, 11 months ago) by greg
Changes since 1.10: +25 -20 lines
Diff to previous 1.10 , to selected 1.24
Added -u option to rlam
Fri Jun 18 01:12:57 2010 UTC (13 years, 11 months ago) by greg
Changes since 1.9: +8 -2 lines
Diff to previous 1.9 , to selected 1.24
Modified rlam to use -iw option for 2-byte words and added -ii and -ib options
Sun May 7 15:44:28 2006 UTC (18 years, 1 month ago) by greg
Changes since 1.8: +9 -3 lines
Diff to previous 1.8 , to selected 1.24
Made missing calls to SET_FILE_BINARY() for Windows
Wed Oct 5 05:20:50 2005 UTC (18 years, 8 months ago) by greg
Changes since 1.7: +3 -1 lines
Diff to previous 1.7 , to selected 1.24
Made empty string default separator for binary input
Sun Sep 25 20:36:02 2005 UTC (18 years, 8 months ago) by greg
Changes since 1.6: +53 -7 lines
Diff to previous 1.6 , to selected 1.24
Added -i option to allow rlam to work with binary input records
Mon Jun 13 22:40:47 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.5: +6 -6 lines
Diff to previous 1.5 , to selected 1.24
Changed rlam -t option to accept strings as well as tab characters
Tue Dec 7 22:25:55 2004 UTC (19 years, 5 months ago) by greg
Diff to previous 1.4 , to selected 1.24
Increased file limit from 16 to 32
Fri Nov 14 17:31:24 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 1.3: +2 -1 lines
Diff to previous 1.3 , to selected 1.24
Reduced compile warnings.
Mon Oct 27 10:26:05 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 1.2: +2 -1 lines
Diff to previous 1.2 , to selected 1.24
Various compatibility fixes.
Sun Jun 8 12:03:09 2003 UTC (21 years ago) by schorsch
Changes since 1.1: +5 -1 lines
Diff to previous 1.1 , to selected 1.24
Sat Feb 22 02:07:20 2003 UTC (21 years, 3 months ago) by greg
Diff to selected 1.24
