root/radiance/ray/src/cal/lam.c
Sun Mar 9 20:07:27 2014 UTC (10 years, 1 month ago) by greg
Changes since 1.13: +12 -2 lines
Diff to previous 1.13 , to selected 1.7
Added flockfile calls and fixed SET_FILE_BINARY usage for consistency
Tue Feb 11 17:05:00 2014 UTC (10 years, 2 months ago) by greg
Diff to previous 1.12 , to selected 1.7
Increased maximum line length to 64KB
Fri Jul 26 16:45:04 2013 UTC (10 years, 8 months ago) by greg
Changes since 1.11: +18 -12 lines
Diff to previous 1.11 , to selected 1.7
Improved handling of -iaN option and binary input from stdin
Fri Jun 18 21:22:49 2010 UTC (13 years, 10 months ago) by greg
Changes since 1.10: +25 -20 lines
Diff to previous 1.10 , to selected 1.7
Added -u option to rlam
Fri Jun 18 01:12:57 2010 UTC (13 years, 10 months ago) by greg
Changes since 1.9: +8 -2 lines
Diff to previous 1.9 , to selected 1.7
Modified rlam to use -iw option for 2-byte words and added -ii and -ib options
Sun May 7 15:44:28 2006 UTC (17 years, 11 months ago) by greg
Changes since 1.8: +9 -3 lines
Diff to previous 1.8 , to selected 1.7
Made missing calls to SET_FILE_BINARY() for Windows
Wed Oct 5 05:20:50 2005 UTC (18 years, 6 months ago) by greg
Changes since 1.7: +3 -1 lines
Diff to previous 1.7
Made empty string default separator for binary input
Revision 1.7 - (view) (download) (annotate) - [selected]
Sun Sep 25 20:36:02 2005 UTC (18 years, 6 months ago) by greg
Changes since 1.6: +53 -7 lines
Diff to previous 1.6
Added -i option to allow rlam to work with binary input records
Mon Jun 13 22:40:47 2005 UTC (18 years, 10 months ago) by greg
Changes since 1.5: +6 -6 lines
Changed rlam -t option to accept strings as well as tab characters
Tue Dec 7 22:25:55 2004 UTC (19 years, 4 months ago) by greg
Increased file limit from 16 to 32
Fri Nov 14 17:31:24 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 1.3: +2 -1 lines
Reduced compile warnings.
Mon Oct 27 10:26:05 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 1.2: +2 -1 lines
Various compatibility fixes.
Sun Jun 8 12:03:09 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 1.1: +5 -1 lines
Sat Feb 22 02:07:20 2003 UTC (21 years, 2 months ago) by greg
Diff to selected 1.7
