root/radiance/ray/src/cal/lam.c
Sun May 7 15:44:28 2006 UTC (19 years, 2 months ago) by greg
Changes since 1.8: +9 -3 lines
Diff to previous 1.8
Made missing calls to SET_FILE_BINARY() for Windows
Revision 1.8 - (view) (download) (annotate) - [selected]
Wed Oct 5 05:20:50 2005 UTC (19 years, 9 months ago) by greg
Changes since 1.7: +3 -1 lines
Diff to previous 1.7
Made empty string default separator for binary input
Sun Sep 25 20:36:02 2005 UTC (19 years, 9 months ago) by greg
Changes since 1.6: +53 -7 lines
Diff to previous 1.6 , to selected 1.8
Added -i option to allow rlam to work with binary input records
Mon Jun 13 22:40:47 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.5: +6 -6 lines
Diff to previous 1.5 , to selected 1.8
Changed rlam -t option to accept strings as well as tab characters
Tue Dec 7 22:25:55 2004 UTC (20 years, 7 months ago) by greg
Diff to previous 1.4 , to selected 1.8
Increased file limit from 16 to 32
Fri Nov 14 17:31:24 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 1.3: +2 -1 lines
Diff to previous 1.3 , to selected 1.8
Reduced compile warnings.
Mon Oct 27 10:26:05 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 1.2: +2 -1 lines
Diff to previous 1.2 , to selected 1.8
Various compatibility fixes.
Sun Jun 8 12:03:09 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 1.1: +5 -1 lines
Diff to previous 1.1 , to selected 1.8
Sat Feb 22 02:07:20 2003 UTC (22 years, 4 months ago) by greg
Diff to selected 1.8
