root/Development/ray/src/cal/lam.c
Revision: 1.28
Committed: Thu Mar 6 20:19:03 2025 UTC (9 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 1.27: +4 -2 lines
Error occurred while calculating annotation data.
perf(rlam): Increased maximum input line width to 1 MByte
2 static const char RCSid[] = "$Id: lam.c,v 1.27 2025/02/06 19:52:05 greg Exp $";
5 * lam.c - simple program to laminate files.
6 *
7 * 7/14/88 Greg Ward
8 */
9
10 #include <ctype.h>
11
12 #include "rtio.h"
13 #include "platform.h"
14 #include "paths.h"
15
16 #ifndef MAXLINE
17 #define MAXLINE (1L<<20) /* maximum input line per stream */
18 #endif
19
20 struct instream { /* structure to hold input stream info */
21 FILE *input; /* input stream */
22 int bytsiz; /* bytes/component if binary */
23 char *tabc; /* data separation string */
24 } *rifile = NULL;
25
26 int nfiles = 0;
27
28 char buf[MAXLINE];
29
30 int
31 main(int argc, char *argv[])
32 {
33 long incnt = 0;
34 int unbuff = 0;
35 int binout = 0;
36 char *curtab = "\t";
37 int curbytes = 0;
38 int puteol;
39 int i;
40
41 rifile = (struct instream *)calloc(argc-1, sizeof(struct instream));
42 if (!rifile) {
43 fputs(argv[0], stderr);
44 fputs(": not enough memory\n", stderr);
45 return(1);
46 }
47 for (i = 1; i < argc; i++) {
48 if (argv[i][0] == '-') {
49 switch (argv[i][1]) {
50 case 't':
51 curtab = argv[i]+2;
52 if (!*curtab) curtab = "\n";
53 continue;
54 case 'u':
55 unbuff = !unbuff;
56 continue;
57 case 'i':
58 switch (argv[i][2]) {
59 case 'n':
60 incnt = atol(argv[++i]);
61 continue;
62 case 'f':
63 case 'F':
64 curbytes = sizeof(float);
65 break;
66 case 'd':
67 case 'D':
68 curbytes = sizeof(double);
69 break;
70 case 'i':
71 case 'I':
72 curbytes = sizeof(int);
73 break;
74 case 'w':
75 case 'W':
76 curbytes = 2;
77 break;
78 case 'b':
79 curbytes = 1;
80 break;
81 case 'a':
82 curbytes = argv[i][3] ? -1 : 0;
83 break;
84 default:
85 goto badopt;
86 }
87 if (isdigit(argv[i][3]))
88 curbytes *= atoi(argv[i]+3);
89 curbytes += (curbytes == -1);
90 if (curbytes > MAXLINE) {
91 fputs(argv[0], stderr);
92 fputs(": input size too big\n", stderr);
93 return(1);
94 }
95 if (curbytes > 0) {
96 curtab = "";
97 ++binout;
98 }
99 continue;
100 case '\0':
101 rifile[nfiles].tabc = curtab;
102 rifile[nfiles].input = stdin;
103 if (curbytes > 0)
104 SET_FILE_BINARY(rifile[nfiles].input);
105 rifile[nfiles++].bytsiz = curbytes;
106 continue;
107 badopt:;
108 default:
109 fputs(argv[0], stderr);
110 fputs(": unknown option '", stderr);
111 fputs(argv[i], stderr);
112 fputs("'\n", stderr);
113 return(1);
114 }
115 }
116 if (argv[i][0] == '!') {
117 rifile[nfiles].tabc = curtab;
118 if ((rifile[nfiles].input = popen(argv[i]+1, "r")) == NULL) {
119 fputs(argv[i], stderr);
120 fputs(": cannot start command\n", stderr);
121 return(1);
122 }
123 if (curbytes > 0)
124 SET_FILE_BINARY(rifile[nfiles].input);
125 rifile[nfiles++].bytsiz = curbytes;
126 } else {
127 rifile[nfiles].tabc = curtab;
128 if ((rifile[nfiles].input = fopen(argv[i], "r")) == NULL) {
129 fputs(argv[i], stderr);
130 fputs(": cannot open file\n", stderr);
131 return(1);
132 }
133 if (curbytes > 0)
134 SET_FILE_BINARY(rifile[nfiles].input);
135 rifile[nfiles++].bytsiz = curbytes;
136 }
137 }
138 if (!nfiles) {
139 fputs(argv[0], stderr);
140 fputs(": no input streams\n", stderr);
141 return(1);
142 } /* reduce array to size we need */
143 rifile = (struct instream *)realloc(rifile, nfiles*sizeof(struct instream));
144 if (!rifile) {
145 fputs(argv[0], stderr);
146 fputs(": realloc() failed!\n", stderr);
147 return(1);
148 }
149 if (binout) /* binary output? */
150 SET_FILE_BINARY(stdout);
151 #ifdef getc_unlocked /* avoid lock/unlock overhead */
152 for (i = nfiles; i--; )
153 flockfile(rifile[i].input);
154 flockfile(stdout);
155 #endif
156 puteol = 0; /* any ASCII output at all? */
157 for (i = nfiles; i--; )
158 puteol += (rifile[i].bytsiz <= 0);
159 do { /* main loop */
160 for (i = 0; i < nfiles; i++) {
161 if (rifile[i].bytsiz > 0) { /* binary input */
162 if (getbinary(buf, rifile[i].bytsiz, 1, rifile[i].input) < 1)
163 break;
164 if (putbinary(buf, rifile[i].bytsiz, 1, stdout) != 1)
165 break;
166 } else if (rifile[i].bytsiz < 0) { /* multi-line input */
167 int n = -rifile[i].bytsiz;
168 while (n--) {
169 if (fgets(buf, MAXLINE, rifile[i].input) == NULL)
170 break;
171 if ((i > 0) | (n < -rifile[i].bytsiz-1))
172 fputs(rifile[i].tabc, stdout);
173 buf[strlen(buf)-1] = '\0';
174 if (fputs(buf, stdout) == EOF)
175 break;
176 }
177 if (n >= 0) /* fell short? */
178 break;
179 } else { /* single-line input */
180 if (fgets(buf, MAXLINE, rifile[i].input) == NULL)
181 break;
182 if (i)
183 fputs(rifile[i].tabc, stdout);
184 buf[strlen(buf)-1] = '\0';
185 if (fputs(buf, stdout) == EOF)
186 break;
187 }
188 }
189 if (i < nfiles)
190 break;
191 if (puteol)
192 putchar('\n');
193 if (unbuff)
194 fflush(stdout);
195 } while (--incnt);
196 /* check ending */
197 if (fflush(stdout) == EOF) {
198 fputs(argv[0], stderr);
199 fputs(": write error on standard output\n", stderr);
200 return(1);
201 }
202 if (incnt > 0) {
203 fputs(argv[0], stderr);
204 fputs(": warning: premature EOD\n", stderr);
205 }
206 return(0);
207 }
