--- ray/src/cal/lam.c 2014/02/11 17:05:00 1.13 +++ ray/src/cal/lam.c 2019/07/04 17:36:04 1.19 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: lam.c,v 1.13 2014/02/11 17:05:00 greg Exp $"; +static const char RCSid[] = "$Id: lam.c,v 1.19 2019/07/04 17:36:04 greg Exp $"; #endif /* * lam.c - simple program to laminate files. @@ -14,6 +14,7 @@ static const char RCSid[] = "$Id: lam.c,v 1.13 2014/02 #include "platform.h" #include "rtprocess.h" +#include "rtio.h" #define MAXFILE 512 /* maximum number of files */ @@ -31,14 +32,14 @@ main(argc, argv) int argc; char *argv[]; { + long incnt = 0; int unbuff = 0; - int i; - char *curtab; - int curbytes; + int binout = 0; + char *curtab = "\t"; + int curbytes = 0; int puteol; + int i; - curtab = "\t"; - curbytes = 0; nfiles = 0; for (i = 1; i < argc; i++) { if (argv[i][0] == '-') { @@ -51,6 +52,9 @@ char *argv[]; break; case 'i': switch (argv[i][2]) { + case 'n': + incnt = atol(argv[++i]); + break; case 'f': curbytes = sizeof(float); break; @@ -74,75 +78,93 @@ char *argv[]; } if (isdigit(argv[i][3])) curbytes *= atoi(argv[i]+3); - if (abs(curbytes) > MAXLINE) { + curbytes += (curbytes == -1); + if (curbytes > MAXLINE) { fputs(argv[0], stderr); fputs(": input size too big\n", stderr); - exit(1); + return(1); } - if (curbytes) + if (curbytes > 0) { curtab = ""; + ++binout; + } break; case '\0': tabc[nfiles] = curtab; input[nfiles] = stdin; if (curbytes > 0) SET_FILE_BINARY(input[nfiles]); - else - curbytes = -curbytes; bytsiz[nfiles++] = curbytes; break; badopt:; default: fputs(argv[0], stderr); fputs(": bad option\n", stderr); - exit(1); + return(1); } } else if (argv[i][0] == '!') { tabc[nfiles] = curtab; if ((input[nfiles] = popen(argv[i]+1, "r")) == NULL) { fputs(argv[i], stderr); fputs(": cannot start command\n", stderr); - exit(1); + return(1); } if (curbytes > 0) SET_FILE_BINARY(input[nfiles]); - else - curbytes = -curbytes; bytsiz[nfiles++] = curbytes; } else { tabc[nfiles] = curtab; if ((input[nfiles] = fopen(argv[i], "r")) == NULL) { fputs(argv[i], stderr); fputs(": cannot open file\n", stderr); - exit(1); + return(1); } if (curbytes > 0) SET_FILE_BINARY(input[nfiles]); - else - curbytes = -curbytes; bytsiz[nfiles++] = curbytes; } if (nfiles >= MAXFILE) { fputs(argv[0], stderr); fputs(": too many input streams\n", stderr); - exit(1); + return(1); } } - puteol = 0; /* check for ASCII output */ + if (!nfiles) { + fputs(argv[0], stderr); + fputs(": no input streams\n", stderr); + return(1); + } + if (binout) /* binary output? */ + SET_FILE_BINARY(stdout); +#ifdef getc_unlocked /* avoid lock/unlock overhead */ for (i = nfiles; i--; ) - if (!bytsiz[i] || isprint(tabc[i][0]) || tabc[i][0] == '\t') { - puteol++; - break; - } - for ( ; ; ) { /* main loop */ + flockfile(input[i]); + flockfile(stdout); +#endif + puteol = 0; /* any ASCII output at all? */ + for (i = nfiles; i--; ) + puteol += (bytsiz[i] <= 0); + do { /* main loop */ for (i = 0; i < nfiles; i++) { - if (bytsiz[i]) { /* binary file */ - if (fread(buf, bytsiz[i], 1, input[i]) < 1) + if (bytsiz[i] > 0) { /* binary input */ + if (getbinary(buf, bytsiz[i], 1, input[i]) < 1) break; if (i) fputs(tabc[i], stdout); - fwrite(buf, bytsiz[i], 1, stdout); - } else { + putbinary(buf, bytsiz[i], 1, stdout); + } else if (bytsiz[i] < 0) { /* multi-line input */ + int n = -bytsiz[i]; + while (n--) { + if (fgets(buf, MAXLINE, input[i]) == NULL) + break; + if ((i > 0) | (n < -bytsiz[i]-1)) + fputs(tabc[i], stdout); + buf[strlen(buf)-1] = '\0'; + fputs(buf, stdout); + } + if (n >= 0) /* fell short? */ + break; + } else { /* single-line input */ if (fgets(buf, MAXLINE, input[i]) == NULL) break; if (i) @@ -157,6 +179,6 @@ char *argv[]; putchar('\n'); if (unbuff) fflush(stdout); - } + } while (--incnt); return(0); }
