--- ray/src/cal/lam.c 2016/08/18 00:52:47 1.17 +++ ray/src/cal/lam.c 2019/07/05 00:46:23 1.21 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: lam.c,v 1.17 2016/08/18 00:52:47 greg Exp $"; +static const char RCSid[] = "$Id: lam.c,v 1.21 2019/07/05 00:46:23 greg Exp $"; #endif /* * lam.c - simple program to laminate files. @@ -13,37 +13,30 @@ static const char RCSid[] = "$Id: lam.c,v 1.17 2016/08 #include #include "platform.h" -#include "rtprocess.h" #include "rtio.h" #define MAXFILE 512 /* maximum number of files */ #define MAXLINE 65536 /* maximum input line */ -long incnt = 0; /* limit number of records? */ - FILE *input[MAXFILE]; int bytsiz[MAXFILE]; char *tabc[MAXFILE]; -int nfiles; +int nfiles = 0; char buf[MAXLINE]; int -main(argc, argv) -int argc; -char *argv[]; +main(int argc, char *argv[]) { + long incnt = 0; int unbuff = 0; int binout = 0; - int i; - char *curtab; - int curbytes; + char *curtab = "\t"; + int curbytes = 0; int puteol; + int i; - curtab = "\t"; - curbytes = 0; - nfiles = 0; for (i = 1; i < argc; i++) { if (argv[i][0] == '-') { switch (argv[i][1]) { @@ -81,12 +74,13 @@ char *argv[]; } if (isdigit(argv[i][3])) curbytes *= atoi(argv[i]+3); - if (abs(curbytes) > MAXLINE) { + curbytes += (curbytes == -1); + if (curbytes > MAXLINE) { fputs(argv[0], stderr); fputs(": input size too big\n", stderr); - exit(1); + return(1); } - if (curbytes) { + if (curbytes > 0) { curtab = ""; ++binout; } @@ -96,47 +90,46 @@ char *argv[]; input[nfiles] = stdin; if (curbytes > 0) SET_FILE_BINARY(input[nfiles]); - else - curbytes = -curbytes; bytsiz[nfiles++] = curbytes; break; badopt:; default: fputs(argv[0], stderr); fputs(": bad option\n", stderr); - exit(1); + return(1); } } else if (argv[i][0] == '!') { tabc[nfiles] = curtab; if ((input[nfiles] = popen(argv[i]+1, "r")) == NULL) { fputs(argv[i], stderr); fputs(": cannot start command\n", stderr); - exit(1); + return(1); } if (curbytes > 0) SET_FILE_BINARY(input[nfiles]); - else - curbytes = -curbytes; bytsiz[nfiles++] = curbytes; } else { tabc[nfiles] = curtab; if ((input[nfiles] = fopen(argv[i], "r")) == NULL) { fputs(argv[i], stderr); fputs(": cannot open file\n", stderr); - exit(1); + return(1); } if (curbytes > 0) SET_FILE_BINARY(input[nfiles]); - else - curbytes = -curbytes; bytsiz[nfiles++] = curbytes; } if (nfiles >= MAXFILE) { fputs(argv[0], stderr); fputs(": too many input streams\n", stderr); - exit(1); + return(1); } } + if (!nfiles) { + fputs(argv[0], stderr); + fputs(": no input streams\n", stderr); + return(1); + } if (binout) /* binary output? */ SET_FILE_BINARY(stdout); #ifdef getc_unlocked /* avoid lock/unlock overhead */ @@ -146,19 +139,26 @@ char *argv[]; #endif puteol = 0; /* any ASCII output at all? */ for (i = nfiles; i--; ) - if (!bytsiz[i] || isprint(tabc[i][0]) || tabc[i][0] == '\t') { - puteol++; - break; - } + puteol += (bytsiz[i] <= 0); do { /* main loop */ for (i = 0; i < nfiles; i++) { - if (bytsiz[i]) { /* binary file */ + if (bytsiz[i] > 0) { /* binary input */ if (getbinary(buf, bytsiz[i], 1, input[i]) < 1) break; - if (i) - fputs(tabc[i], stdout); putbinary(buf, bytsiz[i], 1, stdout); - } else { + } else if (bytsiz[i] < 0) { /* multi-line input */ + int n = -bytsiz[i]; + while (n--) { + if (fgets(buf, MAXLINE, input[i]) == NULL) + break; + if ((i > 0) | (n < -bytsiz[i]-1)) + fputs(tabc[i], stdout); + buf[strlen(buf)-1] = '\0'; + fputs(buf, stdout); + } + if (n >= 0) /* fell short? */ + break; + } else { /* single-line input */ if (fgets(buf, MAXLINE, input[i]) == NULL) break; if (i) @@ -174,5 +174,10 @@ char *argv[]; if (unbuff) fflush(stdout); } while (--incnt); + /* check ending */ + if (incnt > 0) { + fputs(argv[0], stderr); + fputs(": warning: premature EOD\n", stderr); + } return(0); }
