feature(rsplit,rlam): Modified to allow any number of files up to system limit
Windows cleaning (thanks to Nathaniel Jones for pointing out errors)
Made -f more flexible accepting upper-case letters (byte-swapping doesn't matter)
Made it so -t option sets newline if no character follows
Improved error reporting and added newline after ASCII records
Added check for premature end-of-data
Changed rlam -iaN behavior to read N lines rather than N characters
Minor bug fix for Windoz -- was setting fixed-width ASCII input to binary output
I guess I can't count...
Added -in options to commands for manual EOF specification
Added flockfile calls and fixed SET_FILE_BINARY usage for consistency
Increased maximum line length to 64KB
Improved handling of -iaN option and binary input from stdin
Added -u option to rlam
Modified rlam to use -iw option for 2-byte words and added -ii and -ib options
Made missing calls to SET_FILE_BINARY() for Windows
Made empty string default separator for binary input
Added -i option to allow rlam to work with binary input records
Changed rlam -t option to accept strings as well as tab characters
Increased file limit from 16 to 32
Reduced compile warnings.
Various compatibility fixes.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
