root/radiance/ray/src/cal/histo.c
Mon Mar 6 19:31:30 2023 UTC (2 years, 2 months ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 1.5
fix(histo): Include lowest value in range
Fri Apr 18 16:32:27 2008 UTC (17 years ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Diff to previous 1.4
Changed maximum number of input columns to more generous 2K
Sun Dec 14 16:33:37 2003 UTC (21 years, 4 months ago) by greg
Changes since 1.3: +46 -17 lines
Diff to previous 1.3
Added -p option to histo to report percentiles and changed output slightly
Sun Jul 27 22:12:01 2003 UTC (21 years, 9 months ago) by schorsch
Diff to previous 1.2
Sun Jun 8 12:03:09 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 1.1: +54 -46 lines
Diff to previous 1.1
Sat Feb 22 02:07:20 2003 UTC (22 years, 2 months ago) by greg
