root/radiance/ray/src/cal/ev.c
Thu Sep 11 05:34:47 2008 UTC (15 years, 7 months ago) by greg
CVS Tags: rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Changes since 1.6: +4 -1 lines
Diff to previous 1.6 , to selected 1.5
Avoid returning error on spurious errno settings
Fri Nov 14 17:31:24 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 1.5: +3 -1 lines
Diff to previous 1.5
Reduced compile warnings.
Tue Oct 14 16:46:20 2003 UTC (20 years, 6 months ago) by greg
Changes since 1.4: +1 -2 lines
Diff to previous 1.4
Removed errno declaration that was causing fits on some systems
Wed Aug 20 09:30:16 2003 UTC (20 years, 8 months ago) by schorsch
Changes since 1.3: +2 -1 lines
Added include for errno.h.
Changes since 1.2: +2 -1 lines
Sun Jun 8 12:03:09 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 1.1: +2 -1 lines
Sat Feb 22 02:07:20 2003 UTC (21 years, 2 months ago) by greg
Diff to selected 1.5
