root/radiance/ray/src/cal/cnt.c
Fri Apr 22 15:52:50 2022 UTC (3 years ago) by greg
Diff to previous 1.7
fix(cnt): Reversed sense of new test -- whoops!
Fri Apr 22 15:50:34 2022 UTC (3 years ago) by greg
Changes since 1.6: +6 -4 lines
Diff to previous 1.6
fix(cnt): Added extra check for occupancy counter overflow
Thu Apr 21 02:52:40 2022 UTC (3 years ago) by greg
Changes since 1.5: +3 -3 lines
Diff to previous 1.5
perf(cnt): improved randomness of cnt -s option with new irandom(modulus) call
Wed Apr 20 20:56:01 2022 UTC (3 years ago) by greg
Changes since 1.4: +11 -11 lines
Diff to previous 1.4
perf(cnt): Minor optimization on -s mode
Wed Apr 20 19:13:12 2022 UTC (3 years ago) by greg
Changes since 1.3: +191 -44 lines
Diff to previous 1.3
perf(cnt): Added memory-efficient large array shuffle (up to 2 billion entries)
Mon Apr 11 18:08:19 2022 UTC (3 years ago) by greg
Changes since 1.2: +97 -26 lines
Diff to previous 1.2
feat(cnt): Added -s option to shuffle output
Sun Jun 8 12:03:09 2003 UTC (21 years, 10 months ago) by schorsch
CVS Tags: rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Changes since 1.1: +17 -10 lines
Diff to previous 1.1
Sat Feb 22 02:07:20 2003 UTC (22 years, 2 months ago) by greg
