root/radiance/ray/src/cal/cnt.c
Revision: 1.9
Committed: Thu Feb 27 20:00:35 2025 UTC (3 months, 3 weeks ago) by greg
Changes since 1.8: +4 -2 lines
perf(cnt): Added flockfile(stdout) call to reduce i/o locking overhead
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 1.9 static const char RCSid[] = "$Id: cnt.c,v 1.8 2022/04/22 15:52:50 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * cnt.c - simple counting program.
6     *
7     * 2/1/88
8 greg 1.3 *
9     * Added -s (shuffle) option April 2022
10 greg 1.1 */
11
12     #include <stdio.h>
13 greg 1.3 #include <time.h>
14     #include "random.h"
15 greg 1.1
16 greg 1.4 #ifndef uint16
17     #define uint16 unsigned short /* 16-bit unsigned integer */
18     #endif
19     #undef uby8
20     #define uby8 unsigned char /* 8-bit unsigned integer */
21
22 greg 1.3 #define MAXDIM 50
23 greg 1.1
24 greg 1.4 #define NLEVELS 9 /* number of tree levels */
25     #define BRORDER 6 /* branches/level */
26
27     /* Tree branch structure for quick occupancy search */
28     /* with 9 levels & 6 branches per level, we can store 1.94 Gbits in 259 MBytes (4.5% overhead) */
29     const struct {
30     long capacity; /* slots/branch this level */
31     long skip_bytes; /* bytes until next branch */
32     int cntr_siz; /* occupancy counter size */
33     } tree_br[NLEVELS] = {
34     {248L, 32L, 1},
35     {248L*6, 32L*6+2, 2},
36     {248L*6*6, (32L*6+2)*6+2, 2},
37     {248L*6*6*6, ((32L*6+2)*6+2)*6+2, 2},
38     {248L*6*6*6*6, (((32L*6+2)*6+2)*6+2)*6+3, 3},
39     {248L*6*6*6*6*6, ((((32L*6+2)*6+2)*6+2)*6+3)*6+3, 3},
40     {248L*6*6*6*6*6*6, (((((32L*6+2)*6+2)*6+2)*6+3)*6+3)*6+3, 3},
41     {248L*6*6*6*6*6*6*6, ((((((32L*6+2)*6+2)*6+2)*6+3)*6+3)*6+3)*6+4, 4},
42     {248L*6*6*6*6*6*6*6*6, (((((((32L*6+2)*6+2)*6+2)*6+3)*6+3)*6+3)*6+4)*6+4, 4},
43     };
44
45     char buf[256]; /* buffer for ordered array output */
46 greg 1.1
47
48 greg 1.3 /* Encode integer in string and return pointer to end */
49     static char *
50 greg 1.4 tack(char *b, long i)
51 greg 1.1 {
52 greg 1.3 char *cp;
53 greg 1.1 char *res;
54
55     *b++ = '\t';
56     cp = b;
57     if (i == 0)
58     *cp++ = '0';
59     else
60     do {
61 greg 1.4 *cp++ = i%10L + '0';
62     i /= 10L;
63 greg 1.1 } while (i);
64     res = cp--;
65     #define c i
66     while (cp > b) { /* reverse string */
67     c = *cp;
68     *cp-- = *b;
69     *b++ = c;
70     }
71     #undef c
72     return(res);
73     }
74
75
76 greg 1.3 /* Loop over dimensions, spitting out buffer after each increment */
77 schorsch 1.2 static void
78 greg 1.4 loop(long *n, char *b)
79 greg 1.1 {
80 greg 1.4 long i;
81 greg 1.1
82     if (n[0] == 0) {
83     *b = '\0';
84     puts(buf);
85     return;
86     }
87     for (i = 0; i < n[0]; i++)
88     loop(n+1, tack(b, i));
89     }
90 greg 1.3
91
92 greg 1.4 /* Print out shuffled value */
93     static void
94     print_shuf(long *n, long aval)
95     {
96     int i;
97
98     for (i = 0; n[i+1]; i++) {
99     printf("\t%ld", aval % n[i]);
100     aval /= n[i];
101     }
102     printf("\t%ld\n", aval);
103     }
104
105
106     /* Allocate and prepare occupancy tree */
107     static uby8 *
108     tree_alloc(long alen)
109     {
110     uby8 *troot;
111     double bytes_per_bit;
112     int i;
113     int ht = 0;
114     /* how tall does our tree need to be? */
115     while (tree_br[ht].capacity*BRORDER < alen)
116     if (++ht >= NLEVELS) {
117     fputs("Array too large to shuffle\n", stderr);
118     exit(1);
119     }
120     bytes_per_bit = 1.; /* figure out tree size (with overhead) */
121     for (i = ht; i >= 0; i--)
122     bytes_per_bit += (double)tree_br[i].cntr_siz;
123     bytes_per_bit += (double)tree_br[ht].skip_bytes;
124     bytes_per_bit /= (double)tree_br[ht].capacity;
125     troot = (uby8 *)calloc((long)(alen*bytes_per_bit)+2, 1);
126     if (troot == NULL) {
127     fputs("Not enough memory for shuffle\n", stderr);
128     exit(1);
129     }
130     *troot = ht; /* first byte is tree height */
131 greg 1.5 for (i = 256; i--; ) { /* assign 0-bit count table */
132 greg 1.4 int b;
133 greg 1.5 buf[i] = 8;
134 greg 1.4 for (b = i; b; b >>= 1)
135 greg 1.5 buf[i] -= b&1;
136 greg 1.4 }
137     return(troot);
138     }
139
140
141     /* Get number of slots available at this branch location */
142     static long
143     get_avail(const uby8 *ctrp, int lvl)
144     {
145     long cnt = 0;
146     int n = tree_br[lvl].cntr_siz;
147
148     while (--n > 0) { /* LSB first */
149     cnt |= ctrp[n];
150     cnt <<= 8;
151     }
152     cnt |= ctrp[0];
153
154     return(tree_br[lvl].capacity - cnt);
155     }
156
157
158     /* Increment branch occupancy counter */
159     static void
160     incr_counter(uby8 *ctrp, int n)
161     {
162     n = tree_br[n].cntr_siz;
163
164 greg 1.8 while (! ++(*ctrp++)) /* LSB first */
165 greg 1.7 if (--n <= 0) {
166     fputs("Shuffle occupancy overflow!\n", stderr);
167     exit(1); /* means we sized something wrong */
168     }
169 greg 1.4 }
170
171
172     /* Skip to and allocate a leaf from tree */
173     static long
174     eat_nth_leaf(uby8 *brp, long ski)
175     {
176     int lvl = *brp++; /* tree height in first byte */
177     long pos = 0;
178     int b;
179
180     while (lvl >= 0) { /* descend to leaves */
181     long navail;
182     b = 0; /* select each branch */
183     while (ski >= (navail = get_avail(brp, lvl))) {
184     if (++b >= BRORDER) {
185     fputs("Shuffle tree error!\n", stderr);
186     exit(1);
187     }
188     pos += tree_br[lvl].capacity;
189     ski -= navail;
190     brp += tree_br[lvl].skip_bytes;
191     }
192     incr_counter(brp, lvl); /* we intend to eat one */
193     brp += tree_br[lvl--].cntr_siz; /* drop a level */
194     }
195 greg 1.5 while (ski >= buf[*brp]) { /* browse the leaves */
196 greg 1.4 pos += 8;
197 greg 1.5 ski -= buf[*brp++]; /* buf contains 0-bit counts */
198 greg 1.4 }
199 greg 1.5 b = 0; /* find target bit in byte */
200     while ((ski -= !(*brp & 1<<b)) >= 0) {
201 greg 1.4 pos++;
202 greg 1.5 b++;
203 greg 1.4 }
204 greg 1.5 *brp |= 1<<b; /* eat it */
205     return(pos); /* & return leaf's slot# */
206 greg 1.4 }
207
208
209     /* Shuffle all possible output strings and spit out randomly (tree version) */
210     static void
211     big_shuffle(long *n, long alen)
212     {
213     uby8 *tree_root;
214     /* size and allocate holder tree */
215     tree_root = tree_alloc(alen);
216
217     while (alen > 0) /* allocate and print random array entries */
218 greg 1.6 print_shuf(n, eat_nth_leaf(tree_root, irandom(alen--)));
219 greg 1.4
220     free(tree_root); /* all done */
221     }
222
223
224 greg 1.3 /* Shuffle all possible output strings and spit out randomly */
225     static void
226 greg 1.4 shuffle(long *n)
227     {
228     long alen;
229     uint16 *myshuf;
230     int i;
231
232     alen = 1; /* compute shuffle size */
233     for (i = 0; n[i]; i++) {
234     if (alen*n[i] <= alen) {
235     fputs("Array too large to count!\n", stderr);
236 greg 1.3 exit(1);
237 greg 1.4 }
238     alen *= n[i];
239     }
240     /* get unique starting point */
241     srandom((long)time(0));
242 greg 1.3
243 greg 1.4 if (alen > 1L<<16) { /* use large shuffle method? */
244     big_shuffle(n, alen);
245     return;
246     }
247     myshuf = (uint16 *)malloc(alen*sizeof(uint16));
248 greg 1.3 if (myshuf == NULL) {
249     fputs("Insufficient memory for shuffle\n", stderr);
250     exit(1);
251     }
252     for (i = alen; i--; ) /* initialize in any order */
253     myshuf[i] = i;
254     /* perform Fisher-Yates shuffle */
255     for (i = 0; i < alen-1; i++) {
256 greg 1.6 int ix = irandom(alen-i) + i;
257 greg 1.3 int ndx = myshuf[i];
258     myshuf[i] = myshuf[ix];
259     myshuf[ix] = ndx;
260     }
261     /* put randomly indexed output */
262 greg 1.4 for (i = alen; i--; )
263     print_shuf(n, (long)myshuf[i]);
264
265     free(myshuf); /* all done */
266 greg 1.3 }
267
268
269     int
270 greg 1.4 main(int argc, char *argv[])
271 greg 1.3 {
272     char *prog = argv[0];
273     int doshuffle = 0;
274 greg 1.4 long n[MAXDIM];
275 greg 1.3 int a;
276
277     argv++; argc--;
278     if (argc <= 0)
279     goto userr;
280     if (argv[0][0] == '-' && argv[0][1] == 's') {
281     doshuffle = 1;
282     argv++; argc--;
283     }
284     for (a = 0; a < argc; a++)
285 greg 1.4 if ((n[a] = atol(argv[a])) <= 1)
286 greg 1.3 goto userr;
287     n[a] = 0;
288     if (!a)
289     goto userr;
290 greg 1.9 #ifdef getc_unlocked
291     flockfile(stdout); /* avoid overhead */
292     #endif
293 greg 1.3 if (doshuffle)
294     shuffle(n);
295     else
296     loop(n, buf);
297
298     return(0);
299     userr:
300     fputs("Usage: ", stderr);
301     fputs(prog, stderr);
302     fputs(" [-s] N0 [N1 ..]\n", stderr);
303     return(1);
304     }
