1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: cnt.c,v 1.6 2022/04/21 02:52:40 greg Exp $"; |
3 |
#endif |
4 |
5 |
* cnt.c - simple counting program. |
6 |
7 |
* 2/1/88 |
8 |
9 |
* Added -s (shuffle) option April 2022 |
10 |
11 |
12 |
#include <stdio.h> |
13 |
#include <time.h> |
14 |
#include "random.h" |
15 |
16 |
#ifndef uint16 |
17 |
#define uint16 unsigned short /* 16-bit unsigned integer */ |
18 |
#endif |
19 |
#undef uby8 |
20 |
#define uby8 unsigned char /* 8-bit unsigned integer */ |
21 |
22 |
#define MAXDIM 50 |
23 |
24 |
#define NLEVELS 9 /* number of tree levels */ |
25 |
#define BRORDER 6 /* branches/level */ |
26 |
27 |
/* Tree branch structure for quick occupancy search */ |
28 |
/* with 9 levels & 6 branches per level, we can store 1.94 Gbits in 259 MBytes (4.5% overhead) */ |
29 |
const struct { |
30 |
long capacity; /* slots/branch this level */ |
31 |
long skip_bytes; /* bytes until next branch */ |
32 |
int cntr_siz; /* occupancy counter size */ |
33 |
} tree_br[NLEVELS] = { |
34 |
{248L, 32L, 1}, |
35 |
{248L*6, 32L*6+2, 2}, |
36 |
{248L*6*6, (32L*6+2)*6+2, 2}, |
37 |
{248L*6*6*6, ((32L*6+2)*6+2)*6+2, 2}, |
38 |
{248L*6*6*6*6, (((32L*6+2)*6+2)*6+2)*6+3, 3}, |
39 |
{248L*6*6*6*6*6, ((((32L*6+2)*6+2)*6+2)*6+3)*6+3, 3}, |
40 |
{248L*6*6*6*6*6*6, (((((32L*6+2)*6+2)*6+2)*6+3)*6+3)*6+3, 3}, |
41 |
{248L*6*6*6*6*6*6*6, ((((((32L*6+2)*6+2)*6+2)*6+3)*6+3)*6+3)*6+4, 4}, |
42 |
{248L*6*6*6*6*6*6*6*6, (((((((32L*6+2)*6+2)*6+2)*6+3)*6+3)*6+3)*6+4)*6+4, 4}, |
43 |
44 |
45 |
char buf[256]; /* buffer for ordered array output */ |
46 |
47 |
48 |
/* Encode integer in string and return pointer to end */ |
49 |
static char * |
50 |
tack(char *b, long i) |
51 |
52 |
char *cp; |
53 |
char *res; |
54 |
55 |
*b++ = '\t'; |
56 |
cp = b; |
57 |
if (i == 0) |
58 |
*cp++ = '0'; |
59 |
else |
60 |
do { |
61 |
*cp++ = i%10L + '0'; |
62 |
i /= 10L; |
63 |
} while (i); |
64 |
res = cp--; |
65 |
#define c i |
66 |
while (cp > b) { /* reverse string */ |
67 |
c = *cp; |
68 |
*cp-- = *b; |
69 |
*b++ = c; |
70 |
71 |
#undef c |
72 |
return(res); |
73 |
74 |
75 |
76 |
/* Loop over dimensions, spitting out buffer after each increment */ |
77 |
static void |
78 |
loop(long *n, char *b) |
79 |
80 |
long i; |
81 |
82 |
if (n[0] == 0) { |
83 |
*b = '\0'; |
84 |
puts(buf); |
85 |
return; |
86 |
87 |
for (i = 0; i < n[0]; i++) |
88 |
loop(n+1, tack(b, i)); |
89 |
90 |
91 |
92 |
/* Print out shuffled value */ |
93 |
static void |
94 |
print_shuf(long *n, long aval) |
95 |
96 |
int i; |
97 |
98 |
for (i = 0; n[i+1]; i++) { |
99 |
printf("\t%ld", aval % n[i]); |
100 |
aval /= n[i]; |
101 |
102 |
printf("\t%ld\n", aval); |
103 |
104 |
105 |
106 |
/* Allocate and prepare occupancy tree */ |
107 |
static uby8 * |
108 |
tree_alloc(long alen) |
109 |
110 |
uby8 *troot; |
111 |
double bytes_per_bit; |
112 |
int i; |
113 |
int ht = 0; |
114 |
/* how tall does our tree need to be? */ |
115 |
while (tree_br[ht].capacity*BRORDER < alen) |
116 |
if (++ht >= NLEVELS) { |
117 |
fputs("Array too large to shuffle\n", stderr); |
118 |
exit(1); |
119 |
120 |
bytes_per_bit = 1.; /* figure out tree size (with overhead) */ |
121 |
for (i = ht; i >= 0; i--) |
122 |
bytes_per_bit += (double)tree_br[i].cntr_siz; |
123 |
bytes_per_bit += (double)tree_br[ht].skip_bytes; |
124 |
bytes_per_bit /= (double)tree_br[ht].capacity; |
125 |
troot = (uby8 *)calloc((long)(alen*bytes_per_bit)+2, 1); |
126 |
if (troot == NULL) { |
127 |
fputs("Not enough memory for shuffle\n", stderr); |
128 |
exit(1); |
129 |
130 |
*troot = ht; /* first byte is tree height */ |
131 |
for (i = 256; i--; ) { /* assign 0-bit count table */ |
132 |
int b; |
133 |
buf[i] = 8; |
134 |
for (b = i; b; b >>= 1) |
135 |
buf[i] -= b&1; |
136 |
137 |
return(troot); |
138 |
139 |
140 |
141 |
/* Get number of slots available at this branch location */ |
142 |
static long |
143 |
get_avail(const uby8 *ctrp, int lvl) |
144 |
145 |
long cnt = 0; |
146 |
int n = tree_br[lvl].cntr_siz; |
147 |
148 |
while (--n > 0) { /* LSB first */ |
149 |
cnt |= ctrp[n]; |
150 |
cnt <<= 8; |
151 |
152 |
cnt |= ctrp[0]; |
153 |
154 |
return(tree_br[lvl].capacity - cnt); |
155 |
156 |
157 |
158 |
/* Increment branch occupancy counter */ |
159 |
static void |
160 |
incr_counter(uby8 *ctrp, int n) |
161 |
162 |
n = tree_br[n].cntr_siz; |
163 |
164 |
while (++(*ctrp++)) /* LSB first */ |
165 |
if (--n <= 0) { |
166 |
fputs("Shuffle occupancy overflow!\n", stderr); |
167 |
exit(1); /* means we sized something wrong */ |
168 |
169 |
170 |
171 |
172 |
/* Skip to and allocate a leaf from tree */ |
173 |
static long |
174 |
eat_nth_leaf(uby8 *brp, long ski) |
175 |
176 |
int lvl = *brp++; /* tree height in first byte */ |
177 |
long pos = 0; |
178 |
int b; |
179 |
180 |
while (lvl >= 0) { /* descend to leaves */ |
181 |
long navail; |
182 |
b = 0; /* select each branch */ |
183 |
while (ski >= (navail = get_avail(brp, lvl))) { |
184 |
if (++b >= BRORDER) { |
185 |
fputs("Shuffle tree error!\n", stderr); |
186 |
exit(1); |
187 |
188 |
pos += tree_br[lvl].capacity; |
189 |
ski -= navail; |
190 |
brp += tree_br[lvl].skip_bytes; |
191 |
192 |
incr_counter(brp, lvl); /* we intend to eat one */ |
193 |
brp += tree_br[lvl--].cntr_siz; /* drop a level */ |
194 |
195 |
while (ski >= buf[*brp]) { /* browse the leaves */ |
196 |
pos += 8; |
197 |
ski -= buf[*brp++]; /* buf contains 0-bit counts */ |
198 |
199 |
b = 0; /* find target bit in byte */ |
200 |
while ((ski -= !(*brp & 1<<b)) >= 0) { |
201 |
pos++; |
202 |
b++; |
203 |
204 |
*brp |= 1<<b; /* eat it */ |
205 |
return(pos); /* & return leaf's slot# */ |
206 |
207 |
208 |
209 |
/* Shuffle all possible output strings and spit out randomly (tree version) */ |
210 |
static void |
211 |
big_shuffle(long *n, long alen) |
212 |
213 |
uby8 *tree_root; |
214 |
/* size and allocate holder tree */ |
215 |
tree_root = tree_alloc(alen); |
216 |
217 |
while (alen > 0) /* allocate and print random array entries */ |
218 |
print_shuf(n, eat_nth_leaf(tree_root, irandom(alen--))); |
219 |
220 |
free(tree_root); /* all done */ |
221 |
222 |
223 |
224 |
/* Shuffle all possible output strings and spit out randomly */ |
225 |
static void |
226 |
shuffle(long *n) |
227 |
228 |
long alen; |
229 |
uint16 *myshuf; |
230 |
int i; |
231 |
232 |
alen = 1; /* compute shuffle size */ |
233 |
for (i = 0; n[i]; i++) { |
234 |
if (alen*n[i] <= alen) { |
235 |
fputs("Array too large to count!\n", stderr); |
236 |
exit(1); |
237 |
238 |
alen *= n[i]; |
239 |
240 |
/* get unique starting point */ |
241 |
srandom((long)time(0)); |
242 |
243 |
if (alen > 1L<<16) { /* use large shuffle method? */ |
244 |
big_shuffle(n, alen); |
245 |
return; |
246 |
247 |
myshuf = (uint16 *)malloc(alen*sizeof(uint16)); |
248 |
if (myshuf == NULL) { |
249 |
fputs("Insufficient memory for shuffle\n", stderr); |
250 |
exit(1); |
251 |
252 |
for (i = alen; i--; ) /* initialize in any order */ |
253 |
myshuf[i] = i; |
254 |
/* perform Fisher-Yates shuffle */ |
255 |
for (i = 0; i < alen-1; i++) { |
256 |
int ix = irandom(alen-i) + i; |
257 |
int ndx = myshuf[i]; |
258 |
myshuf[i] = myshuf[ix]; |
259 |
myshuf[ix] = ndx; |
260 |
261 |
/* put randomly indexed output */ |
262 |
for (i = alen; i--; ) |
263 |
print_shuf(n, (long)myshuf[i]); |
264 |
265 |
free(myshuf); /* all done */ |
266 |
267 |
268 |
269 |
int |
270 |
main(int argc, char *argv[]) |
271 |
272 |
char *prog = argv[0]; |
273 |
int doshuffle = 0; |
274 |
long n[MAXDIM]; |
275 |
int a; |
276 |
277 |
argv++; argc--; |
278 |
if (argc <= 0) |
279 |
goto userr; |
280 |
if (argv[0][0] == '-' && argv[0][1] == 's') { |
281 |
doshuffle = 1; |
282 |
argv++; argc--; |
283 |
284 |
for (a = 0; a < argc; a++) |
285 |
if ((n[a] = atol(argv[a])) <= 1) |
286 |
goto userr; |
287 |
n[a] = 0; |
288 |
if (!a) |
289 |
goto userr; |
290 |
291 |
if (doshuffle) |
292 |
shuffle(n); |
293 |
else |
294 |
loop(n, buf); |
295 |
296 |
return(0); |
297 |
userr: |
298 |
fputs("Usage: ", stderr); |
299 |
fputs(prog, stderr); |
300 |
fputs(" [-s] N0 [N1 ..]\n", stderr); |
301 |
return(1); |
302 |
