| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: cnt.c,v 1.5 2022/04/20 20:56:01 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* cnt.c - simple counting program.
| 6 |
| 7 |
* 2/1/88
| 8 |
| 9 |
* Added -s (shuffle) option April 2022
| 10 |
| 11 |
| 12 |
#include <stdio.h>
| 13 |
#include <time.h>
| 14 |
#include "random.h"
| 15 |
| 16 |
#ifndef uint16
| 17 |
#define uint16 unsigned short /* 16-bit unsigned integer */
| 18 |
#endif
| 19 |
#undef uby8
| 20 |
#define uby8 unsigned char /* 8-bit unsigned integer */
| 21 |
| 22 |
#define MAXDIM 50
| 23 |
| 24 |
#define NLEVELS 9 /* number of tree levels */
| 25 |
#define BRORDER 6 /* branches/level */
| 26 |
| 27 |
/* Tree branch structure for quick occupancy search */
| 28 |
/* with 9 levels & 6 branches per level, we can store 1.94 Gbits in 259 MBytes (4.5% overhead) */
| 29 |
const struct {
| 30 |
long capacity; /* slots/branch this level */
| 31 |
long skip_bytes; /* bytes until next branch */
| 32 |
int cntr_siz; /* occupancy counter size */
| 33 |
} tree_br[NLEVELS] = {
| 34 |
{248L, 32L, 1},
| 35 |
{248L*6, 32L*6+2, 2},
| 36 |
{248L*6*6, (32L*6+2)*6+2, 2},
| 37 |
{248L*6*6*6, ((32L*6+2)*6+2)*6+2, 2},
| 38 |
{248L*6*6*6*6, (((32L*6+2)*6+2)*6+2)*6+3, 3},
| 39 |
{248L*6*6*6*6*6, ((((32L*6+2)*6+2)*6+2)*6+3)*6+3, 3},
| 40 |
{248L*6*6*6*6*6*6, (((((32L*6+2)*6+2)*6+2)*6+3)*6+3)*6+3, 3},
| 41 |
{248L*6*6*6*6*6*6*6, ((((((32L*6+2)*6+2)*6+2)*6+3)*6+3)*6+3)*6+4, 4},
| 42 |
{248L*6*6*6*6*6*6*6*6, (((((((32L*6+2)*6+2)*6+2)*6+3)*6+3)*6+3)*6+4)*6+4, 4},
| 43 |
| 44 |
| 45 |
char buf[256]; /* buffer for ordered array output */
| 46 |
| 47 |
| 48 |
/* Encode integer in string and return pointer to end */
| 49 |
static char *
| 50 |
tack(char *b, long i)
| 51 |
| 52 |
char *cp;
| 53 |
char *res;
| 54 |
| 55 |
*b++ = '\t';
| 56 |
cp = b;
| 57 |
if (i == 0)
| 58 |
*cp++ = '0';
| 59 |
else
| 60 |
do {
| 61 |
*cp++ = i%10L + '0';
| 62 |
i /= 10L;
| 63 |
} while (i);
| 64 |
res = cp--;
| 65 |
#define c i
| 66 |
while (cp > b) { /* reverse string */
| 67 |
c = *cp;
| 68 |
*cp-- = *b;
| 69 |
*b++ = c;
| 70 |
| 71 |
#undef c
| 72 |
return(res);
| 73 |
| 74 |
| 75 |
| 76 |
/* Loop over dimensions, spitting out buffer after each increment */
| 77 |
static void
| 78 |
loop(long *n, char *b)
| 79 |
| 80 |
long i;
| 81 |
| 82 |
if (n[0] == 0) {
| 83 |
*b = '\0';
| 84 |
puts(buf);
| 85 |
return;
| 86 |
| 87 |
for (i = 0; i < n[0]; i++)
| 88 |
loop(n+1, tack(b, i));
| 89 |
| 90 |
| 91 |
| 92 |
/* Print out shuffled value */
| 93 |
static void
| 94 |
print_shuf(long *n, long aval)
| 95 |
| 96 |
int i;
| 97 |
| 98 |
for (i = 0; n[i+1]; i++) {
| 99 |
printf("\t%ld", aval % n[i]);
| 100 |
aval /= n[i];
| 101 |
| 102 |
printf("\t%ld\n", aval);
| 103 |
| 104 |
| 105 |
| 106 |
/* Allocate and prepare occupancy tree */
| 107 |
static uby8 *
| 108 |
tree_alloc(long alen)
| 109 |
| 110 |
uby8 *troot;
| 111 |
double bytes_per_bit;
| 112 |
int i;
| 113 |
int ht = 0;
| 114 |
/* how tall does our tree need to be? */
| 115 |
while (tree_br[ht].capacity*BRORDER < alen)
| 116 |
if (++ht >= NLEVELS) {
| 117 |
fputs("Array too large to shuffle\n", stderr);
| 118 |
exit(1);
| 119 |
| 120 |
bytes_per_bit = 1.; /* figure out tree size (with overhead) */
| 121 |
for (i = ht; i >= 0; i--)
| 122 |
bytes_per_bit += (double)tree_br[i].cntr_siz;
| 123 |
bytes_per_bit += (double)tree_br[ht].skip_bytes;
| 124 |
bytes_per_bit /= (double)tree_br[ht].capacity;
| 125 |
troot = (uby8 *)calloc((long)(alen*bytes_per_bit)+2, 1);
| 126 |
if (troot == NULL) {
| 127 |
fputs("Not enough memory for shuffle\n", stderr);
| 128 |
exit(1);
| 129 |
| 130 |
*troot = ht; /* first byte is tree height */
| 131 |
for (i = 256; i--; ) { /* assign 0-bit count table */
| 132 |
int b;
| 133 |
buf[i] = 8;
| 134 |
for (b = i; b; b >>= 1)
| 135 |
buf[i] -= b&1;
| 136 |
| 137 |
return(troot);
| 138 |
| 139 |
| 140 |
| 141 |
/* Get number of slots available at this branch location */
| 142 |
static long
| 143 |
get_avail(const uby8 *ctrp, int lvl)
| 144 |
| 145 |
long cnt = 0;
| 146 |
int n = tree_br[lvl].cntr_siz;
| 147 |
| 148 |
while (--n > 0) { /* LSB first */
| 149 |
cnt |= ctrp[n];
| 150 |
cnt <<= 8;
| 151 |
| 152 |
cnt |= ctrp[0];
| 153 |
| 154 |
return(tree_br[lvl].capacity - cnt);
| 155 |
| 156 |
| 157 |
| 158 |
/* Increment branch occupancy counter */
| 159 |
static void
| 160 |
incr_counter(uby8 *ctrp, int n)
| 161 |
| 162 |
n = tree_br[n].cntr_siz;
| 163 |
| 164 |
while (n-- > 0) /* LSB first */
| 165 |
if (++(*ctrp++))
| 166 |
break;
| 167 |
| 168 |
| 169 |
| 170 |
/* Skip to and allocate a leaf from tree */
| 171 |
static long
| 172 |
eat_nth_leaf(uby8 *brp, long ski)
| 173 |
| 174 |
int lvl = *brp++; /* tree height in first byte */
| 175 |
long pos = 0;
| 176 |
int b;
| 177 |
| 178 |
while (lvl >= 0) { /* descend to leaves */
| 179 |
long navail;
| 180 |
b = 0; /* select each branch */
| 181 |
while (ski >= (navail = get_avail(brp, lvl))) {
| 182 |
if (++b >= BRORDER) {
| 183 |
fputs("Shuffle tree error!\n", stderr);
| 184 |
exit(1);
| 185 |
| 186 |
pos += tree_br[lvl].capacity;
| 187 |
ski -= navail;
| 188 |
brp += tree_br[lvl].skip_bytes;
| 189 |
| 190 |
incr_counter(brp, lvl); /* we intend to eat one */
| 191 |
brp += tree_br[lvl--].cntr_siz; /* drop a level */
| 192 |
| 193 |
while (ski >= buf[*brp]) { /* browse the leaves */
| 194 |
pos += 8;
| 195 |
ski -= buf[*brp++]; /* buf contains 0-bit counts */
| 196 |
| 197 |
b = 0; /* find target bit in byte */
| 198 |
while ((ski -= !(*brp & 1<<b)) >= 0) {
| 199 |
pos++;
| 200 |
b++;
| 201 |
| 202 |
*brp |= 1<<b; /* eat it */
| 203 |
return(pos); /* & return leaf's slot# */
| 204 |
| 205 |
| 206 |
| 207 |
/* Shuffle all possible output strings and spit out randomly (tree version) */
| 208 |
static void
| 209 |
big_shuffle(long *n, long alen)
| 210 |
| 211 |
uby8 *tree_root;
| 212 |
/* size and allocate holder tree */
| 213 |
tree_root = tree_alloc(alen);
| 214 |
| 215 |
while (alen > 0) /* allocate and print random array entries */
| 216 |
print_shuf(n, eat_nth_leaf(tree_root, irandom(alen--)));
| 217 |
| 218 |
free(tree_root); /* all done */
| 219 |
| 220 |
| 221 |
| 222 |
/* Shuffle all possible output strings and spit out randomly */
| 223 |
static void
| 224 |
shuffle(long *n)
| 225 |
| 226 |
long alen;
| 227 |
uint16 *myshuf;
| 228 |
int i;
| 229 |
| 230 |
alen = 1; /* compute shuffle size */
| 231 |
for (i = 0; n[i]; i++) {
| 232 |
if (alen*n[i] <= alen) {
| 233 |
fputs("Array too large to count!\n", stderr);
| 234 |
exit(1);
| 235 |
| 236 |
alen *= n[i];
| 237 |
| 238 |
/* get unique starting point */
| 239 |
srandom((long)time(0));
| 240 |
| 241 |
if (alen > 1L<<16) { /* use large shuffle method? */
| 242 |
big_shuffle(n, alen);
| 243 |
return;
| 244 |
| 245 |
myshuf = (uint16 *)malloc(alen*sizeof(uint16));
| 246 |
if (myshuf == NULL) {
| 247 |
fputs("Insufficient memory for shuffle\n", stderr);
| 248 |
exit(1);
| 249 |
| 250 |
for (i = alen; i--; ) /* initialize in any order */
| 251 |
myshuf[i] = i;
| 252 |
/* perform Fisher-Yates shuffle */
| 253 |
for (i = 0; i < alen-1; i++) {
| 254 |
int ix = irandom(alen-i) + i;
| 255 |
int ndx = myshuf[i];
| 256 |
myshuf[i] = myshuf[ix];
| 257 |
myshuf[ix] = ndx;
| 258 |
| 259 |
/* put randomly indexed output */
| 260 |
| 261 |
print_shuf(n, (long)myshuf[i]);
| 262 |
| 263 |
free(myshuf); /* all done */
| 264 |
| 265 |
| 266 |
| 267 |
int
| 268 |
main(int argc, char *argv[])
| 269 |
| 270 |
char *prog = argv[0];
| 271 |
int doshuffle = 0;
| 272 |
long n[MAXDIM];
| 273 |
int a;
| 274 |
| 275 |
argv++; argc--;
| 276 |
if (argc <= 0)
| 277 |
goto userr;
| 278 |
if (argv[0][0] == '-' && argv[0][1] == 's') {
| 279 |
doshuffle = 1;
| 280 |
argv++; argc--;
| 281 |
| 282 |
for (a = 0; a < argc; a++)
| 283 |
if ((n[a] = atol(argv[a])) <= 1)
| 284 |
goto userr;
| 285 |
n[a] = 0;
| 286 |
if (!a)
| 287 |
goto userr;
| 288 |
| 289 |
if (doshuffle)
| 290 |
shuffle(n);
| 291 |
else
| 292 |
loop(n, buf);
| 293 |
| 294 |
return(0);
| 295 |
userr:
| 296 |
fputs("Usage: ", stderr);
| 297 |
fputs(prog, stderr);
| 298 |
fputs(" [-s] N0 [N1 ..]\n", stderr);
| 299 |
return(1);
| 300 |
