root/radiance/ray/src/cal/calc.c
Revision: 1.7
Committed: Thu Dec 19 16:38:12 2013 UTC (10 years, 5 months ago) by greg
Changes since 1.6: +13 -6 lines
2 static const char RCSid[] = "$Id: calc.c,v 1.6 2003/12/09 15:55:46 greg Exp $";
5 * calc.c - simple algebraic desk calculator program.
6 *
7 * 4/1/86
8 */
9
10 #include <stdlib.h>
11 #include <setjmp.h>
12 #include <ctype.h>
13
14 #include "rtio.h"
15 #include "rterror.h"
16 #include "calcomp.h"
17
18 #define MAXRES 100
19
20 double result[MAXRES];
21 int nres = 0;
22
23 jmp_buf env;
24 int recover = 0;
25
26
27 int
28 main(argc, argv)
29 int argc;
30 char *argv[];
31 {
32 char expr[2048];
33 char *epos;
34 FILE *fp;
35 int i;
36 register char *cp;
37
38 esupport |= E_VARIABLE|E_INCHAN|E_FUNCTION;
39 esupport &= ~(E_REDEFW|E_RCONST|E_OUTCHAN);
40 #ifdef BIGGERLIB
41 biggerlib();
42 #endif
43 varset("PI", ':', 3.14159265358979323846);
44
45 for (i = 1; i < argc; i++) {
46 char *path = getpath(argv[i], getrlibpath(), 0);
47 if (path == NULL) {
48 eputs(argv[0]);
49 eputs(": cannot find file '");
50 eputs(argv[i]);
51 eputs("'\n");
52 quit(1);
53 }
54 fcompile(path);
55 }
56 setjmp(env);
57 recover = 1;
58 eclock++;
59
60 epos = expr;
61 while (fgets(epos, sizeof(expr)-(epos-expr), stdin) != NULL) {
62 while (*epos && *epos != '\n')
63 epos++;
64 if (*epos && epos > expr && epos[-1] == '\\') {
65 epos[-1] = ' ';
66 continue; /* escaped newline */
67 }
68 *epos = '\0';
69 epos = expr;
70 switch (expr[0]) {
71 case '\0':
72 continue;
73 case '?':
74 for (cp = expr+1; isspace(*cp); cp++)
75 ;
76 if (*cp)
77 dprint(cp, stdout);
78 else
79 dprint(NULL, stdout);
80 continue;
81 case '>':
82 for (cp = expr+1; isspace(*cp); cp++)
83 ;
84 if (!*cp) {
85 eputs("file name required\n");
86 continue;
87 }
88 if ((fp = fopen(cp, "w")) == NULL) {
89 eputs(cp);
90 eputs(": cannot open\n");
91 continue;
92 }
93 dprint(NULL, fp);
94 fclose(fp);
95 continue;
96 case '<':
97 for (cp = expr+1; isspace(*cp); cp++)
98 ;
99 if (!*cp) {
100 eputs("file name required\n");
101 continue;
102 }
103 fcompile(cp);
104 eclock++;
105 continue;
106 }
107 if ((cp = strchr(expr, '=')) != NULL ||
108 (cp = strchr(expr, ':')) != NULL) {
109 if (cp[1])
110 scompile(expr, NULL, 0);
111 else if (*cp == '=') {
112 *cp = '\0';
113 if (!strcmp(expr, "*"))
114 dcleanup(1);
115 else
116 dclear(expr);
117 } else {
118 *cp = '\0';
119 if (!strcmp(expr, "*"))
120 dcleanup(2);
121 else
122 dremove(expr);
123 }
124 eclock++;
125 } else {
126 printf("$%d=%.9g\n", nres+1,
127 result[nres%MAXRES] = eval(expr));
128 nres++;
129 }
130 }
131
132 recover = 0;
133 quit(0);
134 return 0; /* pro forma exit */
135 }
136
137
138 double
139 chanvalue(n) /* return channel value */
140 int n;
141 {
142 if (n == 0)
143 n = nres;
144 else if (n > nres || nres-n >= MAXRES) {
145 fprintf(stderr, "$%d: illegal result\n", n);
146 return(0.0);
147 }
148 return(result[(n-1)%MAXRES]);
149 }
150
151
152 void
153 eputs(msg)
154 char *msg;
155 {
156 fputs(msg, stderr);
157 }
158
159
160 void
161 wputs(msg)
162 char *msg;
163 {
164 eputs(msg);
165 }
166
167
168 void
169 quit(code)
170 int code;
171 {
172 if (recover) /* a cavalier approach */
173 longjmp(env, 1);
174 exit(code);
175 }
