root/radiance/ray/src/cal/cal/xyz_srgb.cal
Revision: 1.2
Committed: Thu Apr 28 17:20:34 2005 UTC (18 years, 11 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
Modified xyz_rgb.cal to permit changing color primaries
1 { RCSid $Id$ }
2 {
3 Convert between XYZ and RGB coordinates.
4
5 2/17/95
6
7 Be sure that CIE_x_r, etc. definitions are consistent with
8 those in ray/src/common/color.h.
9 }
10
11 {*** The whole calculation is based on the CIE (x,y) chromaticities below ***}
12
13 CIE_x_r :.640; { CCIR709 primaries }
14 CIE_y_r :.330;
15 CIE_x_g :.300;
16 CIE_y_g :.600;
17 CIE_x_b :0.150;
18 CIE_y_b :0.060;
19
20 CIE_x_w:.3127; { Illuminant D65 }
21 CIE_y_w:.3290;
22
23 WHTEFFICACY : 179. ; { luminous efficacy of uniform white light }
24
25 { Derived constants }
26
27 CIE_D : CIE_x_r*(CIE_y_g - CIE_y_b) +
28 CIE_x_g*(CIE_y_b - CIE_y_r) +
29 CIE_x_b*(CIE_y_r - CIE_y_g) ;
30
31 CIE_C_rD : (1./CIE_y_w) * ( CIE_x_w*(CIE_y_g - CIE_y_b) -
32 CIE_y_w*(CIE_x_g - CIE_x_b) +
33 CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) ;
34
35 CIE_C_gD : (1./CIE_y_w) * ( CIE_x_w*(CIE_y_b - CIE_y_r) -
36 CIE_y_w*(CIE_x_b - CIE_x_r) -
37 CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) ;
38
39 CIE_C_bD : (1./CIE_y_w) * ( CIE_x_w*(CIE_y_r - CIE_y_g) -
40 CIE_y_w*(CIE_x_r - CIE_x_g) +
41 CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) ;
42
43 { Convert CIE XYZ coordinates to RGB }
44
45 XYZ2RGB(i,j) : select(i*3+j+1,
46 (CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD,
47 (CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD,
48 (CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g)/CIE_C_rD,
49 (CIE_y_b - CIE_y_r - CIE_y_b*CIE_x_r + CIE_y_r*CIE_x_b)/CIE_C_gD,
50 (CIE_x_r - CIE_x_b - CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r)/CIE_C_gD,
51 (CIE_x_b*CIE_y_r - CIE_x_r*CIE_y_b)/CIE_C_gD,
52 (CIE_y_r - CIE_y_g - CIE_y_r*CIE_x_g + CIE_y_g*CIE_x_r)/CIE_C_bD,
53 (CIE_x_g - CIE_x_r - CIE_x_g*CIE_y_r + CIE_x_r*CIE_y_g)/CIE_C_bD,
54 (CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r)/CIE_C_bD
55 );
56
57 { noneg(x) : if(x, x, 0); }
58 noneg(x) : x;
59
60 R(X,Y,Z) : noneg(XYZ2RGB(0,0)*X + XYZ2RGB(0,1)*Y + XYZ2RGB(0,2)*Z);
61 G(X,Y,Z) : noneg(XYZ2RGB(1,0)*X + XYZ2RGB(1,1)*Y + XYZ2RGB(1,2)*Z);
62 B(X,Y,Z) : noneg(XYZ2RGB(2,0)*X + XYZ2RGB(2,1)*Y + XYZ2RGB(2,2)*Z);
63
64 { Convert RGB to CIE XYZ coordinates }
65
66 RGB2XYZ(i,j) : select(i*3+j+1,
67 CIE_x_r*CIE_C_rD/CIE_D,CIE_x_g*CIE_C_gD/CIE_D,CIE_x_b*CIE_C_bD/CIE_D,
68 CIE_y_r*CIE_C_rD/CIE_D,CIE_y_g*CIE_C_gD/CIE_D,CIE_y_b*CIE_C_bD/CIE_D,
69 (1.-CIE_x_r-CIE_y_r)*CIE_C_rD/CIE_D,
70 (1.-CIE_x_g-CIE_y_g)*CIE_C_gD/CIE_D,
71 (1.-CIE_x_b-CIE_y_b)*CIE_C_bD/CIE_D
72 );
73
74 X(R,G,B) : RGB2XYZ(0,0)*R + RGB2XYZ(0,1)*G + RGB2XYZ(0,2)*B;
75 Y(R,G,B) : RGB2XYZ(1,0)*R + RGB2XYZ(1,1)*G + RGB2XYZ(1,2)*B;
76 Z(R,G,B) : RGB2XYZ(2,0)*R + RGB2XYZ(2,1)*G + RGB2XYZ(2,2)*B;
77
78 { Convert spectral radiance in watts/sr/m^2 to luminance in cd/m^2 }
79
80 luminance(r,g,b) = WHTEFFICACY * Y(r,g,b) ;
