root/radiance/ray/src/cal/cal/xyz_rgb.cal
Tue Jun 18 20:07:46 2013 UTC (10 years, 11 months ago) by greg
Changes since 1.5: +2 -1 lines
Diff to previous 1.5
Added Rec. 2020 color primaries
Tue Mar 20 16:24:06 2012 UTC (12 years, 2 months ago) by greg
Changes since 1.4: +2 -1 lines
Diff to previous 1.4
Added P3 color primaries
Sun Mar 21 18:26:52 2010 UTC (14 years, 2 months ago) by greg
Changes since 1.3: +8 -2 lines
Diff to previous 1.3
Added alternate color spaces
Thu Apr 28 17:21:47 2005 UTC (19 years ago) by greg
Changes since 1.2: +9 -9 lines
Diff to previous 1.2
Fix in last change
Thu Apr 28 17:20:34 2005 UTC (19 years ago) by greg
Changes since 1.1: +23 -20 lines
Diff to previous 1.1
Modified xyz_rgb.cal to permit changing color primaries
