root/radiance/ray/src/cal/cal/xyz_rgb.cal
Revision: 1.3
Committed: Thu Apr 28 17:21:47 2005 UTC (19 years ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad4R0, rad3R8, rad3R9
Changes since 1.2: +9 -9 lines
Fix in last change
1 { RCSid $Id: xyz_rgb.cal,v 1.2 2005/04/28 17:20:34 greg Exp $ }
2 {
3 Convert between XYZ and RGB coordinates.
4
5 2/17/95
6
7 Be sure that CIE_x_r, etc. definitions are consistent with
8 those in ray/src/common/color.h.
9 }
10
11 CIE_pri(i) = select(i, 0.640,0.330, 0.290,0.600, 0.150,0.060, 1/3,1/3);
12
13 {*** The whole calculation is based on the CIE (x,y) chromaticities below ***}
14
15 CIE_x_r = CIE_pri(1);
16 CIE_y_r = CIE_pri(2);
17 CIE_x_g = CIE_pri(3);
18 CIE_y_g = CIE_pri(4);
19 CIE_x_b = CIE_pri(5);
20 CIE_y_b = CIE_pri(6);
21 CIE_x_w = CIE_pri(7);
22 CIE_y_w = CIE_pri(8);
23
24 WHTEFFICACY : 179. ; { luminous efficacy of uniform white light }
25
26 { Derived constants }
27
28 CIE_D = CIE_x_r*(CIE_y_g - CIE_y_b) +
29 CIE_x_g*(CIE_y_b - CIE_y_r) +
30 CIE_x_b*(CIE_y_r - CIE_y_g) ;
31
32 CIE_C_rD = (1./CIE_y_w) * ( CIE_x_w*(CIE_y_g - CIE_y_b) -
33 CIE_y_w*(CIE_x_g - CIE_x_b) +
34 CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) ;
35
36 CIE_C_gD = (1./CIE_y_w) * ( CIE_x_w*(CIE_y_b - CIE_y_r) -
37 CIE_y_w*(CIE_x_b - CIE_x_r) -
38 CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) ;
39
40 CIE_C_bD = (1./CIE_y_w) * ( CIE_x_w*(CIE_y_r - CIE_y_g) -
41 CIE_y_w*(CIE_x_r - CIE_x_g) +
42 CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) ;
43
44 { Convert CIE XYZ coordinates to RGB }
45
46 XYZ2RGB(i,j) = select(i*3+j+1,
47 (CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD,
48 (CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD,
49 (CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g)/CIE_C_rD,
50 (CIE_y_b - CIE_y_r - CIE_y_b*CIE_x_r + CIE_y_r*CIE_x_b)/CIE_C_gD,
51 (CIE_x_r - CIE_x_b - CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r)/CIE_C_gD,
52 (CIE_x_b*CIE_y_r - CIE_x_r*CIE_y_b)/CIE_C_gD,
53 (CIE_y_r - CIE_y_g - CIE_y_r*CIE_x_g + CIE_y_g*CIE_x_r)/CIE_C_bD,
54 (CIE_x_g - CIE_x_r - CIE_x_g*CIE_y_r + CIE_x_r*CIE_y_g)/CIE_C_bD,
55 (CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r)/CIE_C_bD
56 );
57
58 noneg(x) : if(x, x, 0);
59
60 R(X,Y,Z) = noneg(XYZ2RGB(0,0)*X + XYZ2RGB(0,1)*Y + XYZ2RGB(0,2)*Z);
61 G(X,Y,Z) = noneg(XYZ2RGB(1,0)*X + XYZ2RGB(1,1)*Y + XYZ2RGB(1,2)*Z);
62 B(X,Y,Z) = noneg(XYZ2RGB(2,0)*X + XYZ2RGB(2,1)*Y + XYZ2RGB(2,2)*Z);
63
64 { Convert RGB to CIE XYZ coordinates }
65
66 RGB2XYZ(i,j) = select(i*3+j+1,
67 CIE_x_r*CIE_C_rD/CIE_D,CIE_x_g*CIE_C_gD/CIE_D,CIE_x_b*CIE_C_bD/CIE_D,
68 CIE_y_r*CIE_C_rD/CIE_D,CIE_y_g*CIE_C_gD/CIE_D,CIE_y_b*CIE_C_bD/CIE_D,
69 (1.-CIE_x_r-CIE_y_r)*CIE_C_rD/CIE_D,
70 (1.-CIE_x_g-CIE_y_g)*CIE_C_gD/CIE_D,
71 (1.-CIE_x_b-CIE_y_b)*CIE_C_bD/CIE_D
72 );
73
74 X(R,G,B) = RGB2XYZ(0,0)*R + RGB2XYZ(0,1)*G + RGB2XYZ(0,2)*B;
75 Y(R,G,B) = RGB2XYZ(1,0)*R + RGB2XYZ(1,1)*G + RGB2XYZ(1,2)*B;
76 Z(R,G,B) = RGB2XYZ(2,0)*R + RGB2XYZ(2,1)*G + RGB2XYZ(2,2)*B;
77
78 { Convert spectral radiance in watts/sr/m^2 to luminance in cd/m^2 }
79
80 luminance(r,g,b) = WHTEFFICACY * Y(r,g,b) ;
