root/radiance/ray/src/cal/cal/view360stereo.cal
Revision: 1.3
Committed: Mon Jan 23 02:30:33 2017 UTC (7 years, 4 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1, HEAD
Fixed left-right eye reversal after last change
1 { RCSid $Id: view360stereo.cal,v 1.2 2017/01/22 21:04:22 greg Exp $ }
2 {
3 Definitions for full 360 over-under stereo equirectangular projection
4
5 (c)2014 Mark J. Stock
6 Modified 1/2017 by G.Ward
7
8 Use it like this:
9 X=2048; Y=2048; cnt $Y $X | rcalc -f view360stereo.cal -e "XD:$X;YD:$Y;X:0;Y:0;Z:-0.1;IPD:0.06;EX:0;EZ:0" | rtrace [rpict options] -x $X -y $Y -fac scene.oct > out.hdr
10
11 Parameters defined externally:
12 X : neck rotation origin x
13 Y : neck rotation origin y
14 Z : neck rotation origin z
15 XD : horizontal picture dimension ( pixels )
16 YD : vertical picture dimension ( pixels )
17 IPD : inter-pupillary distance
18 this is between 0.055m and 0.07m on most humans
19 It's not a bad idea to leave these to their default, zero values:
20 EX : forward distance between neck rotation center and bridge of nose (between eyes)
21 this is between 0.05m and 0.07m on most humans
22 EZ : vertical distance between neck rotation center and eye elevation when altitude is 0 degrees
23 this is around 0.1m on most humans
24 }
25
26 { Provide default settings }
27 X = 0; Y = 0; Z = 0;
28 IPD = 0.06;
29 EX = 0;
30 EZ = 0;
31 { Direction of the current pixel (both angles in radians) }
32 px = (XD-1)/2 - $2;
33 py = YD-.5 - $1;
34 frac(x) : x - floor(x);
35 altitude = (frac(py/(YD/2)) - 0.5) * PI;
36 { to do over-under stereo, azimuth is easy }
37 azimut = 2*PI/XD*px;
38
39 { Save a little time below }
40 sinazi = sin(azimut); cosazi = cos(azimut);
41 sinalt = sin(altitude); cosalt = cos(altitude);
42
43 { Transformation into a direction vector }
44 xdir = cosazi * cosalt;
45 ydir = sinazi * cosalt;
46 zdir = sinalt;
47
48 { Transform the viewpoint to account for the eye position }
49 EY = if($1 - YD/2, -0.5*IPD, 0.5*IPD);
50 xpos = X + xdir*EX - sinazi*EY - cosazi*sinalt*EZ;
51 ypos = Y + ydir*EX + cosazi*EY - sinazi*sinalt*EZ;
52 zpos = Z + zdir*EX + 0*EY + cosalt*EZ;
53
54 { Output line to rtrace; each ray needs: xorg yorg zorg xdir ydir zdir }
55 $1 = xpos; $2 = ypos; $3 = zpos;
56 $4 = xdir; $5 = ydir; $6 = zdir;
57
58 { EOF }
