root/radiance/ray/src/cal/cal/stdrefl.cal
Revision: 1.2
Committed: Wed Nov 21 18:10:45 2018 UTC (5 years, 6 months ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
Error occurred while calculating annotation data.
Added missing RCSid tag
1 { RCSid $Id$ }
2 {
3 The following was generated by the command:
4
5 tabfunc -i rho1 rho2 rho3 rho4 rho5 rho6 rho7 rho8 < radfactor.dat
6
7 Used by scripts illumcal, reflcal.
8 }
9 interp_arr`(x,f)=if(x-1,if(f(0)-x,interp_arr2`(floor(x),x,f),f(f(0))),f(1));
10 interp_arr2`(i,x,f)=(i+1-x)*f(i)+(x-i)*f(i+1);
11 rho1(x)=interp_arr`((x-380)/10+1,rho1`p2810);
12 rho1`p2810(i)=select(i,0.219,0.252,0.256,0.252,0.244,
13 0.237,0.23,0.225,0.22,0.216,0.214,0.216,0.223,0.226,0.225,
14 0.227,0.236,0.253,0.272,0.298,0.341,0.39,0.424,0.442,0.45,
15 0.451,0.451,0.45,0.451,0.453,0.455,0.458,0.462,0.464,0.466,
16 0.466,0.467,0.467,0.467,0.467,0.467);
17 rho2(x)=interp_arr`((x-380)/10+1,rho2`p2810);
18 rho2`p2810(i)=select(i,0.07,0.089,0.111,0.118,0.121,
19 0.122,0.123,0.127,0.131,0.138,0.15,0.174,0.207,0.242,0.26,
20 0.267,0.272,0.282,0.299,0.322,0.335,0.341,0.342,0.342,0.341,
21 0.339,0.338,0.336,0.334,0.332,0.331,0.329,0.328,0.326,0.324,
22 0.324,0.322,0.32,0.316,0.315,0.314);
23 rho3(x)=interp_arr`((x-380)/10+1,rho3`p2810);
24 rho3`p2810(i)=select(i,0.065,0.07,0.073,0.074,0.074,
25 0.073,0.073,0.074,0.077,0.085,0.109,0.148,0.198,0.241,0.278,
26 0.339,0.392,0.4,0.38,0.349,0.315,0.285,0.264,0.252,0.241,0.229,
27 0.22,0.216,0.219,0.23,0.251,0.288,0.34,0.39,0.431,0.46,0.481,
28 0.493,0.5,0.505,0.516);
29 rho4(x)=interp_arr`((x-380)/10+1,rho4`p2810);
30 rho4`p2810(i)=select(i,0.074,0.093,0.116,0.124,0.128,
31 0.135,0.144,0.161,0.186,0.229,0.281,0.332,0.37,0.39,0.395,
32 0.385,0.367,0.341,0.312,0.28,0.247,0.214,0.185,0.169,0.16,
33 0.154,0.151,0.148,0.148,0.151,0.158,0.165,0.17,0.17,0.166,
34 0.164,0.168,0.177,0.185,0.192,0.197);
35 rho5(x)=interp_arr`((x-380)/10+1,rho5`p2810);
36 rho5`p2810(i)=select(i,0.295,0.31,0.313,0.319,0.326,
37 0.334,0.346,0.36,0.381,0.403,0.415,0.419,0.413,0.403,0.389,
38 0.372,0.353,0.331,0.308,0.284,0.26,0.232,0.12,0.194,0.185,0.18,
39 0.176,0.175,0.175,0.18,0.186,0.192,0.199,0.199,0.196,0.195,
40 0.197,0.203,0.208,0.215,0.219);
41 rho6(x)=interp_arr`((x-380)/10+1,rho6`p2810);
42 rho6`p2810(i)=select(i,0.151,0.265,0.41,0.492,0.517,
43 0.531,0.544,0.556,0.554,0.541,0.519,0.488,0.45,0.414,0.377,
44 0.341,0.309,0.279,0.253,0.234,0.225,0.221,0.22,0.22,0.223,
45 0.233,0.244,0.258,0.268,0.278,0.283,0.291,0.302,0.325,0.351,
46 0.376,0.401,0.425,0.447,0.469,0.485);
47 rho7(x)=interp_arr`((x-380)/10+1,rho7`p2810);
48 rho7`p2810(i)=select(i,0.378,0.524,0.551,0.559,0.561,
49 0.556,0.544,0.522,0.488,0.448,0.408,0.363,0.324,0.301,0.283,
50 0.265,0.257,0.259,0.26,0.256,0.254,0.27,0.302,0.344,0.377,0.4,
51 0.42,0.438,0.452,0.462,0.468,0.473,0.483,0.496,0.511,0.525,
52 0.539,0.553,0.565,0.575,0.581);
53 rho8(x)=interp_arr`((x-380)/10+1,rho8`p2810);
54 rho8`p2810(i)=select(i,0.104,0.17,0.319,0.462,0.49,
55 0.482,0.462,0.439,0.413,0.382,0.352,0.325,0.299,0.283,0.27,
56 0.256,0.25,0.254,0.264,0.272,0.278,0.295,0.348,0.434,0.528,
57 0.604,0.648,0.676,0.693,0.705,0.712,0.717,0.721,0.719,0.725,
58 0.729,0.73,0.73,0.73,0.73,0.73);
