root/radiance/ray/src/cal/cal/klems_int.cal
Revision 1.10
Sat Jul 19 00:28:38 2014 UTC (9 years, 10 months ago) by greg
FILE REMOVED
Renamed klems_int.cal to klems_full.cal and created similar for half & quarter
Sat Jul 19 00:09:18 2014 UTC (9 years, 10 months ago) by greg
Diff to previous 1.8 , to selected 1.7
Changed to generate kbin=-1 for wrong-side rays
Thu Jul 10 17:43:18 2014 UTC (9 years, 11 months ago) by greg
Changes since 1.7: +5 -3 lines
Diff to previous 1.7
Added return of 145 (Nkbins) for wrong-side rays
Revision 1.7 - (view) (download) (annotate) - [selected]
Mon Feb 20 02:56:19 2012 UTC (12 years, 3 months ago) by greg
Diff to previous 1.6
Minor fix for corner case
Mon Apr 11 03:47:46 2011 UTC (13 years, 2 months ago) by greg
Changes since 1.5: +5 -5 lines
Final fix to Klems angles -- I hope
Wed Jan 26 23:42:03 2011 UTC (13 years, 4 months ago) by greg
Changes since 1.4: +3 -3 lines
Fixed skylight orientation
Sun Sep 26 15:50:39 2010 UTC (13 years, 8 months ago) by greg
Changes since 1.3: +5 -5 lines
Fixed mixed-up definitions of window elevation variables
Fri Sep 3 23:53:11 2010 UTC (13 years, 9 months ago) by greg
Fixed bug at exact phi boundaries
Mon Jun 15 19:31:24 2009 UTC (14 years, 11 months ago) by greg
Changes since 1.1: +4 -4 lines
Fixed angle calculations
Sun Jun 14 20:07:59 2009 UTC (14 years, 11 months ago) by greg
Diff to selected 1.7
Added klems_int.cal module for computing Klems window bins
