1 |
greg |
1.6 |
{ RCSid $Id: fisheye_corr.cal,v 1.5 2016/09/14 20:39:08 greg Exp $ } |
2 |
greg |
1.1 |
3 |
Correct fisheye image using a distortion function: |
4 |
5 |
rad(r) = function of r in [0,.5] range, returing same |
6 |
7 |
This function takes the pixel distance from the image center, where |
8 |
1.0 is the full width of the image constituting 180-degrees of view. |
9 |
The output is the corrected distance from the center for the output. |
10 |
greg |
1.4 |
(If your function is the inverse of this, set map_inverse=1.) |
11 |
greg |
1.1 |
12 |
greg |
1.4 |
pcomb -f fisheye_corr.cal -e 'rad(r)=my_function(r)' \ |
13 |
greg |
1.3 |
-o fisheye.hdr > corrected.hdr |
14 |
greg |
1.1 |
15 |
We also clear the region outside the r=[0,.5] circle to black. |
16 |
greg |
1.4 |
If this is all you want to do, use "rad(r)=r". |
17 |
greg |
1.1 |
18 |
greg |
1.4 |
If you know you have a solid-angle preserving distortion, use |
19 |
"rad(r)=mapsolid(r)" or leave off definition, as this is the default. |
20 |
greg |
1.1 |
21 |
xc : xres/2; |
22 |
yc : yres/2; |
23 |
sq(x) : x*x; |
24 |
greg |
1.4 |
map_inverse = -1; { change to 1 if rad(r) is inverse mapping } |
25 |
greg |
1.5 |
inp_r = sqrt(sq((x-xc)/xres) + sq((y-yc)/yres)); |
26 |
mapped_r = rad(inp_r); |
27 |
rmult = if(map_inverse, inp_r/(mapped_r+1e-7), mapped_r/(inp_r+1e-7)); |
28 |
greg |
1.1 |
xoff = (x-xc)*(1-rmult); |
29 |
yoff = (y-yc)*(1-rmult); |
30 |
greg |
1.5 |
ro = if(.5-inp_r, ri(1,xoff,yoff), 0); |
31 |
go = if(.5-inp_r, gi(1,xoff,yoff), 0); |
32 |
bo = if(.5-inp_r, bi(1,xoff,yoff), 0); |
33 |
greg |
1.2 |
34 |
{ Radius adjustment for equisolid-angle projection to equidistant (-vta) } |
35 |
greg |
1.5 |
mapsolid(r) : 2/PI*asin(sqrt(2)*r); |
36 |
greg |
1.4 |
37 |
{ Default correction function } |
38 |
rad(r) = mapsolid(r); |
