root/radiance/ray/src/cal/cal/fisheye_corr.cal
Fri Aug 28 19:39:22 2020 UTC (3 years, 9 months ago) by greg
Changes since 1.5: +1 -11 lines
Diff to previous 1.5
docs: Updated comment as pcomb now preserves the VIEW= line from header
Wed Sep 14 20:39:08 2016 UTC (7 years, 8 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 1.4: +8 -8 lines
Diff to previous 1.4
Variable name changes, mostly
Wed Sep 14 18:17:59 2016 UTC (7 years, 8 months ago) by greg
Changes since 1.3: +15 -14 lines
Diff to previous 1.3
Made mapsolid(r) the default mapping
Wed Sep 14 18:02:42 2016 UTC (7 years, 8 months ago) by greg
Changes since 1.2: +13 -3 lines
Diff to previous 1.2
Added mention of getinfo -a in comments at top
Tue Aug 30 12:11:29 2016 UTC (7 years, 9 months ago) by greg
Changes since 1.1: +4 -1 lines
Diff to previous 1.1
Added mapsolid(r) definition for mapping from equisolid-angle to equidistant
Mon Aug 1 00:08:38 2016 UTC (7 years, 10 months ago) by greg
Added file to correct fisheye lens perspective
