root/radiance/ray/src/cal/cal/conv2.cal
Revision: 1.1
Committed: Sat Feb 22 02:07:21 2003 UTC (21 years, 2 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
1 {
2 Rcalc run to compute CRI and other factors from light source SPD
3 convolved with standard curves.
4 Used by scripts illumcal, reflcal.
5
6 Input is summed wavelength convolution used below.
7 }
8 Lp = $1; { photopic lumens or luminance }
9 Ls = $2; { scotopic lumens or luminance }
10 x_k = $3/($3+$4+$5); { source x }
11 y_k = $4/($3+$4+$5); { source y }
12 u_k = u_XYZ($3,$4,$5); { source u }
13 v_k = v_XYZ($3,$4,$5); { source v }
14 c_k = c_uv(u_k,v_k); { source c }
15 d_k = d_uv(u_k,v_k); { source d }
16 x10_k = $6/($6+$7+$8); { source x10 }
17 y10_k = $7/($6+$7+$8); { source y10 }
18 Yi(i) = select(i, $10, $13, $16, $19, $22, $25, $28, $31) * 100 / $4;
19 ui(i) = select(i,
20 u_XYZ($9,$10,$11), { u for reference color 1 }
21 u_XYZ($12,$13,$14), { u for reference color 2 }
22 u_XYZ($15,$16,$17), { u for reference color 3 }
23 u_XYZ($18,$19,$20), { u for reference color 4 }
24 u_XYZ($21,$22,$23), { u for reference color 5 }
25 u_XYZ($24,$25,$26), { u for reference color 6 }
26 u_XYZ($27,$28,$29), { u for reference color 7 }
27 u_XYZ($30,$31,$32) { u for reference color 8 }
28 );
29 vi(i) = select(i,
30 v_XYZ($9,$10,$11), { v for reference color 1 }
31 v_XYZ($12,$13,$14), { v for reference color 2 }
32 v_XYZ($15,$16,$17), { v for reference color 3 }
33 v_XYZ($18,$19,$20), { v for reference color 4 }
34 v_XYZ($21,$22,$23), { v for reference color 5 }
35 v_XYZ($24,$25,$26), { v for reference color 6 }
36 v_XYZ($27,$28,$29), { v for reference color 7 }
37 v_XYZ($30,$31,$32) { v for reference color 8 }
38 );
39
40 ci(i) = c_uv(ui(i),vi(i));
41 di(i) = d_uv(ui(i),vi(i));
42
43 u_XYZ(X,Y,Z) = 4*X/(X+15*Y+3*Z);
44 v_XYZ(X,Y,Z) = 9*Y/(X+15*Y+3*Z);
45 c_uv(u,v) = (4-u-10*v)/v;
46 d_uv(u,v) = (1.708*v+.404-1.481*u)/v;
