root/radiance/ray/src/cal/cal/conv2.cal
Revision: 1.2
Committed: Wed Nov 21 18:10:45 2018 UTC (5 years, 6 months ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
Added missing RCSid tag
1 { RCSid $Id$ }
2 {
3 Rcalc run to compute CRI and other factors from light source SPD
4 convolved with standard curves.
5 Used by scripts illumcal, reflcal.
6
7 Input is summed wavelength convolution used below.
8 }
9 Lp = $1; { photopic lumens or luminance }
10 Ls = $2; { scotopic lumens or luminance }
11 x_k = $3/($3+$4+$5); { source x }
12 y_k = $4/($3+$4+$5); { source y }
13 u_k = u_XYZ($3,$4,$5); { source u }
14 v_k = v_XYZ($3,$4,$5); { source v }
15 c_k = c_uv(u_k,v_k); { source c }
16 d_k = d_uv(u_k,v_k); { source d }
17 x10_k = $6/($6+$7+$8); { source x10 }
18 y10_k = $7/($6+$7+$8); { source y10 }
19 Yi(i) = select(i, $10, $13, $16, $19, $22, $25, $28, $31) * 100 / $4;
20 ui(i) = select(i,
21 u_XYZ($9,$10,$11), { u for reference color 1 }
22 u_XYZ($12,$13,$14), { u for reference color 2 }
23 u_XYZ($15,$16,$17), { u for reference color 3 }
24 u_XYZ($18,$19,$20), { u for reference color 4 }
25 u_XYZ($21,$22,$23), { u for reference color 5 }
26 u_XYZ($24,$25,$26), { u for reference color 6 }
27 u_XYZ($27,$28,$29), { u for reference color 7 }
28 u_XYZ($30,$31,$32) { u for reference color 8 }
29 );
30 vi(i) = select(i,
31 v_XYZ($9,$10,$11), { v for reference color 1 }
32 v_XYZ($12,$13,$14), { v for reference color 2 }
33 v_XYZ($15,$16,$17), { v for reference color 3 }
34 v_XYZ($18,$19,$20), { v for reference color 4 }
35 v_XYZ($21,$22,$23), { v for reference color 5 }
36 v_XYZ($24,$25,$26), { v for reference color 6 }
37 v_XYZ($27,$28,$29), { v for reference color 7 }
38 v_XYZ($30,$31,$32) { v for reference color 8 }
39 );
40
41 ci(i) = c_uv(ui(i),vi(i));
42 di(i) = d_uv(ui(i),vi(i));
43
44 u_XYZ(X,Y,Z) = 4*X/(X+15*Y+3*Z);
45 v_XYZ(X,Y,Z) = 9*Y/(X+15*Y+3*Z);
46 c_uv(u,v) = (4-u-10*v)/v;
47 d_uv(u,v) = (1.708*v+.404-1.481*u)/v;
