root/radiance/ray/src/cal/SConscript
Mon Jan 8 13:38:37 2018 UTC (6 years, 5 months ago) by schorsch
Changes since 1.7: +4 -1 lines
Diff to previous 1.7
Thu Mar 10 21:43:22 2016 UTC (8 years, 3 months ago) by schorsch
Changes since 1.6: +5 -5 lines
Diff to previous 1.6
Sat Mar 5 13:24:58 2016 UTC (8 years, 3 months ago) by schorsch
Diff to previous 1.5
Sat Mar 5 00:29:28 2016 UTC (8 years, 3 months ago) by schorsch
Diff to previous 1.4
update SCons
Mon Apr 21 07:31:28 2008 UTC (16 years, 2 months ago) by schorsch
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Diff to previous 1.3
Scons update for mingw.
Thu Jan 1 20:56:29 2004 UTC (20 years, 5 months ago) by schorsch
Diff to previous 1.2
Renamed calc to icalc, lam to rlam, and neat to neaten.
Mon Oct 27 10:35:41 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 1.1: +5 -5 lines
Diff to previous 1.1
Tue Oct 21 19:27:28 2003 UTC (20 years, 8 months ago) by schorsch
