root/radiance/ray/src/cal/SConscript
Revision: 1.7
Committed: Thu Mar 10 21:43:22 2016 UTC (9 years, 2 months ago) by schorsch
Changes since 1.6: +5 -5 lines
# User Rev Content
1 schorsch 1.1 import os
2
3     Import('env') # inherit from parent
4
5     mlib = env['RAD_MLIB']
6
7     # standard targets
8     PROGS = (
9     # name sources libs
10 schorsch 1.7 ('icalc', Split('calc.c'), ['rtrad'] + mlib),
11     ('ev', Split('ev.c'), ['rtrad'] + mlib),
12     ('rcalc', Split('rcalc.c'), ['rtrad'] + mlib),
13 schorsch 1.1 ('total', Split('total.c'), mlib),
14     ('cnt', Split('cnt.c'), []),
15 schorsch 1.3 ('neaten', Split('neat.c'), []),
16 schorsch 1.7 ('rlam', Split('lam.c'), ['rtrad']),
17     ('tabfunc',Split('tabfunc.c'), ['rtrad'] + mlib),
18 schorsch 1.1 ('histo', Split('histo.c'), mlib),
19     )
20     for p in PROGS:
21     prog = env.Program(target=os.path.join(env['RAD_BUILDBIN'], p[0]),
22     source=p[1], LIBS=p[2])
23     Default(prog)
24     env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
25
26 schorsch 1.6 # vim: set syntax=python:
