root/radiance/ray/src/cal/CMakeLists.txt
Thu Jul 16 21:46:30 2020 UTC (4 years, 10 months ago) by greg
Changes since 1.6: +1 -0 lines
Diff to previous 1.6
fix(rsplit): added to installer target
Fri Jul 5 00:20:57 2019 UTC (5 years, 11 months ago) by greg
Changes since 1.5: +3 -0 lines
Diff to previous 1.5
Mon Jan 8 16:51:32 2018 UTC (7 years, 5 months ago) by greg
Changes since 1.4: +16 -3 lines
Diff to previous 1.4
Update to CMake build system from Rob G. and Alex S., adding test cases
Thu Aug 18 00:55:14 2016 UTC (8 years, 9 months ago) by greg
Diff to previous 1.3
Added missing library linkage
Wed May 30 18:31:11 2012 UTC (13 years ago) by greg
Diff to previous 1.2
Patches to cmake build system and QT driver for rvu
Wed Apr 25 22:21:06 2012 UTC (13 years, 1 month ago) by greg
Diff to previous 1.1
Sat Oct 22 22:38:10 2011 UTC (13 years, 7 months ago) by greg
Added qt interface for rvu and cmake files from Bill Hoffman
