root/radiance/ray/src/CMakeLists.txt
Revision: 1.3
Committed: Wed Apr 25 22:21:06 2012 UTC (11 years, 11 months ago) by greg
CVS Tags: rad4R2P2, rad4R2, rad4R2P1
Changes since 1.2: +0 -3 lines
1 if(UNIX)
2 find_library(LIB_M m DOC "Path to libm")
3 if(NOT LIB_M)
4 message(FATAL_ERROR "Cannot build radiance without libm. Please set LIB_M")
5 endif()
6 else()
7 set(LIB_M )
8 endif()
9
10 include_directories(common)
11 # create a macro to generate
12 macro(create_version_file version_file)
13 add_custom_command(
14 OUTPUT "${version_file}"
15 COMMAND "${CMAKE_COMMAND}"
16 -DVERSION_OUT_FILE="${version_file}"
17 -DVERSION_IN_FILE="${radiance_SOURCE_DIR}/src/rt/VERSION"
18 -DVERSION_GOLD="${radiance_SOURCE_DIR}/src/rt/Version.c"
19 -P "${radiance_SOURCE_DIR}/src/rt/create_version.cmake"
20 )
21 endmacro()
22 add_subdirectory(common)
23 add_subdirectory(cal)
24 add_subdirectory(cv)
25 add_subdirectory(gen)
26 add_subdirectory(hd)
27 add_subdirectory(meta)
28 add_subdirectory(ot)
29 add_subdirectory(px)
30 add_subdirectory(rt)
31 add_subdirectory(util)
32 # only use rvu if qt4 is found
33 if(QT4_FOUND)
34 add_subdirectory(qtrvu)
35 endif()
36
