root/radiance/ray/src/CMakeLists.txt
Tue May 16 22:58:18 2023 UTC (2 years ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 1.8
chore: Removed qt from macOS X and Linux builds as it was having issues
Wed Jun 20 20:51:24 2018 UTC (6 years, 10 months ago) by greg
CVS Tags: rad5R2, rad5R3
Diff to previous 1.7
Updates to package installers from Rob G.
Mon Jan 8 16:51:32 2018 UTC (7 years, 4 months ago) by greg
Changes since 1.6: +28 -9 lines
Diff to previous 1.6
Update to CMake build system from Rob G. and Alex S., adding test cases
Tue Mar 22 21:36:24 2016 UTC (9 years, 1 month ago) by greg
Changes since 1.5: +5 -4 lines
Diff to previous 1.5
Rob G. fixes for "headless" target
Wed Feb 3 22:54:01 2016 UTC (9 years, 3 months ago) by greg
Diff to previous 1.4
Fixes in cmake build for last changes (thanks to Rob G.)
Fri May 8 18:07:38 2015 UTC (10 years ago) by greg
Diff to previous 1.3
Fixes for rvu under Windows
Wed Apr 25 22:21:06 2012 UTC (13 years ago) by greg
Changes since 1.2: +0 -3 lines
Diff to previous 1.2
Fri Oct 28 20:46:47 2011 UTC (13 years, 6 months ago) by greg
Changes since 1.1: +11 -1 lines
Diff to previous 1.1
Fixes to Version.c update in cmake build system
Sat Oct 22 22:38:10 2011 UTC (13 years, 6 months ago) by greg
Added qt interface for rvu and cmake files from Bill Hoffman
