root/radiance/ray/src/CMakeLists.txt
Revision: 1.4
Committed: Fri May 8 18:07:38 2015 UTC (10 years ago) by greg
Fixes for rvu under Windows
# User Rev Content
1 greg 1.1 if(UNIX)
2     find_library(LIB_M m DOC "Path to libm")
3     if(NOT LIB_M)
4     message(FATAL_ERROR "Cannot build radiance without libm. Please set LIB_M")
5     endif()
6     else()
7     set(LIB_M )
8     endif()
9
10     include_directories(common)
11 greg 1.2 # create a macro to generate
12     macro(create_version_file version_file)
13     add_custom_command(
14     OUTPUT "${version_file}"
15     COMMAND "${CMAKE_COMMAND}"
16     -DVERSION_OUT_FILE="${version_file}"
17     -DVERSION_IN_FILE="${radiance_SOURCE_DIR}/src/rt/VERSION"
18     -DVERSION_GOLD="${radiance_SOURCE_DIR}/src/rt/Version.c"
19     -P "${radiance_SOURCE_DIR}/src/rt/create_version.cmake"
20     )
21     endmacro()
22 greg 1.1 add_subdirectory(common)
23     add_subdirectory(cal)
24     add_subdirectory(cv)
25     add_subdirectory(gen)
26     add_subdirectory(hd)
27     add_subdirectory(meta)
28     add_subdirectory(ot)
29     add_subdirectory(px)
30     add_subdirectory(rt)
31     add_subdirectory(util)
32 greg 1.4 # only use rvu if qt5 is found
33     if(Qt5Widgets_DIR)
34 greg 1.1 add_subdirectory(qtrvu)
35     endif()
36
