root/radiance/ray/src/CMakeLists.txt
Revision: 1.2
Committed: Fri Oct 28 20:46:47 2011 UTC (12 years, 7 months ago) by greg
Changes since 1.1: +11 -1 lines
Fixes to Version.c update in cmake build system
# User Rev Content
1 greg 1.1 if(UNIX)
2     find_library(LIB_M m DOC "Path to libm")
3     if(NOT LIB_M)
4     message(FATAL_ERROR "Cannot build radiance without libm. Please set LIB_M")
5     endif()
6     else()
7     set(LIB_M )
8     endif()
9
10     find_package(OpenGL)
11     find_package(X11)
12
13     include_directories(common)
14 greg 1.2 # create a macro to generate
15     macro(create_version_file version_file)
16     add_custom_command(
17     OUTPUT "${version_file}"
18     COMMAND "${CMAKE_COMMAND}"
19     -DVERSION_OUT_FILE="${version_file}"
20     -DVERSION_IN_FILE="${radiance_SOURCE_DIR}/src/rt/VERSION"
21     -DVERSION_GOLD="${radiance_SOURCE_DIR}/src/rt/Version.c"
22     -P "${radiance_SOURCE_DIR}/src/rt/create_version.cmake"
23     )
24     endmacro()
25 greg 1.1 add_subdirectory(common)
26     add_subdirectory(cal)
27     add_subdirectory(cv)
28     add_subdirectory(gen)
29     add_subdirectory(hd)
30     add_subdirectory(meta)
31     add_subdirectory(ot)
32     add_subdirectory(px)
33     add_subdirectory(rt)
34     add_subdirectory(util)
35     # only use rvu if qt4 is found
36     if(QT4_FOUND)
37     add_subdirectory(qtrvu)
38     endif()
39
