1 |
#!/usr/bin/ruby |
2 |
3 |
# Radiance test library |
4 |
5 |
# Use with cmake build system deployed by NREL |
6 |
# Run from [build]/resources |
7 |
# usage: [ruby]test_lib[.rb] (runs all tests with all available cores passed to radiance MP tools) |
8 |
# usage: [ruby]test_lib[.rb] -n [n] -t ['testname', 'all'] |
9 |
10 |
11 |
$stderr.sync = true |
12 |
require 'optparse' |
13 |
require 'etc' |
14 |
# default options |
15 |
flag = false |
16 |
tst = "all" |
17 |
18 |
tproc = Etc.nprocessors |
19 |
nproc = tproc / 2 # half cores by default, override with -n |
20 |
list = ["x", "y", "z"] |
21 |
22 |
# parse arguments |
23 |
file = __FILE__ |
24 |
ARGV.options do |opts| |
25 |
opts.on("-t", "--test=val", String) { |val| tst = val } |
26 |
opts.on("-n", "--nproc=val", Integer) { |val| nproc = val } |
27 |
opts.parse! |
28 |
end |
29 |
30 |
# print opts |
31 |
warn "ARGV: #{ARGV.inspect}" |
32 |
warn "test: #{tst.inspect}" |
33 |
warn "cores: #{nproc.inspect} (of #{tproc} total)" |
34 |
35 |
test_in = tst |
36 |
37 |
test_total = 0 |
38 |
@test_pass = 0 |
39 |
@test_fail = 0 |
40 |
41 |
all_tests = [ |
42 |
'test_xform' , 'test_rad' , 'test_rtrace' , 'test_vwright' , 'test_rcollate' , 'test_dctimestep', |
43 |
'test_getinfo' , 'test_rmtxop' , 'test_oconv' , 'test_rfluxmtx' , 'test_dielectric_def' , |
44 |
'test_dielectric_fish', 'test_replmarks', 'test_gensky', 'test_gendaymtx','test_genbox', |
45 |
'test_genrev', 'test_genworm', 'test_genprism', 'test_gensurf', 'test_cnt', 'test_rcalc', |
46 |
'test_total', 'test_histo', 'test_rlam' |
47 |
48 |
49 |
def rcpf |
50 |
if $?.exitstatus == 0 |
51 |
@test_pass +=1 |
52 |
53 |
puts "test: PASS" |
54 |
else |
55 |
@test_fail +=1 |
56 |
puts "test: FAIL" |
57 |
end |
58 |
end |
59 |
60 |
# Number of processes to use on tests that run multi-core |
61 |
NPROC = nproc |
62 |
63 |
# Image reduction for comparisons |
64 |
RDU_PFILT = "pfilt -1 -r 1 -x 128 -y 128 -pa 1" |
65 |
66 |
# Image comparison command |
67 |
IMG_CMP = "radcompare -v -rms 0.07 -max 1.5" |
68 |
69 |
## tests from test/util |
70 |
71 |
def test_vwright |
72 |
73 |
Dir.chdir('../test/util') do |
74 |
# generate test input |
75 |
cmd = "vwright -vf test.vf 3.5 > vwright.txt" |
76 |
system(cmd) |
77 |
78 |
# compare to reference |
79 |
cmd = "radcompare -v ref/vwright.txt vwright.txt" |
80 |
system(cmd) |
81 |
82 |
# report pass/fail |
83 |
rcpf |
84 |
85 |
# cleanup |
86 |
# File.delete("vwright.mtx") |
87 |
end |
88 |
89 |
end |
90 |
91 |
def make_test_mtx |
92 |
93 |
94 |
95 |
cmd = "rcollate -t ../renders/ref/rfmirror.mtx > test.mtx" |
96 |
system(cmd) |
97 |
98 |
end |
99 |
100 |
end |
101 |
102 |
def test_rcollate |
103 |
104 |
make_test_mtx if !File.exist?("../test/util/test.mtx") |
105 |
106 |
107 |
cmd = "radcompare -v ref/test.mtx test.mtx" |
108 |
system(cmd) |
109 |
end |
110 |
111 |
rcpf |
112 |
113 |
#File.delete("#{t}/test.mtx") |
114 |
115 |
end |
116 |
117 |
def test_dctimestep |
118 |
119 |
120 |
121 |
122 |
cmd = "gensky 3 21 10:15PST +s -g .3 -g 2.5 -a 36 -o 124 | genskyvec -m 1 -c .92 1.03 1.2 | dctimestep '!rmtxop -ff -t test.mtx' > dctimestep.mtx" |
123 |
system(cmd) |
124 |
cmd = "radcompare -v ref/dctimestep.mtx dctimestep.mtx" |
125 |
system(cmd) |
126 |
end |
127 |
128 |
rcpf |
129 |
130 |
#File.delete("#{t}/dctimestep.mtx") |
131 |
132 |
end |
133 |
134 |
def test_getinfo |
135 |
136 |
137 |
138 |
139 |
cmd = "getinfo -a Guppies 'Fredo the Frog' < test.mtx | getinfo > getinfo.txt" |
140 |
system(cmd) |
141 |
cmd = "radcompare -v ref/getinfo.txt getinfo.txt" |
142 |
system(cmd) |
143 |
end |
144 |
145 |
rcpf |
146 |
147 |
#File.delete("#{t}/getinfo.txt") |
148 |
149 |
end |
150 |
151 |
def test_rmtxop |
152 |
153 |
154 |
155 |
156 |
cmd = "rmtxop -ff -c .3 .9 .2 test.mtx -c .7 .2 .3 -t test.mtx > rmtxop.mtx" |
157 |
puts("command: #{cmd}") |
158 |
system(cmd) |
159 |
cmd = "radcompare -v ref/rmtxop.mtx rmtxop.mtx" |
160 |
161 |
system(cmd) |
162 |
end |
163 |
164 |
rcpf |
165 |
#File.delete("#{t}/rmtxop.mtx") |
166 |
167 |
end |
168 |
169 |
### END test/util ### |
170 |
171 |
172 |
### test/renders ### |
173 |
174 |
def inst_oct |
175 |
Dir.chdir('../test/renders') do |
176 |
cmd = "rad -v 0 inst.rif" |
177 |
178 |
system(cmd) |
179 |
end |
180 |
end |
181 |
182 |
def test_xform |
183 |
combined_rad if !File.exist?("../test/renders/combined.rad") |
184 |
185 |
cmd = "radcompare -v -max 0.04 ref/combined.rad combined.rad" |
186 |
187 |
system(cmd) |
188 |
rcpf |
189 |
end |
190 |
end |
191 |
192 |
def combined_rad |
193 |
194 |
cmd = "xform -f combined_scene.rad | grep -v '^[ ]*#' > combined.rad" |
195 |
196 |
system(cmd) |
197 |
end |
198 |
end |
199 |
200 |
def test_rad |
201 |
202 |
cmd = 'rad -n -s -e inst.rif > inst_rad.txt' |
203 |
system(cmd) |
204 |
cmd = 'radcompare -v ref/inst_rad.txt inst_rad.txt' |
205 |
206 |
system(cmd) |
207 |
rcpf |
208 |
end |
209 |
end |
210 |
211 |
def test_oconv |
212 |
inst_oct if !File.exist?("../test/renders/inst.oct") |
213 |
214 |
cmd="radcompare -v ref/inst.oct inst.oct" |
215 |
system(cmd) |
216 |
end |
217 |
rcpf |
218 |
end |
219 |
220 |
def gen_rtmirror_fish_hdr |
221 |
222 |
puts "generating input file: rtmirror_fish.hdr" |
223 |
cmd = "rad -v 0 mirror.rif OPT=mirror.opt" |
224 |
system(cmd) |
225 |
cmd = "vwrays -ff -vf fish.vf -x 2048 -y 2048 | rtrace -n #{NPROC} @mirror.opt -ffc -x 2048 -y 2048 mirror.oct | pfilt -1 -e +3 -r .6 -x /2 -y /2 > rtmirror_fish.hdr" |
226 |
# rm -f mirror.opt |
227 |
228 |
system(cmd) |
229 |
end |
230 |
end |
231 |
232 |
def test_rtrace |
233 |
gen_rtmirror_fish_hdr if !File.exist?("../test/renders/rtmirror_fish.hdr") |
234 |
235 |
cmd = "#{RDU_PFILT} rtmirror_fish.hdr | #{IMG_CMP} -h ref/mirror_fish.hdr -" |
236 |
237 |
system(cmd) |
238 |
rcpf |
239 |
end |
240 |
end |
241 |
242 |
def test_rfluxmtx |
243 |
gen_rfmirror_mtx if !File.exist?("../test/renders/rfmirror.mtx") |
244 |
245 |
cmd = 'radcompare -v -max .4 -rms .05 ref/rfmirror.mtx rfmirror.mtx' |
246 |
247 |
system(cmd) |
248 |
rcpf |
249 |
end |
250 |
end |
251 |
252 |
def gen_rfmirror_mtx |
253 |
254 |
cmd = "rfluxmtx -n #{NPROC} -ab 2 -lw 1e-4 mirror.rad dummysky.rad basic.mat diorama_walls.rad closed_end.rad front_cap.rad glass_pane.rad antimatter_portal.rad > rfmirror.mtx" |
255 |
256 |
system(cmd) |
257 |
end |
258 |
end |
259 |
260 |
def gen_dielectric_oct |
261 |
262 |
cmd = 'rad -v 0 dielectric.rif' |
263 |
264 |
system(cmd) |
265 |
end |
266 |
end |
267 |
268 |
def test_dielectric_def #ref/dielectric_def.hdr dielectric_def.hdr |
269 |
gen_dielectric_def if !File.exist?("../test/renders/dielectric_def.hdr") |
270 |
gen_dielectric_def_ref if !File.exist?("../test/renders/ref/dielectric_def.hdr") |
271 |
272 |
cmd = "#{RDU_PFILT} dielectric_def.hdr | #{IMG_CMP} ref/dielectric_def.hdr -" |
273 |
274 |
system(cmd) |
275 |
rcpf |
276 |
end |
277 |
end |
278 |
279 |
def gen_dielectric_def_ref |
280 |
gen_dielectric_def if !File.exist?('../test/renders/dielectric_def.hdr') |
281 |
282 |
cmd = '#{RDU_PFILT} dielectric_def.hdr > ref/dielectric_def.hdr' |
283 |
284 |
system(cmd) |
285 |
end |
286 |
end |
287 |
288 |
def gen_dielectric_def #dielectric.oct |
289 |
gen_dielectric_oct if !File.exist?('../test/renders/dielectric.oct') |
290 |
291 |
cmd = 'rad -v def dielectric.rif' |
292 |
293 |
system(cmd) |
294 |
end |
295 |
end |
296 |
297 |
298 |
### Reference and test for dielectric view fish ### |
299 |
300 |
def test_dielectric_fish # ref/dielectric_fish.hdr dielectric_fish.hdr |
301 |
gen_dielectric_fish_hdr if !File.exist?('../test/renders/dielectric_fish.hdr') |
302 |
gen_ref_dielectric_fish_hdr if !File.exist?('../test/renders/ref/dielectric_fish.hdr') |
303 |
304 |
cmd = "#{RDU_PFILT} dielectric_fish.hdr | #{IMG_CMP} ref/dielectric_fish.hdr -" |
305 |
306 |
system(cmd) |
307 |
rcpf |
308 |
end |
309 |
end |
310 |
311 |
def gen_ref_dielectric_fish_hdr #dielectric.oct |
312 |
313 |
314 |
cmd = "#{RDU_PFILT} dielectric_fish.hdr > ref/dielectric_fish.hdr" |
315 |
316 |
system(cmd) |
317 |
end |
318 |
end |
319 |
320 |
def gen_dielectric_fish_hdr |
321 |
322 |
323 |
cmd = 'rad -v fish dielectric.rif' |
324 |
325 |
system(cmd) |
326 |
end |
327 |
end |
328 |
329 |
### End dielectric-fish tests |
330 |
331 |
332 |
### END test/renders ### |
333 |
334 |
335 |
### test/gen ### |
336 |
337 |
def test_replmarks |
338 |
Dir.chdir('../test/gen') do |
339 |
cmd = "replmarks -s 1 -x dummy.rad rmod markers.rad | grep -v '^[ ]*#' > replmarks.rad" |
340 |
341 |
system(cmd) |
342 |
343 |
rcpf |
344 |
end |
345 |
#rm -f replmarks.rad |
346 |
end |
347 |
348 |
349 |
def test_gensky |
350 |
351 |
cmd = 'gensky 11 15 14:21EST +s -g .25 -t 3.5 -a 40.7128 -o 74.006 > NYC11-15-14-21.rad' |
352 |
353 |
system(cmd) |
354 |
355 |
cmd = 'radcompare ref/NYC11-15-14-21.rad NYC11-15-14-21.rad' |
356 |
357 |
system(cmd) |
358 |
359 |
rcpf |
360 |
end |
361 |
#rm -f NYC11-15-14-21.rad |
362 |
end |
363 |
364 |
365 |
def test_gendaymtx |
366 |
367 |
cmd = 'gendaymtx -r 90 -m 1 -g .3 .2 .1 -c .9 .9 1.2 test.wea > test.smx' |
368 |
369 |
system(cmd) |
370 |
371 |
cmd = 'radcompare ref/test.smx test.smx' |
372 |
373 |
system(cmd) |
374 |
375 |
rcpf |
376 |
end |
377 |
#rm -f test.smx |
378 |
end |
379 |
380 |
def test_genbox |
381 |
382 |
cmd = 'genbox tmat tbox 1 2 3 -i -b .1 > genbox.rad' |
383 |
384 |
system(cmd) |
385 |
386 |
cmd = 'radcompare ref/genbox.rad genbox.rad' |
387 |
388 |
system(cmd) |
389 |
390 |
rcpf |
391 |
end |
392 |
#rm -f genbox.rad |
393 |
end |
394 |
395 |
def test_genrev |
396 |
397 |
cmd = "genrev tmat trev 'sin(2*PI*t)' '2+cos(2*PI*t)' 16 -s > genrev.rad" |
398 |
399 |
system(cmd) |
400 |
401 |
cmd = 'radcompare ref/genrev.rad genrev.rad' |
402 |
403 |
system(cmd) |
404 |
405 |
rcpf |
406 |
end |
407 |
#rm -f genrev.rad |
408 |
end |
409 |
410 |
def test_genworm |
411 |
412 |
cmd = "genworm tmat tworm '0' '5*sin(t)' '5*cos(t)' '.4-(.5-t)*(.5-t)' 8 > genworm.rad" |
413 |
414 |
system(cmd) |
415 |
416 |
cmd = 'radcompare ref/genworm.rad genworm.rad' |
417 |
418 |
system(cmd) |
419 |
420 |
rcpf |
421 |
end |
422 |
#rm -f genworm.rad |
423 |
end |
424 |
425 |
def test_genprism |
426 |
427 |
cmd = "genprism tmat tprism 8 0 5 4 5 4 4 24.5 4 24.5 3 30 1.5 30 22 0 22 -l 0 0 -1.5 -r .2 > genprism.rad" |
428 |
429 |
system(cmd) |
430 |
431 |
cmd = 'radcompare ref/genprism.rad genprism.rad' |
432 |
433 |
system(cmd) |
434 |
435 |
rcpf |
436 |
end |
437 |
#rm -f genprism.rad |
438 |
end |
439 |
440 |
def test_gensurf |
441 |
442 |
cmd = "gensurf tmat tsurf '15.5+x(theta(s),phi(t))' '10.5+y(theta(s),phi(t))' '30.75+z(theta(s),phi(t))' 4 15 -f basin.cal -s > gensurf.rad" |
443 |
444 |
system(cmd) |
445 |
446 |
cmd = 'radcompare ref/gensurf.rad gensurf.rad' |
447 |
448 |
system(cmd) |
449 |
450 |
rcpf |
451 |
end |
452 |
#rm -f gensurf.rad |
453 |
end |
454 |
455 |
456 |
### END test/gen ### |
457 |
458 |
459 |
### test/cal ### |
460 |
461 |
def test_cnt |
462 |
gen_cnt_txt if !File.exist?('../test/cal/cnt.txt') |
463 |
Dir.chdir('../test/cal') do |
464 |
cmd = 'radcompare ref/cnt.txt cnt.txt' |
465 |
466 |
system(cmd) |
467 |
468 |
rcpf |
469 |
end |
470 |
end |
471 |
472 |
def gen_cnt_txt |
473 |
474 |
cmd = 'cnt 5 3 2 > cnt.txt' |
475 |
476 |
system(cmd) |
477 |
end |
478 |
end |
479 |
480 |
def gen_rcalc_txt |
481 |
482 |
cmd = "rcalc -o 'Test $${v1} $$(s1) $${v2}' -e 'v1=$$1*$$2;v2=($$2-$$1)*exp($$3)' -s s1=HEY cnt.txt > rcalc.txt" |
483 |
484 |
system(cmd) |
485 |
end |
486 |
end |
487 |
488 |
def test_rcalc |
489 |
gen_rcalc_txt if !File.exist?('../test/cal/rcalc.txt') |
490 |
491 |
cmd = 'radcompare ref/rcalc.txt rcalc.txt' |
492 |
493 |
system(cmd) |
494 |
495 |
rcpf |
496 |
end |
497 |
end |
498 |
499 |
def gen_total_txt |
500 |
501 |
502 |
build = [ |
503 |
'total cnt.txt > total.txt', |
504 |
'total -l cnt.txt >> total.txt', |
505 |
'total -u cnt.txt >> total.txt', |
506 |
'total -m cnt.txt >> total.txt', |
507 |
'total -s2.5 cnt.txt >> total.txt', |
508 |
'total -3 -r cnt.txt >> total.txt' |
509 |
510 |
build.each do |cmd| |
511 |
system(cmd) |
512 |
end |
513 |
end |
514 |
end |
515 |
516 |
def test_total |
517 |
gen_total_txt if !File.exist?('../test/cal/total.txt') |
518 |
519 |
cmd = 'radcompare ref/total.txt total.txt' |
520 |
521 |
system(cmd) |
522 |
523 |
rcpf |
524 |
end |
525 |
end |
526 |
527 |
def gen_histo_txt |
528 |
529 |
530 |
cmd = 'histo 0 60 5 < total.txt > histo.txt' |
531 |
532 |
system(cmd) |
533 |
534 |
end |
535 |
end |
536 |
537 |
def test_histo |
538 |
gen_histo_txt if !File.exist?('../test/cal/histo.txt') |
539 |
540 |
cmd = 'radcompare ref/histo.txt histo.txt' |
541 |
542 |
system(cmd) |
543 |
544 |
rcpf |
545 |
end |
546 |
end |
547 |
548 |
def gen_rlam_txt |
549 |
550 |
551 |
552 |
553 |
554 |
cmd = 'rlam -in 5 total.txt cnt.txt histo.txt > rlam.txt' |
555 |
556 |
system(cmd) |
557 |
558 |
end |
559 |
end |
560 |
561 |
def test_rlam |
562 |
gen_rlam_txt if !File.exist?('../test/cal/rlam.txt') |
563 |
564 |
cmd = 'radcompare ref/rlam.txt rlam.txt' |
565 |
566 |
system(cmd) |
567 |
568 |
rcpf |
569 |
end |
570 |
end |
571 |
572 |
573 |
### END test/cal ### |
574 |
575 |
### END test methods ### |
576 |
577 |
# call the test already |
578 |
579 |
if test_in == "all" |
580 |
all_tests.each do |test_in| |
581 |
test_total += 1 |
582 |
puts "running test: #{test_in}" |
583 |
method(test_in).call |
584 |
puts '' |
585 |
end |
586 |
else |
587 |
test_total += 1 |
588 |
589 |
590 |
puts '' |
591 |
end |
592 |
593 |
puts "### Total tests: #{test_total} (Passed: #{@test_pass} Failed: #{@test_fail}) ###" |
594 |
595 |
# do some cleanup |
596 |
# rm... |
597 |
# or not |
