root/Development/ray/resources/cmake_tests/test_rtrace.cmake
Revision: 1.2
Committed: Mon Jan 8 16:51:31 2018 UTC (7 years, 11 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, HEAD
Changes since 1.1: +7 -7 lines
Error occurred while calculating annotation data.
Update to CMake build system from Rob G. and Alex S., adding test cases
1 include(setup_paths.cmake)
2 file(WRITE ${test_output_dir}/rtrace.in
3 "0 0 0 0 0 -1
4 ")
5 execute_process(
6 WORKING_DIRECTORY ${test_output_dir}
7 COMMAND rtrace${CMAKE_EXECUTABLE_SUFFIX} -ab 1 cornell_box.oct
8 INPUT_FILE rtrace.in
9 OUTPUT_FILE rtrace.out
10 RESULT_VARIABLE res
11 )
12 if(NOT ${res} EQUAL 0)
13 message(FATAL_ERROR "Bad return value from rtrace, res = ${res}")
14 endif()
15
16 file(READ ${test_output_dir}/rtrace.out test_output)
17 if(test_output MATCHES "SOFTWARE= RADIANCE")
18 message(STATUS "passed")
19 else()
20 message(STATUS "failed")
21 endif()
