Revision: | 1.2 |
Committed: | Mon Jan 8 16:51:31 2018 UTC (6 years, 4 months ago) by greg |
Branch: | MAIN |
CVS Tags: | rad5R2 |
Changes since 1.1: | +4 -6 lines |
Log Message: | Update to CMake build system from Rob G. and Alex S., adding test cases |
# | Content |
1 | include(setup_paths.cmake) |
2 | |
3 | execute_process( |
4 | COMMAND getinfo${CMAKE_EXECUTABLE_SUFFIX} ${resources_dir}/evalglare/testimage.hdr |
5 | OUTPUT_FILE test_output |
6 | RESULT_VARIABLE res |
7 | ) |
8 | if(NOT ${res} EQUAL 0) |
9 | message(FATAL_ERROR "Bad return value from getinfo, res = ${res}") |
10 | endif() |
11 | |
12 | file(READ ${resources_dir}/evalglare/testimage.hdr test_output) |
13 | if(test_output MATCHES "RADIANCE") |
14 | message(STATUS "passed") |
15 | else() |
16 | message(STATUS "failed") |
17 | endif() |
