root/radiance/ray/resources/cmake_tests/test_DC.cmake
Revision: 1.2
Committed: Mon Jan 8 16:51:31 2018 UTC (7 years, 3 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, HEAD
Error occurred while calculating annotation data.
Update to CMake build system from Rob G. and Alex S., adding test cases
1 include(setup_paths.cmake)
2
3 file(MAKE_DIRECTORY "${test_output_dir}/dc")
4
5 set(view_def -x 50 -y 50 -vf model.vp)
6
7 file(WRITE "${office_dir}/test/raytest_dc.sky"
8 "void glow skyglow\n0\n0\n4\n1 1 1 0\n\nskyglow source sky\n0\n0\n4\n0 0 1 360
9 ")
10
11 message("Run: oconv${CMAKE_EXECUTABLE_SUFFIX} -f -i test/raytest_model.oct test/raytest_dc.sky")
12 execute_process(
13 WORKING_DIRECTORY ${office_dir}
14 COMMAND oconv${CMAKE_EXECUTABLE_SUFFIX} -f -i test/raytest_model.oct test/raytest_dc.sky
15 OUTPUT_FILE test/raytest_model_dc.oct
16 )
17
18 execute_process(
19 WORKING_DIRECTORY ${office_dir}
20 COMMAND vwrays${CMAKE_EXECUTABLE_SUFFIX} -d ${view_def}
21 OUTPUT_VARIABLE vwrays_out
22 )
23
24 message(STATUS "vwrays_out: ${vwrays_out}")
25 string(STRIP "${vwrays_out}" vwrays_out)
26 separate_arguments(vwrays_out)
27
28 message("Run: vwrays${CMAKE_EXECUTABLE_SUFFIX} -ff ${view_def} | rtcontrib${CMAKE_EXECUTABLE_SUFFIX} -ab 1 ${rtcontrib_threads}-V+ -fo -ffc $\(vwrays -d ${view_def}\) -f tregenza.cal -bn 146 -b tbin -o ${test_output_dir}/dc/treg%03d.hdr -m skyglow test/raytest_model_dc.oct")
29 execute_process(
30 WORKING_DIRECTORY ${office_dir}
31 COMMAND vwrays${CMAKE_EXECUTABLE_SUFFIX} -ff ${view_def}
32 COMMAND rtcontrib${CMAKE_EXECUTABLE_SUFFIX} -ab 1 ${rtcontrib_threads}-V+ -fo -ffc ${vwrays_out} -f tregenza.cal -bn 146 -b tbin -o ${test_output_dir}/dc/treg%03d.hdr -m skyglow test/raytest_model_dc.oct
33 RESULT_VARIABLE res
34 )
35 if(NOT ${res} EQUAL 0)
36 message(FATAL_ERROR "Bad return value from vwrays, res = ${res}")
37 endif()
38
39 execute_process(
40 WORKING_DIRECTORY ${office_dir}
41 COMMAND gensky${CMAKE_EXECUTABLE_SUFFIX} 03 21 12 -a 40 -o 105 -m 105 +s
42 COMMAND ${perl} ${util_dir}/genskyvec.pl -m 1
43 COMMAND dctimestep${CMAKE_EXECUTABLE_SUFFIX} test/dc/treg%03d.hdr
44 COMMAND pfilt${CMAKE_EXECUTABLE_SUFFIX} -1 -x /1 -y /1
45 OUTPUT_FILE test/raytest_timestep.hdr
46 RESULT_VARIABLE res
47 )
48
49 if(NOT ${res} EQUAL 0)
50 message(FATAL_ERROR "Bad return value, res = ${res}")
51 endif()
52
53 file(READ ${office_dir}/test/raytest_timestep.hdr test_output)
54 if(test_output MATCHES "dctimestep${CMAKE_EXECUTABLE_SUFFIX} test/dc/treg%03d.hdr")
55 message(STATUS "passed")
56 else()
57 message(STATUS "failed")
58 endif()
