root/radiance/ray/resources/cmake_tests/CMakeLists.txt
Revision: 1.3
Committed: Wed Apr 3 20:18:54 2019 UTC (6 years, 4 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3
Changes since 1.2: +6 -3 lines
Checked in Rob G's changes for unit testing
1 include(FindPerl)
2
3 set(resources_dir "${CMAKE_SOURCE_DIR}/resources")
4 set(rad_test_dir "${CMAKE_SOURCE_DIR}/test")
5
6 ### CONFIGURE TESTS
7
8 configure_file(setup_paths.cmake.in setup_paths.cmake @ONLY)
9 # configure these files so that they will be in the binary
10 # directory. This will allow them to include setup_paths.cmake
11 # from the binary directory and just use regular variables in the
12 # configured files.
13 configure_file(test_setup.cmake test_setup.cmake COPYONLY)
14 configure_file(test_rtrace.cmake test_rtrace.cmake COPYONLY)
15 configure_file(test_rpict.cmake test_rpict.cmake COPYONLY)
16 configure_file(test_pcond.cmake test_pcond.cmake COPYONLY)
17 configure_file(test_falsecolor.cmake test_falsecolor.cmake COPYONLY)
18 configure_file(test_DC.cmake test_DC.cmake COPYONLY)
19 configure_file(test_evalglare.cmake test_evalglare.cmake COPYONLY)
20
21 ### ADD TESTS
22
23 add_test(test_setup ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_setup.cmake)
24
25 add_test(test_rtrace ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_rtrace.cmake)
26 set_tests_properties(test_rtrace PROPERTIES
27 PASS_REGULAR_EXPRESSION "passed"
28 FAIL_REGULAR_EXPRESSION "failed"
29 )
30
31 add_test(test_rpict ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_rpict.cmake)
32 set_tests_properties(test_rpict PROPERTIES
33 PASS_REGULAR_EXPRESSION "passed"
34 FAIL_REGULAR_EXPRESSION "failed"
35 )
36
37 add_test(test_pcond ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_pcond.cmake)
38 set_tests_properties(test_pcond PROPERTIES
39 PASS_REGULAR_EXPRESSION "passed"
40 FAIL_REGULAR_EXPRESSION "failed"
41 )
42
43 add_test(test_evalglare ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_evalglare.cmake)
44 set_tests_properties(test_evalglare PROPERTIES
45 PASS_REGULAR_EXPRESSION "passed"
46 FAIL_REGULAR_EXPRESSION "failed"
47 )
48
49
50 if(PERL_FOUND)
51 add_test(test_falsecolor ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_falsecolor.cmake)
52 set_tests_properties(test_falsecolor PROPERTIES
53 PASS_REGULAR_EXPRESSION "passed"
54 FAIL_REGULAR_EXPRESSION "failed"
55 )
56 endif()
