1 |
include(FindPerl) |
2 |
3 |
set(resources_dir "${CMAKE_SOURCE_DIR}/resources") |
4 |
5 |
configure_file(setup_paths.cmake.in setup_paths.cmake @ONLY) |
6 |
# configure these files so that they will be in the binary |
7 |
# directory. This will allow them to include setup_paths.cmake |
8 |
# from the binary directory and just use regular variables in the |
9 |
# configured files. |
10 |
configure_file(test_setup.cmake test_setup.cmake COPYONLY) |
11 |
configure_file(test_rtrace.cmake test_rtrace.cmake COPYONLY) |
12 |
configure_file(test_rpict.cmake test_rpict.cmake COPYONLY) |
13 |
configure_file(test_getinfo.cmake test_getinfo.cmake COPYONLY) |
14 |
configure_file(test_pcond.cmake test_pcond.cmake COPYONLY) |
15 |
configure_file(test_falsecolor.cmake test_falsecolor.cmake COPYONLY) |
16 |
configure_file(test_DC.cmake test_DC.cmake COPYONLY) |
17 |
configure_file(test_evalglare.cmake test_evalglare.cmake COPYONLY) |
18 |
19 |
add_test(test_setup ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_setup.cmake) |
20 |
21 |
add_test(test_rtrace ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_rtrace.cmake) |
22 |
set_tests_properties(test_rtrace PROPERTIES |
23 |
PASS_REGULAR_EXPRESSION "passed" |
24 |
FAIL_REGULAR_EXPRESSION "failed" |
25 |
26 |
27 |
add_test(test_rpict ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_rpict.cmake) |
28 |
set_tests_properties(test_rpict PROPERTIES |
29 |
30 |
31 |
32 |
33 |
add_test(test_getinfo ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_getinfo.cmake) |
34 |
35 |
add_test(test_pcond ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_pcond.cmake) |
36 |
set_tests_properties(test_pcond PROPERTIES |
37 |
38 |
39 |
40 |
41 |
add_test(test_evalglare ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_evalglare.cmake) |
42 |
set_tests_properties(test_evalglare PROPERTIES |
43 |
44 |
45 |
46 |
47 |
if(PERL_FOUND) |
48 |
add_test(test_falsecolor ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_falsecolor.cmake) |
49 |
set_tests_properties(test_falsecolor PROPERTIES |
50 |
51 |
52 |
53 |
endif() |
