root/Development/ray/resources/cmake/modules/FindOpenGL.cmake
Revision: 1.1
Committed: Wed Nov 22 17:14:36 2023 UTC (2 years, 1 month ago) by greg
CVS Tags: rad6R0, HEAD
chore: method to find OpenGL by Randolph Fritz
# User Rev Content
1 greg 1.1 # Distributed under the OSI-approved BSD 3-Clause License. See accompanying
2     # file Copyright.txt or https://cmake.org/licensing for details.
3
4     #[=======================================================================[.rst:
5     FindOpenGL
6     ----------
7
8     FindModule for OpenGL and OpenGL Utility Library (GLU).
9
10     .. versionchanged:: 3.2
11     X11 is no longer added as a dependency on Unix/Linux systems.
12
13     .. versionadded:: 3.10
14     GLVND support on Linux. See the :ref:`Linux Specific` section below.
15
16     Optional COMPONENTS
17     ^^^^^^^^^^^^^^^^^^^
18
19     .. versionadded:: 3.10
20
21     This module respects several optional COMPONENTS:
22
23     ``EGL``
24     The EGL interface between OpenGL, OpenGL ES and the underlying windowing system.
25
26     ``GLX``
27     An extension to X that interfaces OpenGL, OpenGL ES with X window system.
28
29     ``OpenGL``
30     The cross platform API for 3D graphics.
31
32     ``GLES2``
33     .. versionadded:: 3.27
34
35     A subset of OpenGL API for embedded systems with limited capabilities.
36
37     ``GLES3``
38     .. versionadded:: 3.27
39
40     A subset of OpenGL API for embedded systems with more capabilities.
41
42     IMPORTED Targets
43     ^^^^^^^^^^^^^^^^
44
45     .. versionadded:: 3.8
46
47     This module defines the :prop_tgt:`IMPORTED` targets:
48
49     ``OpenGL::GL``
50     Defined to the platform-specific OpenGL libraries if the system has OpenGL.
51     ``OpenGL::GLU``
52     Defined if the system has OpenGL Utility Library (GLU).
53
54     .. versionadded:: 3.10
55     Additionally, the following GLVND-specific library targets are defined:
56
57     ``OpenGL::OpenGL``
58     Defined to libOpenGL if the system is GLVND-based.
59     ``OpenGL::GLX``
60     Defined if the system has OpenGL Extension to the X Window System (GLX).
61     ``OpenGL::EGL``
62     Defined if the system has EGL.
63     ``OpenGL::GLES2``
64     .. versionadded:: 3.27
65
66     Defined if the system has GLES2.
67     ``OpenGL::GLES3``
68     .. versionadded:: 3.27
69
70     Defined if the system has GLES3.
71
72     Result Variables
73     ^^^^^^^^^^^^^^^^
74
75     This module sets the following variables:
76
77     ``OPENGL_FOUND``
78     True, if the system has OpenGL and all components are found.
79     ``OPENGL_XMESA_FOUND``
80     True, if the system has XMESA.
81     ``OPENGL_GLU_FOUND``
82     True, if the system has GLU.
83     ``OpenGL_OpenGL_FOUND``
84     True, if the system has an OpenGL library.
85     ``OpenGL_GLX_FOUND``
86     True, if the system has GLX.
87     ``OpenGL_EGL_FOUND``
88     True, if the system has EGL.
89     ``OpenGL::GLES2``
90     Defined if the system has GLES2.
91     ``OpenGL::GLES3``
92     Defined if the system has GLES3.
93     ``OPENGL_INCLUDE_DIR``
94     Path to the OpenGL include directory.
95     ``OPENGL_EGL_INCLUDE_DIRS``
96     Path to the EGL include directory.
97     ``OPENGL_LIBRARIES``
98     Paths to the OpenGL library, windowing system libraries, and GLU libraries.
99     On Linux, this assumes GLX and is never correct for EGL-based targets.
100     Clients are encouraged to use the ``OpenGL::*`` import targets instead.
101
102     .. versionadded:: 3.10
103     Variables for GLVND-specific libraries ``OpenGL``, ``EGL`` and ``GLX``.
104
105     Cache variables
106     ^^^^^^^^^^^^^^^
107
108     The following cache variables may also be set:
109
110     ``OPENGL_egl_LIBRARY``
111     Path to the EGL library.
112     ``OPENGL_glu_LIBRARY``
113     Path to the GLU library.
114     ``OPENGL_glx_LIBRARY``
115     Path to the GLVND 'GLX' library.
116     ``OPENGL_opengl_LIBRARY``
117     Path to the GLVND 'OpenGL' library
118     ``OPENGL_gl_LIBRARY``
119     Path to the OpenGL library. New code should prefer the ``OpenGL::*`` import
120     targets.
121     ``OPENGL_gles2_LIBRARY``
122     .. versionadded:: 3.27
123
124     Path to the OpenGL GLES2 library.
125     ``OPENGL_gles3_LIBRARY``
126     .. versionadded:: 3.27
127
128     Path to the OpenGL GLES3 library.
129
130     .. versionadded:: 3.10
131     Variables for GLVND-specific libraries ``OpenGL``, ``EGL`` and ``GLX``.
132
133     .. _`Linux Specific`:
134
135     Linux-specific
136     ^^^^^^^^^^^^^^
137
138     Some Linux systems utilize GLVND as a new ABI for OpenGL. GLVND separates
139     context libraries from OpenGL itself; OpenGL lives in "libOpenGL", and
140     contexts are defined in "libGLX" or "libEGL". GLVND is currently the only way
141     to get OpenGL 3+ functionality via EGL in a manner portable across vendors.
142     Projects may use GLVND explicitly with target ``OpenGL::OpenGL`` and either
143     ``OpenGL::GLX`` or ``OpenGL::EGL``.
144
145     Projects may use the ``OpenGL::GL`` target (or ``OPENGL_LIBRARIES`` variable)
146     to use legacy GL interfaces. These will use the legacy GL library located
147     by ``OPENGL_gl_LIBRARY``, if available. If ``OPENGL_gl_LIBRARY`` is empty or
148     not found and GLVND is available, the ``OpenGL::GL`` target will use GLVND
149     ``OpenGL::OpenGL`` and ``OpenGL::GLX`` (and the ``OPENGL_LIBRARIES``
150     variable will use the corresponding libraries). Thus, for non-EGL-based
151     Linux targets, the ``OpenGL::GL`` target is most portable.
152
153     A ``OpenGL_GL_PREFERENCE`` variable may be set to specify the preferred way
154     to provide legacy GL interfaces in case multiple choices are available.
155     The value may be one of:
156
157     ``GLVND``
158     If the GLVND OpenGL and GLX libraries are available, prefer them.
159     This forces ``OPENGL_gl_LIBRARY`` to be empty.
160
161     .. versionchanged:: 3.11
162     This is the default, unless policy :policy:`CMP0072` is set to ``OLD``
163     and no components are requested (since components
164     correspond to GLVND libraries).
165
166     ``LEGACY``
167     Prefer to use the legacy libGL library, if available.
168
169     For EGL targets the client must rely on GLVND support on the user's system.
170     Linking should use the ``OpenGL::OpenGL OpenGL::EGL`` targets. Using GLES*
171     libraries is theoretically possible in place of ``OpenGL::OpenGL``, but this
172     module does not currently support that; contributions welcome.
173
174     ``OPENGL_egl_LIBRARY`` and ``OPENGL_EGL_INCLUDE_DIRS`` are defined in the case of
175     GLVND. For non-GLVND Linux and other systems these are left undefined.
176
177     macOS-Specific
178     ^^^^^^^^^^^^^^
179
180     On macOS FindOpenGL defaults to using the macOS-native framework
181     version of OpenGL. To use the X11 version of OpenGL on macOS, you
182     need to disable searching of frameworks and point CMake to the X11
183     libraries. Using the XQuartz X11 server, do something like this::
184
185     if(APPLE AND X11_FOUND)
186     set(CMAKE_FIND_FRAMEWORK NEVER)
187     set(OpenGL_ROOT "/opt/X11") # or whatever your X11 server root is
188     find_package(OpenGL)
189     set(CMAKE_FIND_FRAMEWORK "")
190     else()
191     find_package(OpenGL)
192     endif()
193
194     You must first use find_package(X11) to ensure that X11 is available.
195
196     #]=======================================================================]
197
198     set(_OpenGL_REQUIRED_VARS OPENGL_gl_LIBRARY)
199
200     # Provide OPENGL_USE_<C> variables for each component.
201     foreach(component ${OpenGL_FIND_COMPONENTS})
202     string(TOUPPER ${component} _COMPONENT)
203     set(OPENGL_USE_${_COMPONENT} 1)
204     endforeach()
205
206     set(_OpenGL_CACHE_VARS)
207
208     if (WIN32)
209
210     if(BORLAND)
211     set (OPENGL_gl_LIBRARY import32 CACHE STRING "OpenGL library for win32")
212     set (OPENGL_glu_LIBRARY import32 CACHE STRING "GLU library for win32")
213     else()
214     set (OPENGL_gl_LIBRARY opengl32 CACHE STRING "OpenGL library for win32")
215     set (OPENGL_glu_LIBRARY glu32 CACHE STRING "GLU library for win32")
216     endif()
217
218     list(APPEND _OpenGL_CACHE_VARS
219     OPENGL_gl_LIBRARY
220     OPENGL_glu_LIBRARY
221     )
222     elseif (APPLE)
223     # The OpenGL.framework provides both gl and glu in OpenGL
224     # XQuartz provides libgl and libglu
225     find_library(OPENGL_gl_LIBRARY NAMES OpenGL GL DOC
226     "OpenGL GL library")
227     find_library(OPENGL_glu_LIBRARY NAMES OpenGL GLU DOC
228     "OpenGL GLU library")
229     find_path(OPENGL_INCLUDE_DIR NAMES OpenGL/gl.h GL/gl.h DOC
230     "Include for OpenGL")
231     list(APPEND _OpenGL_REQUIRED_VARS OPENGL_INCLUDE_DIR)
232
233     list(APPEND _OpenGL_CACHE_VARS
234     OPENGL_INCLUDE_DIR
235     OPENGL_gl_LIBRARY
236     OPENGL_glu_LIBRARY
237     )
238     else()
239     if (CMAKE_ANDROID_NDK)
240     set(_OPENGL_INCLUDE_PATH ${CMAKE_ANDROID_NDK}/sysroot/usr/include)
241     set(_OPENGL_LIB_PATH ${CMAKE_ANDROID_NDK}/platforms/android-${CMAKE_SYSTEM_VERSION}/arch-${CMAKE_ANDROID_ARCH}/usr/lib)
242     elseif (CMAKE_SYSTEM_NAME MATCHES "HP-UX")
243     # Handle HP-UX cases where we only want to find OpenGL in either hpux64
244     # or hpux32 depending on if we're doing a 64 bit build.
245     if(CMAKE_SIZEOF_VOID_P EQUAL 4)
246     set(_OPENGL_LIB_PATH
247     /opt/graphics/OpenGL/lib/hpux32/)
248     else()
249     set(_OPENGL_LIB_PATH
250     /opt/graphics/OpenGL/lib/hpux64/
251     /opt/graphics/OpenGL/lib/pa20_64)
252     endif()
253     elseif(CMAKE_SYSTEM_NAME STREQUAL Haiku)
254     set(_OPENGL_LIB_PATH
255     /boot/develop/lib/x86)
256     set(_OPENGL_INCLUDE_PATH
257     /boot/develop/headers/os/opengl)
258     elseif (CMAKE_SYSTEM_NAME STREQUAL "Linux")
259     # CMake doesn't support arbitrary globs in search paths.
260     file(GLOB _OPENGL_LIB_PATH
261     # The NVidia driver installation tool on Linux installs libraries to a
262     # `nvidia-<version>` subdirectory.
263     "/usr/lib/nvidia-*"
264     "/usr/lib32/nvidia-*")
265     endif()
266
267     # The first line below is to make sure that the proper headers
268     # are used on a Linux machine with the NVidia drivers installed.
269     # They replace Mesa with NVidia's own library but normally do not
270     # install headers and that causes the linking to
271     # fail since the compiler finds the Mesa headers but NVidia's library.
272     # Make sure the NVIDIA directory comes BEFORE the others.
273     # - Atanas Georgiev <[email protected]>
274     find_path(OPENGL_INCLUDE_DIR GL/gl.h
275     /usr/share/doc/NVIDIA_GLX-1.0/include
276     /usr/openwin/share/include
277     /opt/graphics/OpenGL/include
278     ${_OPENGL_INCLUDE_PATH}
279     )
280     find_path(OPENGL_GLX_INCLUDE_DIR GL/glx.h ${_OPENGL_INCLUDE_PATH})
281     find_path(OPENGL_EGL_INCLUDE_DIR EGL/egl.h ${_OPENGL_INCLUDE_PATH})
282     find_path(OPENGL_GLES2_INCLUDE_DIR GLES2/gl2.h ${_OPENGL_INCLUDE_PATH})
283     find_path(OPENGL_GLES3_INCLUDE_DIR GLES3/gl3.h ${_OPENGL_INCLUDE_PATH})
284     find_path(OPENGL_xmesa_INCLUDE_DIR GL/xmesa.h
285     /usr/share/doc/NVIDIA_GLX-1.0/include
286     /usr/openwin/share/include
287     /opt/graphics/OpenGL/include
288     )
289
290     list(APPEND _OpenGL_CACHE_VARS
291     OPENGL_INCLUDE_DIR
292     OPENGL_GLX_INCLUDE_DIR
293     OPENGL_EGL_INCLUDE_DIR
294     OPENGL_GLES2_INCLUDE_DIR
295     OPENGL_GLES3_INCLUDE_DIR
296     OPENGL_xmesa_INCLUDE_DIR
297     )
298
299     # Search for the GLVND libraries. We do this regardless of COMPONENTS; we'll
300     # take into account the COMPONENTS logic later.
301     find_library(OPENGL_opengl_LIBRARY
302     NAMES OpenGL
303     PATHS ${_OPENGL_LIB_PATH}
304     )
305
306     find_library(OPENGL_glx_LIBRARY
307     NAMES GLX
308     PATHS ${_OPENGL_LIB_PATH}
309     PATH_SUFFIXES libglvnd
310     )
311
312     find_library(OPENGL_egl_LIBRARY
313     NAMES EGL
314     PATHS ${_OPENGL_LIB_PATH}
315     PATH_SUFFIXES libglvnd
316     )
317
318     find_library(OPENGL_gles2_LIBRARY
319     NAMES GLESv2
320     PATHS ${_OPENGL_LIB_PATH}
321     )
322
323     find_library(OPENGL_gles3_LIBRARY
324     NAMES GLESv3
325     GLESv2 # mesa provides only libGLESv2
326     PATHS ${_OPENGL_LIB_PATH}
327     )
328
329     find_library(OPENGL_glu_LIBRARY
330     NAMES GLU MesaGLU
331     PATHS ${OPENGL_gl_LIBRARY}
332     /opt/graphics/OpenGL/lib
333     /usr/openwin/lib
334     /usr/shlib
335     )
336
337     list(APPEND _OpenGL_CACHE_VARS
338     OPENGL_opengl_LIBRARY
339     OPENGL_glx_LIBRARY
340     OPENGL_egl_LIBRARY
341     OPENGL_gles2_LIBRARY
342     OPENGL_gles3_LIBRARY
343     OPENGL_glu_LIBRARY
344     )
345
346     set(_OpenGL_GL_POLICY_WARN 0)
347     if(NOT DEFINED OpenGL_GL_PREFERENCE)
348     set(OpenGL_GL_PREFERENCE "")
349     endif()
350     if(NOT OpenGL_GL_PREFERENCE STREQUAL "")
351     # A preference has been explicitly specified.
352     if(NOT OpenGL_GL_PREFERENCE MATCHES "^(GLVND|LEGACY)$")
353     message(FATAL_ERROR
354     "OpenGL_GL_PREFERENCE value '${OpenGL_GL_PREFERENCE}' not recognized. "
355     "Allowed values are 'GLVND' and 'LEGACY'."
356     )
357     endif()
358     elseif(OpenGL_FIND_COMPONENTS)
359     # No preference was explicitly specified, but the caller did request
360     # at least one GLVND component. Prefer GLVND for legacy GL.
361     set(OpenGL_GL_PREFERENCE "GLVND")
362     else()
363     # No preference was explicitly specified and no GLVND components were
364     # requested. Use a policy to choose the default.
365     cmake_policy(GET CMP0072 _OpenGL_GL_POLICY)
366     if("x${_OpenGL_GL_POLICY}x" STREQUAL "xNEWx")
367     set(OpenGL_GL_PREFERENCE "GLVND")
368     else()
369     set(OpenGL_GL_PREFERENCE "LEGACY")
370     if("x${_OpenGL_GL_POLICY}x" STREQUAL "xx")
371     set(_OpenGL_GL_POLICY_WARN 1)
372     endif()
373     endif()
374     unset(_OpenGL_GL_POLICY)
375     endif()
376
377     if("x${OpenGL_GL_PREFERENCE}x" STREQUAL "xGLVNDx" AND OPENGL_opengl_LIBRARY AND OPENGL_glx_LIBRARY)
378     # We can provide legacy GL using GLVND libraries.
379     # Do not use any legacy GL library.
380     set(OPENGL_gl_LIBRARY "")
381     else()
382     # We cannot provide legacy GL using GLVND libraries.
383     # Search for the legacy GL library.
384     find_library(OPENGL_gl_LIBRARY
385     NAMES GL MesaGL
386     PATHS /opt/graphics/OpenGL/lib
387     /usr/openwin/lib
388     /usr/shlib
389     ${_OPENGL_LIB_PATH}
390     PATH_SUFFIXES libglvnd
391     )
392     list(APPEND _OpenGL_CACHE_VARS OPENGL_gl_LIBRARY)
393     endif()
394
395     if(_OpenGL_GL_POLICY_WARN AND OPENGL_gl_LIBRARY AND OPENGL_opengl_LIBRARY AND OPENGL_glx_LIBRARY)
396     cmake_policy(GET_WARNING CMP0072 _cmp0072_warning)
397     message(AUTHOR_WARNING
398     "${_cmp0072_warning}\n"
399     "FindOpenGL found both a legacy GL library:\n"
400     " OPENGL_gl_LIBRARY: ${OPENGL_gl_LIBRARY}\n"
401     "and GLVND libraries for OpenGL and GLX:\n"
402     " OPENGL_opengl_LIBRARY: ${OPENGL_opengl_LIBRARY}\n"
403     " OPENGL_glx_LIBRARY: ${OPENGL_glx_LIBRARY}\n"
404     "OpenGL_GL_PREFERENCE has not been set to \"GLVND\" or \"LEGACY\", so for "
405     "compatibility with CMake 3.10 and below the legacy GL library will be used."
406     )
407     endif()
408     unset(_OpenGL_GL_POLICY_WARN)
409
410     # FPHSA cannot handle "this OR that is required", so we conditionally set what
411     # it must look for. First clear any previous config we might have done:
412     set(_OpenGL_REQUIRED_VARS)
413
414     # now we append the libraries as appropriate. The complicated logic
415     # basically comes down to "use libOpenGL when we can, and add in specific
416     # context mechanisms when requested, or we need them to preserve the previous
417     # default where glx is always available."
418     if((NOT OPENGL_USE_EGL AND
419     NOT OPENGL_opengl_LIBRARY AND
420     OPENGL_glx_LIBRARY AND
421     NOT OPENGL_gl_LIBRARY) OR
422     (NOT OPENGL_USE_EGL AND
423     NOT OPENGL_USE_GLES3 AND
424     NOT OPENGL_USE_GLES2 AND
425     NOT OPENGL_glx_LIBRARY AND
426     NOT OPENGL_gl_LIBRARY) OR
427     (NOT OPENGL_USE_EGL AND
428     OPENGL_opengl_LIBRARY AND
429     OPENGL_glx_LIBRARY) OR
430     (NOT OPENGL_USE_GLES3 AND
431     NOT OPENGL_USE_GLES2 AND
432     OPENGL_USE_EGL))
433     list(APPEND _OpenGL_REQUIRED_VARS OPENGL_opengl_LIBRARY)
434     endif()
435
436     # GLVND GLX library. Preferred when available.
437     if((NOT OPENGL_USE_OPENGL AND
438     NOT OPENGL_USE_GLX AND
439     NOT OPENGL_USE_EGL AND
440     NOT OPENGL_USE_GLES3 AND
441     NOT OPENGL_USE_GLES2 AND
442     NOT OPENGL_glx_LIBRARY AND
443     NOT OPENGL_gl_LIBRARY) OR
444     ( OPENGL_USE_GLX AND
445     NOT OPENGL_USE_EGL AND
446     NOT OPENGL_USE_GLES3 AND
447     NOT OPENGL_USE_GLES2 AND
448     NOT OPENGL_glx_LIBRARY AND
449     NOT OPENGL_gl_LIBRARY) OR
450     (NOT OPENGL_USE_EGL AND
451     NOT OPENGL_USE_GLES3 AND
452     NOT OPENGL_USE_GLES2 AND
453     OPENGL_opengl_LIBRARY AND
454     OPENGL_glx_LIBRARY) OR
455     (OPENGL_USE_GLX AND OPENGL_USE_EGL))
456     list(APPEND _OpenGL_REQUIRED_VARS OPENGL_glx_LIBRARY)
457     endif()
458
459     # GLVND EGL library.
460     if(OPENGL_USE_EGL)
461     list(APPEND _OpenGL_REQUIRED_VARS OPENGL_egl_LIBRARY)
462     endif()
463
464     # GLVND GLES2 library.
465     if(OPENGL_USE_GLES2)
466     list(APPEND _OpenGL_REQUIRED_VARS OPENGL_gles2_LIBRARY)
467     endif()
468
469     # GLVND GLES3 library.
470     if(OPENGL_USE_GLES3)
471     list(APPEND _OpenGL_REQUIRED_VARS OPENGL_gles3_LIBRARY)
472     endif()
473
474     # Old-style "libGL" library: used as a fallback when GLVND isn't available.
475     if((NOT OPENGL_USE_EGL AND
476     NOT OPENGL_opengl_LIBRARY AND
477     OPENGL_glx_LIBRARY AND
478     OPENGL_gl_LIBRARY) OR
479     (NOT OPENGL_USE_EGL AND
480     NOT OPENGL_glx_LIBRARY AND
481     OPENGL_gl_LIBRARY))
482     list(PREPEND _OpenGL_REQUIRED_VARS OPENGL_gl_LIBRARY)
483     endif()
484
485     # We always need the 'gl.h' include dir.
486     if(OPENGL_USE_EGL)
487     list(APPEND _OpenGL_REQUIRED_VARS OPENGL_EGL_INCLUDE_DIR)
488     else()
489     list(APPEND _OpenGL_REQUIRED_VARS OPENGL_INCLUDE_DIR)
490     endif()
491
492     unset(_OPENGL_INCLUDE_PATH)
493     unset(_OPENGL_LIB_PATH)
494
495     find_library(OPENGL_glu_LIBRARY
496     NAMES GLU MesaGLU
497     PATHS ${OPENGL_gl_LIBRARY}
498     /opt/graphics/OpenGL/lib
499     /usr/openwin/lib
500     /usr/shlib
501     )
502     endif ()
503
504     if(OPENGL_xmesa_INCLUDE_DIR)
505     set( OPENGL_XMESA_FOUND "YES" )
506     else()
507     set( OPENGL_XMESA_FOUND "NO" )
508     endif()
509
510     if(OPENGL_glu_LIBRARY)
511     set( OPENGL_GLU_FOUND "YES" )
512     else()
513     set( OPENGL_GLU_FOUND "NO" )
514     endif()
515
516     # OpenGL_OpenGL_FOUND is a bit unique in that it is okay if /either/ libOpenGL
517     # or libGL is found.
518     # Using libGL with libEGL is never okay, though; we handle that case later.
519     if(NOT OPENGL_opengl_LIBRARY AND NOT OPENGL_gl_LIBRARY)
520     set(OpenGL_OpenGL_FOUND FALSE)
521     else()
522     set(OpenGL_OpenGL_FOUND TRUE)
523     endif()
524
525     if(OPENGL_glx_LIBRARY AND OPENGL_GLX_INCLUDE_DIR)
526     set(OpenGL_GLX_FOUND TRUE)
527     else()
528     set(OpenGL_GLX_FOUND FALSE)
529     endif()
530
531     if(OPENGL_egl_LIBRARY AND OPENGL_EGL_INCLUDE_DIR)
532     set(OpenGL_EGL_FOUND TRUE)
533     else()
534     set(OpenGL_EGL_FOUND FALSE)
535     endif()
536
537     if(OPENGL_gles2_LIBRARY AND OPENGL_GLES2_INCLUDE_DIR)
538     set(OpenGL_GLES2_FOUND TRUE)
539     else()
540     set(OpenGL_GLES2_FOUND FALSE)
541     endif()
542
543     if(OPENGL_gles3_LIBRARY AND OPENGL_GLES3_INCLUDE_DIR)
544     set(OpenGL_GLES3_FOUND TRUE)
545     else()
546     set(OpenGL_GLES3_FOUND FALSE)
547     endif()
548
549     # User-visible names should be plural.
550     if(OPENGL_EGL_INCLUDE_DIR)
551     set(OPENGL_EGL_INCLUDE_DIRS ${OPENGL_EGL_INCLUDE_DIR})
552     endif()
553
554     include(FindPackageHandleStandardArgs)
555     if (CMAKE_FIND_PACKAGE_NAME STREQUAL "GLU")
556     # FindGLU include()'s this module. It's an old pattern, but rather than
557     # trying to suppress this from outside the module (which is then sensitive to
558     # the contents, detect the case in this module and suppress it explicitly.
559     set(FPHSA_NAME_MISMATCHED 1)
560     endif ()
561     FIND_PACKAGE_HANDLE_STANDARD_ARGS(OpenGL REQUIRED_VARS ${_OpenGL_REQUIRED_VARS}
562     HANDLE_COMPONENTS)
563     unset(FPHSA_NAME_MISMATCHED)
564     unset(_OpenGL_REQUIRED_VARS)
565
566     # OpenGL:: targets
567     if(OPENGL_FOUND)
568     # ::OpenGL is a GLVND library, and thus Linux-only: we don't bother checking
569     # for a framework version of this library.
570     if(OPENGL_opengl_LIBRARY AND NOT TARGET OpenGL::OpenGL)
571     if(IS_ABSOLUTE "${OPENGL_opengl_LIBRARY}")
572     add_library(OpenGL::OpenGL UNKNOWN IMPORTED)
573     set_target_properties(OpenGL::OpenGL PROPERTIES IMPORTED_LOCATION
574     "${OPENGL_opengl_LIBRARY}")
575     else()
576     add_library(OpenGL::OpenGL INTERFACE IMPORTED)
577     set_target_properties(OpenGL::OpenGL PROPERTIES IMPORTED_LIBNAME
578     "${OPENGL_opengl_LIBRARY}")
579     endif()
580     set_target_properties(OpenGL::OpenGL PROPERTIES INTERFACE_INCLUDE_DIRECTORIES
581     "${OPENGL_INCLUDE_DIR}")
582     set(_OpenGL_EGL_IMPL OpenGL::OpenGL)
583     endif()
584
585     # ::GLX is a GLVND library, and thus Linux-only: we don't bother checking
586     # for a framework version of this library.
587     if(OpenGL_GLX_FOUND AND NOT TARGET OpenGL::GLX AND TARGET OpenGL::OpenGL)
588     if(IS_ABSOLUTE "${OPENGL_glx_LIBRARY}")
589     add_library(OpenGL::GLX UNKNOWN IMPORTED)
590     set_target_properties(OpenGL::GLX PROPERTIES IMPORTED_LOCATION
591     "${OPENGL_glx_LIBRARY}")
592     else()
593     add_library(OpenGL::GLX INTERFACE IMPORTED)
594     set_target_properties(OpenGL::GLX PROPERTIES IMPORTED_LIBNAME
595     "${OPENGL_glx_LIBRARY}")
596     endif()
597     set_target_properties(OpenGL::GLX PROPERTIES INTERFACE_LINK_LIBRARIES
598     OpenGL::OpenGL)
599     set_target_properties(OpenGL::GLX PROPERTIES INTERFACE_INCLUDE_DIRECTORIES
600     "${OPENGL_GLX_INCLUDE_DIR}")
601     endif()
602
603     # ::GLES2 is a GLVND library, and thus Linux-only: we don't bother checking
604     # for a framework version of this library.
605     if(OpenGL_GLES2_FOUND AND NOT TARGET OpenGL::GLES2)
606
607     # Initialize target
608     if(NOT OPENGL_gles2_LIBRARY)
609     add_library(OpenGL::GLES2 INTERFACE IMPORTED)
610     else()
611     if(IS_ABSOLUTE "${OPENGL_gles2_LIBRARY}")
612     add_library(OpenGL::GLES2 UNKNOWN IMPORTED)
613     set_target_properties(OpenGL::GLES2 PROPERTIES
614     IMPORTED_LOCATION "${OPENGL_gles2_LIBRARY}"
615     )
616     else()
617     add_library(OpenGL::GLES2 INTERFACE IMPORTED)
618     set_target_properties(OpenGL::GLES2 PROPERTIES
619     IMPORTED_LIBNAME "${OPENGL_gles2_LIBRARY}"
620     )
621     endif()
622     endif()
623
624     # Attach target properties
625     set_target_properties(OpenGL::GLES2
626     PROPERTIES
627     INTERFACE_INCLUDE_DIRECTORIES
628     "${OPENGL_GLES2_INCLUDE_DIR}"
629     )
630
631     if (OPENGL_USE_GLES2)
632     set(_OpenGL_EGL_IMPL OpenGL::GLES2)
633     endif ()
634
635     endif()
636
637     # ::GLES3 is a GLVND library, and thus Linux-only: we don't bother checking
638     # for a framework version of this library.
639     if(OpenGL_GLES3_FOUND AND NOT TARGET OpenGL::GLES3)
640
641     # Initialize target
642     if(NOT OPENGL_gles3_LIBRARY)
643     add_library(OpenGL::GLES3 INTERFACE IMPORTED)
644     else()
645     if(IS_ABSOLUTE "${OPENGL_gles3_LIBRARY}")
646     add_library(OpenGL::GLES3 UNKNOWN IMPORTED)
647     set_target_properties(OpenGL::GLES3 PROPERTIES
648     IMPORTED_LOCATION "${OPENGL_gles3_LIBRARY}"
649     )
650     else()
651     add_library(OpenGL::GLES3 INTERFACE IMPORTED)
652     set_target_properties(OpenGL::GLES3 PROPERTIES
653     IMPORTED_LIBNAME "${OPENGL_gles3_LIBRARY}"
654     )
655     endif()
656     endif()
657
658     # Attach target properties
659     set_target_properties(OpenGL::GLES3 PROPERTIES
660     INTERFACE_INCLUDE_DIRECTORIES
661     "${OPENGL_GLES3_INCLUDE_DIR}"
662     )
663
664     if (OPENGL_USE_GLES3)
665     set(_OpenGL_EGL_IMPL OpenGL::GLES3)
666     endif ()
667
668     endif()
669
670     if(OPENGL_gl_LIBRARY AND NOT TARGET OpenGL::GL)
671     # A legacy GL library is available, so use it for the legacy GL target.
672     if(IS_ABSOLUTE "${OPENGL_gl_LIBRARY}")
673     add_library(OpenGL::GL UNKNOWN IMPORTED)
674     if(OPENGL_gl_LIBRARY MATCHES "/([^/]+)\\.framework$")
675     set(_gl_fw "${OPENGL_gl_LIBRARY}/${CMAKE_MATCH_1}")
676     if(EXISTS "${_gl_fw}.tbd")
677     string(APPEND _gl_fw ".tbd")
678     endif()
679     set_target_properties(OpenGL::GL PROPERTIES
680     IMPORTED_LOCATION "${_gl_fw}")
681     else()
682     set_target_properties(OpenGL::GL PROPERTIES
683     IMPORTED_LOCATION "${OPENGL_gl_LIBRARY}")
684     endif()
685     else()
686     add_library(OpenGL::GL INTERFACE IMPORTED)
687     set_target_properties(OpenGL::GL PROPERTIES
688     IMPORTED_LIBNAME "${OPENGL_gl_LIBRARY}")
689     endif()
690     set_target_properties(OpenGL::GL PROPERTIES
691     INTERFACE_INCLUDE_DIRECTORIES "${OPENGL_INCLUDE_DIR}")
692     elseif(NOT TARGET OpenGL::GL AND TARGET OpenGL::OpenGL AND TARGET OpenGL::GLX)
693     # A legacy GL library is not available, but we can provide the legacy GL
694     # target using GLVND OpenGL+GLX.
695     add_library(OpenGL::GL INTERFACE IMPORTED)
696     set_target_properties(OpenGL::GL PROPERTIES INTERFACE_LINK_LIBRARIES
697     OpenGL::OpenGL)
698     set_property(TARGET OpenGL::GL APPEND PROPERTY INTERFACE_LINK_LIBRARIES
699     OpenGL::GLX)
700     set_target_properties(OpenGL::GL PROPERTIES INTERFACE_INCLUDE_DIRECTORIES
701     "${OPENGL_INCLUDE_DIR}")
702     endif()
703
704     # ::EGL is a GLVND library, and thus Linux-only: we don't bother checking
705     # for a framework version of this library.
706     # Note we test whether _OpenGL_EGL_IMPL is set. Based on the OpenGL implementation,
707     # _OpenGL_EGL_IMPL will be one of OpenGL::OpenGL, OpenGL::GLES2, OpenGL::GLES3
708     if(_OpenGL_EGL_IMPL AND OpenGL_EGL_FOUND AND NOT TARGET OpenGL::EGL)
709     if(IS_ABSOLUTE "${OPENGL_egl_LIBRARY}")
710     add_library(OpenGL::EGL UNKNOWN IMPORTED)
711     set_target_properties(OpenGL::EGL PROPERTIES IMPORTED_LOCATION
712     "${OPENGL_egl_LIBRARY}")
713     else()
714     add_library(OpenGL::EGL INTERFACE IMPORTED)
715     set_target_properties(OpenGL::EGL PROPERTIES IMPORTED_LIBNAME
716     "${OPENGL_egl_LIBRARY}")
717     endif()
718     set_target_properties(OpenGL::EGL PROPERTIES INTERFACE_LINK_LIBRARIES
719     "${_OpenGL_EGL_IMPL}")
720     # Note that EGL's include directory is different from OpenGL/GLX's!
721     set_target_properties(OpenGL::EGL PROPERTIES INTERFACE_INCLUDE_DIRECTORIES
722     "${OPENGL_EGL_INCLUDE_DIR}")
723     endif()
724
725     if(OPENGL_GLU_FOUND AND NOT TARGET OpenGL::GLU)
726     if(IS_ABSOLUTE "${OPENGL_glu_LIBRARY}")
727     add_library(OpenGL::GLU UNKNOWN IMPORTED)
728     if(OPENGL_glu_LIBRARY MATCHES "/([^/]+)\\.framework$")
729     set(_glu_fw "${OPENGL_glu_LIBRARY}/${CMAKE_MATCH_1}")
730     if(EXISTS "${_glu_fw}.tbd")
731     string(APPEND _glu_fw ".tbd")
732     endif()
733     set_target_properties(OpenGL::GLU PROPERTIES
734     IMPORTED_LOCATION "${_glu_fw}")
735     else()
736     set_target_properties(OpenGL::GLU PROPERTIES
737     IMPORTED_LOCATION "${OPENGL_glu_LIBRARY}")
738     endif()
739     else()
740     add_library(OpenGL::GLU INTERFACE IMPORTED)
741     set_target_properties(OpenGL::GLU PROPERTIES
742     IMPORTED_LIBNAME "${OPENGL_glu_LIBRARY}")
743     endif()
744     set_target_properties(OpenGL::GLU PROPERTIES
745     INTERFACE_LINK_LIBRARIES OpenGL::GL)
746     endif()
747
748     # OPENGL_LIBRARIES mirrors OpenGL::GL's logic ...
749     if(OPENGL_gl_LIBRARY)
750     set(OPENGL_LIBRARIES ${OPENGL_gl_LIBRARY})
751     elseif(TARGET OpenGL::OpenGL AND TARGET OpenGL::GLX)
752     set(OPENGL_LIBRARIES ${OPENGL_opengl_LIBRARY} ${OPENGL_glx_LIBRARY})
753     else()
754     set(OPENGL_LIBRARIES "")
755     endif()
756     # ... and also includes GLU, if available.
757     if(TARGET OpenGL::GLU)
758     list(APPEND OPENGL_LIBRARIES ${OPENGL_glu_LIBRARY})
759     endif()
760     endif()
761
762     # This deprecated setting is for backward compatibility with CMake1.4
763     set(OPENGL_LIBRARY ${OPENGL_LIBRARIES})
764     # This deprecated setting is for backward compatibility with CMake1.4
765     set(OPENGL_INCLUDE_PATH ${OPENGL_INCLUDE_DIR})
766
767     mark_as_advanced(${_OpenGL_CACHE_VARS})
768     unset(_OpenGL_CACHE_VARS)
