root/Development/ray/resources/cmake/modules/FindOpenGL.cmake
Revision: 1.1
Committed: Wed Nov 22 17:14:36 2023 UTC (2 years ago) by greg
CVS Tags: rad6R0, HEAD
Error occurred while calculating annotation data.
chore: method to find OpenGL by Randolph Fritz
1 # Distributed under the OSI-approved BSD 3-Clause License. See accompanying
2 # file Copyright.txt or https://cmake.org/licensing for details.
3
4 #[=======================================================================[.rst:
5 FindOpenGL
6 ----------
7
8 FindModule for OpenGL and OpenGL Utility Library (GLU).
9
10 .. versionchanged:: 3.2
11 X11 is no longer added as a dependency on Unix/Linux systems.
12
13 .. versionadded:: 3.10
14 GLVND support on Linux. See the :ref:`Linux Specific` section below.
15
16 Optional COMPONENTS
17 ^^^^^^^^^^^^^^^^^^^
18
19 .. versionadded:: 3.10
20
21 This module respects several optional COMPONENTS:
22
23 ``EGL``
24 The EGL interface between OpenGL, OpenGL ES and the underlying windowing system.
25
26 ``GLX``
27 An extension to X that interfaces OpenGL, OpenGL ES with X window system.
28
29 ``OpenGL``
30 The cross platform API for 3D graphics.
31
32 ``GLES2``
33 .. versionadded:: 3.27
34
35 A subset of OpenGL API for embedded systems with limited capabilities.
36
37 ``GLES3``
38 .. versionadded:: 3.27
39
40 A subset of OpenGL API for embedded systems with more capabilities.
41
42 IMPORTED Targets
43 ^^^^^^^^^^^^^^^^
44
45 .. versionadded:: 3.8
46
47 This module defines the :prop_tgt:`IMPORTED` targets:
48
49 ``OpenGL::GL``
50 Defined to the platform-specific OpenGL libraries if the system has OpenGL.
51 ``OpenGL::GLU``
52 Defined if the system has OpenGL Utility Library (GLU).
53
54 .. versionadded:: 3.10
55 Additionally, the following GLVND-specific library targets are defined:
56
57 ``OpenGL::OpenGL``
58 Defined to libOpenGL if the system is GLVND-based.
59 ``OpenGL::GLX``
60 Defined if the system has OpenGL Extension to the X Window System (GLX).
61 ``OpenGL::EGL``
62 Defined if the system has EGL.
63 ``OpenGL::GLES2``
64 .. versionadded:: 3.27
65
66 Defined if the system has GLES2.
67 ``OpenGL::GLES3``
68 .. versionadded:: 3.27
69
70 Defined if the system has GLES3.
71
72 Result Variables
73 ^^^^^^^^^^^^^^^^
74
75 This module sets the following variables:
76
77 ``OPENGL_FOUND``
78 True, if the system has OpenGL and all components are found.
79 ``OPENGL_XMESA_FOUND``
80 True, if the system has XMESA.
81 ``OPENGL_GLU_FOUND``
82 True, if the system has GLU.
83 ``OpenGL_OpenGL_FOUND``
84 True, if the system has an OpenGL library.
85 ``OpenGL_GLX_FOUND``
86 True, if the system has GLX.
87 ``OpenGL_EGL_FOUND``
88 True, if the system has EGL.
89 ``OpenGL::GLES2``
90 Defined if the system has GLES2.
91 ``OpenGL::GLES3``
92 Defined if the system has GLES3.
93 ``OPENGL_INCLUDE_DIR``
94 Path to the OpenGL include directory.
95 ``OPENGL_EGL_INCLUDE_DIRS``
96 Path to the EGL include directory.
97 ``OPENGL_LIBRARIES``
98 Paths to the OpenGL library, windowing system libraries, and GLU libraries.
99 On Linux, this assumes GLX and is never correct for EGL-based targets.
100 Clients are encouraged to use the ``OpenGL::*`` import targets instead.
101
102 .. versionadded:: 3.10
103 Variables for GLVND-specific libraries ``OpenGL``, ``EGL`` and ``GLX``.
104
105 Cache variables
106 ^^^^^^^^^^^^^^^
107
108 The following cache variables may also be set:
109
110 ``OPENGL_egl_LIBRARY``
111 Path to the EGL library.
112 ``OPENGL_glu_LIBRARY``
113 Path to the GLU library.
114 ``OPENGL_glx_LIBRARY``
115 Path to the GLVND 'GLX' library.
116 ``OPENGL_opengl_LIBRARY``
117 Path to the GLVND 'OpenGL' library
118 ``OPENGL_gl_LIBRARY``
119 Path to the OpenGL library. New code should prefer the ``OpenGL::*`` import
120 targets.
121 ``OPENGL_gles2_LIBRARY``
122 .. versionadded:: 3.27
123
124 Path to the OpenGL GLES2 library.
125 ``OPENGL_gles3_LIBRARY``
126 .. versionadded:: 3.27
127
128 Path to the OpenGL GLES3 library.
129
130 .. versionadded:: 3.10
131 Variables for GLVND-specific libraries ``OpenGL``, ``EGL`` and ``GLX``.
132
133 .. _`Linux Specific`:
134
135 Linux-specific
136 ^^^^^^^^^^^^^^
137
138 Some Linux systems utilize GLVND as a new ABI for OpenGL. GLVND separates
139 context libraries from OpenGL itself; OpenGL lives in "libOpenGL", and
140 contexts are defined in "libGLX" or "libEGL". GLVND is currently the only way
141 to get OpenGL 3+ functionality via EGL in a manner portable across vendors.
142 Projects may use GLVND explicitly with target ``OpenGL::OpenGL`` and either
143 ``OpenGL::GLX`` or ``OpenGL::EGL``.
144
145 Projects may use the ``OpenGL::GL`` target (or ``OPENGL_LIBRARIES`` variable)
146 to use legacy GL interfaces. These will use the legacy GL library located
147 by ``OPENGL_gl_LIBRARY``, if available. If ``OPENGL_gl_LIBRARY`` is empty or
148 not found and GLVND is available, the ``OpenGL::GL`` target will use GLVND
149 ``OpenGL::OpenGL`` and ``OpenGL::GLX`` (and the ``OPENGL_LIBRARIES``
150 variable will use the corresponding libraries). Thus, for non-EGL-based
151 Linux targets, the ``OpenGL::GL`` target is most portable.
152
153 A ``OpenGL_GL_PREFERENCE`` variable may be set to specify the preferred way
154 to provide legacy GL interfaces in case multiple choices are available.
155 The value may be one of:
156
157 ``GLVND``
158 If the GLVND OpenGL and GLX libraries are available, prefer them.
159 This forces ``OPENGL_gl_LIBRARY`` to be empty.
160
161 .. versionchanged:: 3.11
162 This is the default, unless policy :policy:`CMP0072` is set to ``OLD``
163 and no components are requested (since components
164 correspond to GLVND libraries).
165
166 ``LEGACY``
167 Prefer to use the legacy libGL library, if available.
168
169 For EGL targets the client must rely on GLVND support on the user's system.
170 Linking should use the ``OpenGL::OpenGL OpenGL::EGL`` targets. Using GLES*
171 libraries is theoretically possible in place of ``OpenGL::OpenGL``, but this
172 module does not currently support that; contributions welcome.
173
174 ``OPENGL_egl_LIBRARY`` and ``OPENGL_EGL_INCLUDE_DIRS`` are defined in the case of
175 GLVND. For non-GLVND Linux and other systems these are left undefined.
176
177 macOS-Specific
178 ^^^^^^^^^^^^^^
179
180 On macOS FindOpenGL defaults to using the macOS-native framework
181 version of OpenGL. To use the X11 version of OpenGL on macOS, you
182 need to disable searching of frameworks and point CMake to the X11
183 libraries. Using the XQuartz X11 server, do something like this::
184
185 if(APPLE AND X11_FOUND)
186 set(CMAKE_FIND_FRAMEWORK NEVER)
187 set(OpenGL_ROOT "/opt/X11") # or whatever your X11 server root is
188 find_package(OpenGL)
189 set(CMAKE_FIND_FRAMEWORK "")
190 else()
191 find_package(OpenGL)
192 endif()
193
194 You must first use find_package(X11) to ensure that X11 is available.
195
196 #]=======================================================================]
197
198 set(_OpenGL_REQUIRED_VARS OPENGL_gl_LIBRARY)
199
200 # Provide OPENGL_USE_<C> variables for each component.
201 foreach(component ${OpenGL_FIND_COMPONENTS})
202 string(TOUPPER ${component} _COMPONENT)
203 set(OPENGL_USE_${_COMPONENT} 1)
204 endforeach()
205
206 set(_OpenGL_CACHE_VARS)
207
208 if (WIN32)
209
210 if(BORLAND)
211 set (OPENGL_gl_LIBRARY import32 CACHE STRING "OpenGL library for win32")
212 set (OPENGL_glu_LIBRARY import32 CACHE STRING "GLU library for win32")
213 else()
214 set (OPENGL_gl_LIBRARY opengl32 CACHE STRING "OpenGL library for win32")
215 set (OPENGL_glu_LIBRARY glu32 CACHE STRING "GLU library for win32")
216 endif()
217
218 list(APPEND _OpenGL_CACHE_VARS
219 OPENGL_gl_LIBRARY
220 OPENGL_glu_LIBRARY
221 )
222 elseif (APPLE)
223 # The OpenGL.framework provides both gl and glu in OpenGL
224 # XQuartz provides libgl and libglu
225 find_library(OPENGL_gl_LIBRARY NAMES OpenGL GL DOC
226 "OpenGL GL library")
227 find_library(OPENGL_glu_LIBRARY NAMES OpenGL GLU DOC
228 "OpenGL GLU library")
229 find_path(OPENGL_INCLUDE_DIR NAMES OpenGL/gl.h GL/gl.h DOC
230 "Include for OpenGL")
231 list(APPEND _OpenGL_REQUIRED_VARS OPENGL_INCLUDE_DIR)
232
233 list(APPEND _OpenGL_CACHE_VARS
234 OPENGL_INCLUDE_DIR
235 OPENGL_gl_LIBRARY
236 OPENGL_glu_LIBRARY
237 )
238 else()
239 if (CMAKE_ANDROID_NDK)
240 set(_OPENGL_INCLUDE_PATH ${CMAKE_ANDROID_NDK}/sysroot/usr/include)
241 set(_OPENGL_LIB_PATH ${CMAKE_ANDROID_NDK}/platforms/android-${CMAKE_SYSTEM_VERSION}/arch-${CMAKE_ANDROID_ARCH}/usr/lib)
242 elseif (CMAKE_SYSTEM_NAME MATCHES "HP-UX")
243 # Handle HP-UX cases where we only want to find OpenGL in either hpux64
244 # or hpux32 depending on if we're doing a 64 bit build.
245 if(CMAKE_SIZEOF_VOID_P EQUAL 4)
246 set(_OPENGL_LIB_PATH
247 /opt/graphics/OpenGL/lib/hpux32/)
248 else()
249 set(_OPENGL_LIB_PATH
250 /opt/graphics/OpenGL/lib/hpux64/
251 /opt/graphics/OpenGL/lib/pa20_64)
252 endif()
253 elseif(CMAKE_SYSTEM_NAME STREQUAL Haiku)
254 set(_OPENGL_LIB_PATH
255 /boot/develop/lib/x86)
256 set(_OPENGL_INCLUDE_PATH
257 /boot/develop/headers/os/opengl)
258 elseif (CMAKE_SYSTEM_NAME STREQUAL "Linux")
259 # CMake doesn't support arbitrary globs in search paths.
260 file(GLOB _OPENGL_LIB_PATH
261 # The NVidia driver installation tool on Linux installs libraries to a
262 # `nvidia-<version>` subdirectory.
263 "/usr/lib/nvidia-*"
264 "/usr/lib32/nvidia-*")
265 endif()
266
267 # The first line below is to make sure that the proper headers
268 # are used on a Linux machine with the NVidia drivers installed.
269 # They replace Mesa with NVidia's own library but normally do not
270 # install headers and that causes the linking to
271 # fail since the compiler finds the Mesa headers but NVidia's library.
272 # Make sure the NVIDIA directory comes BEFORE the others.
273 # - Atanas Georgiev <[email protected]>
274 find_path(OPENGL_INCLUDE_DIR GL/gl.h
275 /usr/share/doc/NVIDIA_GLX-1.0/include
276 /usr/openwin/share/include
277 /opt/graphics/OpenGL/include
278 ${_OPENGL_INCLUDE_PATH}
279 )
280 find_path(OPENGL_GLX_INCLUDE_DIR GL/glx.h ${_OPENGL_INCLUDE_PATH})
281 find_path(OPENGL_EGL_INCLUDE_DIR EGL/egl.h ${_OPENGL_INCLUDE_PATH})
282 find_path(OPENGL_GLES2_INCLUDE_DIR GLES2/gl2.h ${_OPENGL_INCLUDE_PATH})
283 find_path(OPENGL_GLES3_INCLUDE_DIR GLES3/gl3.h ${_OPENGL_INCLUDE_PATH})
284 find_path(OPENGL_xmesa_INCLUDE_DIR GL/xmesa.h
285 /usr/share/doc/NVIDIA_GLX-1.0/include
286 /usr/openwin/share/include
287 /opt/graphics/OpenGL/include
288 )
289
290 list(APPEND _OpenGL_CACHE_VARS
291 OPENGL_INCLUDE_DIR
292 OPENGL_GLX_INCLUDE_DIR
293 OPENGL_EGL_INCLUDE_DIR
294 OPENGL_GLES2_INCLUDE_DIR
295 OPENGL_GLES3_INCLUDE_DIR
296 OPENGL_xmesa_INCLUDE_DIR
297 )
298
299 # Search for the GLVND libraries. We do this regardless of COMPONENTS; we'll
300 # take into account the COMPONENTS logic later.
301 find_library(OPENGL_opengl_LIBRARY
302 NAMES OpenGL
303 PATHS ${_OPENGL_LIB_PATH}
304 )
305
306 find_library(OPENGL_glx_LIBRARY
307 NAMES GLX
308 PATHS ${_OPENGL_LIB_PATH}
309 PATH_SUFFIXES libglvnd
310 )
311
312 find_library(OPENGL_egl_LIBRARY
313 NAMES EGL
314 PATHS ${_OPENGL_LIB_PATH}
315 PATH_SUFFIXES libglvnd
316 )
317
318 find_library(OPENGL_gles2_LIBRARY
319 NAMES GLESv2
320 PATHS ${_OPENGL_LIB_PATH}
321 )
322
323 find_library(OPENGL_gles3_LIBRARY
324 NAMES GLESv3
325 GLESv2 # mesa provides only libGLESv2
326 PATHS ${_OPENGL_LIB_PATH}
327 )
328
329 find_library(OPENGL_glu_LIBRARY
330 NAMES GLU MesaGLU
331 PATHS ${OPENGL_gl_LIBRARY}
332 /opt/graphics/OpenGL/lib
333 /usr/openwin/lib
334 /usr/shlib
335 )
336
337 list(APPEND _OpenGL_CACHE_VARS
338 OPENGL_opengl_LIBRARY
339 OPENGL_glx_LIBRARY
340 OPENGL_egl_LIBRARY
341 OPENGL_gles2_LIBRARY
342 OPENGL_gles3_LIBRARY
343 OPENGL_glu_LIBRARY
344 )
345
346 set(_OpenGL_GL_POLICY_WARN 0)
347 if(NOT DEFINED OpenGL_GL_PREFERENCE)
348 set(OpenGL_GL_PREFERENCE "")
349 endif()
350 if(NOT OpenGL_GL_PREFERENCE STREQUAL "")
351 # A preference has been explicitly specified.
352 if(NOT OpenGL_GL_PREFERENCE MATCHES "^(GLVND|LEGACY)$")
353 message(FATAL_ERROR
354 "OpenGL_GL_PREFERENCE value '${OpenGL_GL_PREFERENCE}' not recognized. "
355 "Allowed values are 'GLVND' and 'LEGACY'."
356 )
357 endif()
358 elseif(OpenGL_FIND_COMPONENTS)
359 # No preference was explicitly specified, but the caller did request
360 # at least one GLVND component. Prefer GLVND for legacy GL.
361 set(OpenGL_GL_PREFERENCE "GLVND")
362 else()
363 # No preference was explicitly specified and no GLVND components were
364 # requested. Use a policy to choose the default.
365 cmake_policy(GET CMP0072 _OpenGL_GL_POLICY)
366 if("x${_OpenGL_GL_POLICY}x" STREQUAL "xNEWx")
367 set(OpenGL_GL_PREFERENCE "GLVND")
368 else()
369 set(OpenGL_GL_PREFERENCE "LEGACY")
370 if("x${_OpenGL_GL_POLICY}x" STREQUAL "xx")
371 set(_OpenGL_GL_POLICY_WARN 1)
372 endif()
373 endif()
374 unset(_OpenGL_GL_POLICY)
375 endif()
376
377 if("x${OpenGL_GL_PREFERENCE}x" STREQUAL "xGLVNDx" AND OPENGL_opengl_LIBRARY AND OPENGL_glx_LIBRARY)
378 # We can provide legacy GL using GLVND libraries.
379 # Do not use any legacy GL library.
380 set(OPENGL_gl_LIBRARY "")
381 else()
382 # We cannot provide legacy GL using GLVND libraries.
383 # Search for the legacy GL library.
384 find_library(OPENGL_gl_LIBRARY
385 NAMES GL MesaGL
386 PATHS /opt/graphics/OpenGL/lib
387 /usr/openwin/lib
388 /usr/shlib
389 ${_OPENGL_LIB_PATH}
390 PATH_SUFFIXES libglvnd
391 )
392 list(APPEND _OpenGL_CACHE_VARS OPENGL_gl_LIBRARY)
393 endif()
394
395 if(_OpenGL_GL_POLICY_WARN AND OPENGL_gl_LIBRARY AND OPENGL_opengl_LIBRARY AND OPENGL_glx_LIBRARY)
396 cmake_policy(GET_WARNING CMP0072 _cmp0072_warning)
397 message(AUTHOR_WARNING
398 "${_cmp0072_warning}\n"
399 "FindOpenGL found both a legacy GL library:\n"
400 " OPENGL_gl_LIBRARY: ${OPENGL_gl_LIBRARY}\n"
401 "and GLVND libraries for OpenGL and GLX:\n"
402 " OPENGL_opengl_LIBRARY: ${OPENGL_opengl_LIBRARY}\n"
403 " OPENGL_glx_LIBRARY: ${OPENGL_glx_LIBRARY}\n"
404 "OpenGL_GL_PREFERENCE has not been set to \"GLVND\" or \"LEGACY\", so for "
405 "compatibility with CMake 3.10 and below the legacy GL library will be used."
406 )
407 endif()
408 unset(_OpenGL_GL_POLICY_WARN)
409
410 # FPHSA cannot handle "this OR that is required", so we conditionally set what
411 # it must look for. First clear any previous config we might have done:
412 set(_OpenGL_REQUIRED_VARS)
413
414 # now we append the libraries as appropriate. The complicated logic
415 # basically comes down to "use libOpenGL when we can, and add in specific
416 # context mechanisms when requested, or we need them to preserve the previous
417 # default where glx is always available."
418 if((NOT OPENGL_USE_EGL AND
419 NOT OPENGL_opengl_LIBRARY AND
420 OPENGL_glx_LIBRARY AND
421 NOT OPENGL_gl_LIBRARY) OR
422 (NOT OPENGL_USE_EGL AND
423 NOT OPENGL_USE_GLES3 AND
424 NOT OPENGL_USE_GLES2 AND
425 NOT OPENGL_glx_LIBRARY AND
426 NOT OPENGL_gl_LIBRARY) OR
427 (NOT OPENGL_USE_EGL AND
428 OPENGL_opengl_LIBRARY AND
429 OPENGL_glx_LIBRARY) OR
430 (NOT OPENGL_USE_GLES3 AND
431 NOT OPENGL_USE_GLES2 AND
432 OPENGL_USE_EGL))
433 list(APPEND _OpenGL_REQUIRED_VARS OPENGL_opengl_LIBRARY)
434 endif()
435
436 # GLVND GLX library. Preferred when available.
437 if((NOT OPENGL_USE_OPENGL AND
438 NOT OPENGL_USE_GLX AND
439 NOT OPENGL_USE_EGL AND
440 NOT OPENGL_USE_GLES3 AND
441 NOT OPENGL_USE_GLES2 AND
442 NOT OPENGL_glx_LIBRARY AND
443 NOT OPENGL_gl_LIBRARY) OR
444 ( OPENGL_USE_GLX AND
445 NOT OPENGL_USE_EGL AND
446 NOT OPENGL_USE_GLES3 AND
447 NOT OPENGL_USE_GLES2 AND
448 NOT OPENGL_glx_LIBRARY AND
449 NOT OPENGL_gl_LIBRARY) OR
450 (NOT OPENGL_USE_EGL AND
451 NOT OPENGL_USE_GLES3 AND
452 NOT OPENGL_USE_GLES2 AND
453 OPENGL_opengl_LIBRARY AND
454 OPENGL_glx_LIBRARY) OR
455 (OPENGL_USE_GLX AND OPENGL_USE_EGL))
456 list(APPEND _OpenGL_REQUIRED_VARS OPENGL_glx_LIBRARY)
457 endif()
458
459 # GLVND EGL library.
460 if(OPENGL_USE_EGL)
461 list(APPEND _OpenGL_REQUIRED_VARS OPENGL_egl_LIBRARY)
462 endif()
463
464 # GLVND GLES2 library.
465 if(OPENGL_USE_GLES2)
466 list(APPEND _OpenGL_REQUIRED_VARS OPENGL_gles2_LIBRARY)
467 endif()
468
469 # GLVND GLES3 library.
470 if(OPENGL_USE_GLES3)
471 list(APPEND _OpenGL_REQUIRED_VARS OPENGL_gles3_LIBRARY)
472 endif()
473
474 # Old-style "libGL" library: used as a fallback when GLVND isn't available.
475 if((NOT OPENGL_USE_EGL AND
476 NOT OPENGL_opengl_LIBRARY AND
477 OPENGL_glx_LIBRARY AND
478 OPENGL_gl_LIBRARY) OR
479 (NOT OPENGL_USE_EGL AND
480 NOT OPENGL_glx_LIBRARY AND
481 OPENGL_gl_LIBRARY))
482 list(PREPEND _OpenGL_REQUIRED_VARS OPENGL_gl_LIBRARY)
483 endif()
484
485 # We always need the 'gl.h' include dir.
486 if(OPENGL_USE_EGL)
487 list(APPEND _OpenGL_REQUIRED_VARS OPENGL_EGL_INCLUDE_DIR)
488 else()
489 list(APPEND _OpenGL_REQUIRED_VARS OPENGL_INCLUDE_DIR)
490 endif()
491
492 unset(_OPENGL_INCLUDE_PATH)
493 unset(_OPENGL_LIB_PATH)
494
495 find_library(OPENGL_glu_LIBRARY
496 NAMES GLU MesaGLU
497 PATHS ${OPENGL_gl_LIBRARY}
498 /opt/graphics/OpenGL/lib
499 /usr/openwin/lib
500 /usr/shlib
501 )
502 endif ()
503
504 if(OPENGL_xmesa_INCLUDE_DIR)
505 set( OPENGL_XMESA_FOUND "YES" )
506 else()
507 set( OPENGL_XMESA_FOUND "NO" )
508 endif()
509
510 if(OPENGL_glu_LIBRARY)
511 set( OPENGL_GLU_FOUND "YES" )
512 else()
513 set( OPENGL_GLU_FOUND "NO" )
514 endif()
515
516 # OpenGL_OpenGL_FOUND is a bit unique in that it is okay if /either/ libOpenGL
517 # or libGL is found.
518 # Using libGL with libEGL is never okay, though; we handle that case later.
519 if(NOT OPENGL_opengl_LIBRARY AND NOT OPENGL_gl_LIBRARY)
520 set(OpenGL_OpenGL_FOUND FALSE)
521 else()
522 set(OpenGL_OpenGL_FOUND TRUE)
523 endif()
524
525 if(OPENGL_glx_LIBRARY AND OPENGL_GLX_INCLUDE_DIR)
526 set(OpenGL_GLX_FOUND TRUE)
527 else()
528 set(OpenGL_GLX_FOUND FALSE)
529 endif()
530
531 if(OPENGL_egl_LIBRARY AND OPENGL_EGL_INCLUDE_DIR)
532 set(OpenGL_EGL_FOUND TRUE)
533 else()
534 set(OpenGL_EGL_FOUND FALSE)
535 endif()
536
537 if(OPENGL_gles2_LIBRARY AND OPENGL_GLES2_INCLUDE_DIR)
538 set(OpenGL_GLES2_FOUND TRUE)
539 else()
540 set(OpenGL_GLES2_FOUND FALSE)
541 endif()
542
543 if(OPENGL_gles3_LIBRARY AND OPENGL_GLES3_INCLUDE_DIR)
544 set(OpenGL_GLES3_FOUND TRUE)
545 else()
546 set(OpenGL_GLES3_FOUND FALSE)
547 endif()
548
549 # User-visible names should be plural.
550 if(OPENGL_EGL_INCLUDE_DIR)
551 set(OPENGL_EGL_INCLUDE_DIRS ${OPENGL_EGL_INCLUDE_DIR})
552 endif()
553
554 include(FindPackageHandleStandardArgs)
555 if (CMAKE_FIND_PACKAGE_NAME STREQUAL "GLU")
556 # FindGLU include()'s this module. It's an old pattern, but rather than
557 # trying to suppress this from outside the module (which is then sensitive to
558 # the contents, detect the case in this module and suppress it explicitly.
559 set(FPHSA_NAME_MISMATCHED 1)
560 endif ()
561 FIND_PACKAGE_HANDLE_STANDARD_ARGS(OpenGL REQUIRED_VARS ${_OpenGL_REQUIRED_VARS}
562 HANDLE_COMPONENTS)
563 unset(FPHSA_NAME_MISMATCHED)
564 unset(_OpenGL_REQUIRED_VARS)
565
566 # OpenGL:: targets
567 if(OPENGL_FOUND)
568 # ::OpenGL is a GLVND library, and thus Linux-only: we don't bother checking
569 # for a framework version of this library.
570 if(OPENGL_opengl_LIBRARY AND NOT TARGET OpenGL::OpenGL)
571 if(IS_ABSOLUTE "${OPENGL_opengl_LIBRARY}")
572 add_library(OpenGL::OpenGL UNKNOWN IMPORTED)
573 set_target_properties(OpenGL::OpenGL PROPERTIES IMPORTED_LOCATION
574 "${OPENGL_opengl_LIBRARY}")
575 else()
576 add_library(OpenGL::OpenGL INTERFACE IMPORTED)
577 set_target_properties(OpenGL::OpenGL PROPERTIES IMPORTED_LIBNAME
578 "${OPENGL_opengl_LIBRARY}")
579 endif()
580 set_target_properties(OpenGL::OpenGL PROPERTIES INTERFACE_INCLUDE_DIRECTORIES
581 "${OPENGL_INCLUDE_DIR}")
582 set(_OpenGL_EGL_IMPL OpenGL::OpenGL)
583 endif()
584
585 # ::GLX is a GLVND library, and thus Linux-only: we don't bother checking
586 # for a framework version of this library.
587 if(OpenGL_GLX_FOUND AND NOT TARGET OpenGL::GLX AND TARGET OpenGL::OpenGL)
588 if(IS_ABSOLUTE "${OPENGL_glx_LIBRARY}")
589 add_library(OpenGL::GLX UNKNOWN IMPORTED)
590 set_target_properties(OpenGL::GLX PROPERTIES IMPORTED_LOCATION
591 "${OPENGL_glx_LIBRARY}")
592 else()
593 add_library(OpenGL::GLX INTERFACE IMPORTED)
594 set_target_properties(OpenGL::GLX PROPERTIES IMPORTED_LIBNAME
595 "${OPENGL_glx_LIBRARY}")
596 endif()
597 set_target_properties(OpenGL::GLX PROPERTIES INTERFACE_LINK_LIBRARIES
598 OpenGL::OpenGL)
599 set_target_properties(OpenGL::GLX PROPERTIES INTERFACE_INCLUDE_DIRECTORIES
600 "${OPENGL_GLX_INCLUDE_DIR}")
601 endif()
602
603 # ::GLES2 is a GLVND library, and thus Linux-only: we don't bother checking
604 # for a framework version of this library.
605 if(OpenGL_GLES2_FOUND AND NOT TARGET OpenGL::GLES2)
606
607 # Initialize target
608 if(NOT OPENGL_gles2_LIBRARY)
609 add_library(OpenGL::GLES2 INTERFACE IMPORTED)
610 else()
611 if(IS_ABSOLUTE "${OPENGL_gles2_LIBRARY}")
612 add_library(OpenGL::GLES2 UNKNOWN IMPORTED)
613 set_target_properties(OpenGL::GLES2 PROPERTIES
614 IMPORTED_LOCATION "${OPENGL_gles2_LIBRARY}"
615 )
616 else()
617 add_library(OpenGL::GLES2 INTERFACE IMPORTED)
618 set_target_properties(OpenGL::GLES2 PROPERTIES
619 IMPORTED_LIBNAME "${OPENGL_gles2_LIBRARY}"
620 )
621 endif()
622 endif()
623
624 # Attach target properties
625 set_target_properties(OpenGL::GLES2
626 PROPERTIES
627 INTERFACE_INCLUDE_DIRECTORIES
628 "${OPENGL_GLES2_INCLUDE_DIR}"
629 )
630
631 if (OPENGL_USE_GLES2)
632 set(_OpenGL_EGL_IMPL OpenGL::GLES2)
633 endif ()
634
635 endif()
636
637 # ::GLES3 is a GLVND library, and thus Linux-only: we don't bother checking
638 # for a framework version of this library.
639 if(OpenGL_GLES3_FOUND AND NOT TARGET OpenGL::GLES3)
640
641 # Initialize target
642 if(NOT OPENGL_gles3_LIBRARY)
643 add_library(OpenGL::GLES3 INTERFACE IMPORTED)
644 else()
645 if(IS_ABSOLUTE "${OPENGL_gles3_LIBRARY}")
646 add_library(OpenGL::GLES3 UNKNOWN IMPORTED)
647 set_target_properties(OpenGL::GLES3 PROPERTIES
648 IMPORTED_LOCATION "${OPENGL_gles3_LIBRARY}"
649 )
650 else()
651 add_library(OpenGL::GLES3 INTERFACE IMPORTED)
652 set_target_properties(OpenGL::GLES3 PROPERTIES
653 IMPORTED_LIBNAME "${OPENGL_gles3_LIBRARY}"
654 )
655 endif()
656 endif()
657
658 # Attach target properties
659 set_target_properties(OpenGL::GLES3 PROPERTIES
660 INTERFACE_INCLUDE_DIRECTORIES
661 "${OPENGL_GLES3_INCLUDE_DIR}"
662 )
663
664 if (OPENGL_USE_GLES3)
665 set(_OpenGL_EGL_IMPL OpenGL::GLES3)
666 endif ()
667
668 endif()
669
670 if(OPENGL_gl_LIBRARY AND NOT TARGET OpenGL::GL)
671 # A legacy GL library is available, so use it for the legacy GL target.
672 if(IS_ABSOLUTE "${OPENGL_gl_LIBRARY}")
673 add_library(OpenGL::GL UNKNOWN IMPORTED)
674 if(OPENGL_gl_LIBRARY MATCHES "/([^/]+)\\.framework$")
675 set(_gl_fw "${OPENGL_gl_LIBRARY}/${CMAKE_MATCH_1}")
676 if(EXISTS "${_gl_fw}.tbd")
677 string(APPEND _gl_fw ".tbd")
678 endif()
679 set_target_properties(OpenGL::GL PROPERTIES
680 IMPORTED_LOCATION "${_gl_fw}")
681 else()
682 set_target_properties(OpenGL::GL PROPERTIES
683 IMPORTED_LOCATION "${OPENGL_gl_LIBRARY}")
684 endif()
685 else()
686 add_library(OpenGL::GL INTERFACE IMPORTED)
687 set_target_properties(OpenGL::GL PROPERTIES
688 IMPORTED_LIBNAME "${OPENGL_gl_LIBRARY}")
689 endif()
690 set_target_properties(OpenGL::GL PROPERTIES
691 INTERFACE_INCLUDE_DIRECTORIES "${OPENGL_INCLUDE_DIR}")
692 elseif(NOT TARGET OpenGL::GL AND TARGET OpenGL::OpenGL AND TARGET OpenGL::GLX)
693 # A legacy GL library is not available, but we can provide the legacy GL
694 # target using GLVND OpenGL+GLX.
695 add_library(OpenGL::GL INTERFACE IMPORTED)
696 set_target_properties(OpenGL::GL PROPERTIES INTERFACE_LINK_LIBRARIES
697 OpenGL::OpenGL)
698 set_property(TARGET OpenGL::GL APPEND PROPERTY INTERFACE_LINK_LIBRARIES
699 OpenGL::GLX)
700 set_target_properties(OpenGL::GL PROPERTIES INTERFACE_INCLUDE_DIRECTORIES
701 "${OPENGL_INCLUDE_DIR}")
702 endif()
703
704 # ::EGL is a GLVND library, and thus Linux-only: we don't bother checking
705 # for a framework version of this library.
706 # Note we test whether _OpenGL_EGL_IMPL is set. Based on the OpenGL implementation,
707 # _OpenGL_EGL_IMPL will be one of OpenGL::OpenGL, OpenGL::GLES2, OpenGL::GLES3
708 if(_OpenGL_EGL_IMPL AND OpenGL_EGL_FOUND AND NOT TARGET OpenGL::EGL)
709 if(IS_ABSOLUTE "${OPENGL_egl_LIBRARY}")
710 add_library(OpenGL::EGL UNKNOWN IMPORTED)
711 set_target_properties(OpenGL::EGL PROPERTIES IMPORTED_LOCATION
712 "${OPENGL_egl_LIBRARY}")
713 else()
714 add_library(OpenGL::EGL INTERFACE IMPORTED)
715 set_target_properties(OpenGL::EGL PROPERTIES IMPORTED_LIBNAME
716 "${OPENGL_egl_LIBRARY}")
717 endif()
718 set_target_properties(OpenGL::EGL PROPERTIES INTERFACE_LINK_LIBRARIES
719 "${_OpenGL_EGL_IMPL}")
720 # Note that EGL's include directory is different from OpenGL/GLX's!
721 set_target_properties(OpenGL::EGL PROPERTIES INTERFACE_INCLUDE_DIRECTORIES
722 "${OPENGL_EGL_INCLUDE_DIR}")
723 endif()
724
725 if(OPENGL_GLU_FOUND AND NOT TARGET OpenGL::GLU)
726 if(IS_ABSOLUTE "${OPENGL_glu_LIBRARY}")
727 add_library(OpenGL::GLU UNKNOWN IMPORTED)
728 if(OPENGL_glu_LIBRARY MATCHES "/([^/]+)\\.framework$")
729 set(_glu_fw "${OPENGL_glu_LIBRARY}/${CMAKE_MATCH_1}")
730 if(EXISTS "${_glu_fw}.tbd")
731 string(APPEND _glu_fw ".tbd")
732 endif()
733 set_target_properties(OpenGL::GLU PROPERTIES
734 IMPORTED_LOCATION "${_glu_fw}")
735 else()
736 set_target_properties(OpenGL::GLU PROPERTIES
737 IMPORTED_LOCATION "${OPENGL_glu_LIBRARY}")
738 endif()
739 else()
740 add_library(OpenGL::GLU INTERFACE IMPORTED)
741 set_target_properties(OpenGL::GLU PROPERTIES
742 IMPORTED_LIBNAME "${OPENGL_glu_LIBRARY}")
743 endif()
744 set_target_properties(OpenGL::GLU PROPERTIES
745 INTERFACE_LINK_LIBRARIES OpenGL::GL)
746 endif()
747
748 # OPENGL_LIBRARIES mirrors OpenGL::GL's logic ...
749 if(OPENGL_gl_LIBRARY)
750 set(OPENGL_LIBRARIES ${OPENGL_gl_LIBRARY})
751 elseif(TARGET OpenGL::OpenGL AND TARGET OpenGL::GLX)
752 set(OPENGL_LIBRARIES ${OPENGL_opengl_LIBRARY} ${OPENGL_glx_LIBRARY})
753 else()
754 set(OPENGL_LIBRARIES "")
755 endif()
756 # ... and also includes GLU, if available.
757 if(TARGET OpenGL::GLU)
758 list(APPEND OPENGL_LIBRARIES ${OPENGL_glu_LIBRARY})
759 endif()
760 endif()
761
762 # This deprecated setting is for backward compatibility with CMake1.4
763 set(OPENGL_LIBRARY ${OPENGL_LIBRARIES})
764 # This deprecated setting is for backward compatibility with CMake1.4
765 set(OPENGL_INCLUDE_PATH ${OPENGL_INCLUDE_DIR})
766
767 mark_as_advanced(${_OpenGL_CACHE_VARS})
768 unset(_OpenGL_CACHE_VARS)
